Old 09-02-2009, 06:30 PM   #4201
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,274
I knew you were up to something!!! Havent seen you connected lately!!!
Originally Posted by sambor1965
Carlos locorider
1974 Catalina 22....sailing, mi otra pasión!
"If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian
"Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller
Longaniza Ride
Ruta del Café
Old 09-02-2009, 08:42 PM   #4202
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 523
And I had a great adventure of a tough day at work today. I'm watching with jealousy.
A-Wind is offline   Reply With Quote
Old 09-02-2009, 11:21 PM   #4203
sambor1965
Oddometer: 897
Send a message via Skype™ to sambor1965
www.advfactory.com
sambor1965 is offline   Reply With Quote
Old 09-03-2009, 03:05 AM   #4204
Jim Davis
Owner, Eastern Beaver Co
Jim Davis's Avatar
Oddometer: 201
RD-03 balance the tires?
Hi guys, me again about tires on the RD03. I think I got the ideal pressure now on both, but I'd still like to know about balancing.
How many of you have some kind of weights on your rims?
What do you do about a tire with no markings - do you turn it 180 degrees and try it again if it's way off balance?
What kind of weights do you use? I used four 10 gram stick on weights but they look pretty ugly. I think on the Norton I used a type of weight that went over a spoke head, is that what I should be using?
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics.
Check out my new fusepanel, the PC-8!
1988 Africa Twin 650, 1990 VFR, Address 110
Super G Riders, Tokyo Riders
Jim Davis is offline   Reply With Quote
Old 09-03-2009, 11:04 AM   #4205
Mhassic
Oddometer: 44
Originally Posted by abat
Hi all.
I just installed a front fork on my DR04 from a KTM 620.
What springs should i put in these forks?i believe the springs too soft for the bike.what suggestion can you give me?
Thanks.
How did you do it?
I have the same project to come.
Mhassic is offline   Reply With Quote
Old 09-03-2009, 11:57 AM   #4206
axel32
Oddometer: 5
countershaft replacement in BC canada
hello all !
i am axel from hamburg germany and new on ADVrider .... nice page!
i am on a roundtheworldtour .... stucked in BC canada
my honda african twin rd07 1995 160.000 km needs a new countershaft! can somebody help with knowledge, tricks etc... maybe an old RDO7 with spareparts?!
thanks in advance
axel
axel32 is offline   Reply With Quote
Old 09-03-2009, 12:27 PM   #4207
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 523
Originally Posted by axel32
...my honda african twin rd07 1995 160.000 km needs a new countershaft...
Axel, you could have a new sprocket welded on. The shaft is gone anyways, so why not? It would enable you to continue your trip. If you decide to do so, make sure you disconnect your CDI just in case (I blew a CDI once right after a welding job of the sidestand).
Old 09-03-2009, 12:32 PM   #4208
Andy G
2wheeled alpinist
Andy G's Avatar
Oddometer: 551
Hi Axel,
welcome to the asylum!
there was a guy some pages back, also on RTW, who destroyed the upper half of his engine, maybe you can get the remains of his engine. The AT was never sold in America, so parts are rare. And changing the countershaft is .... you have to remove the engine, dissassemble it completely and put it back together. Is there no chance of welding the sprocket to the countershaft? That would do for the next 15 to 20k kms.
Grüße aus der fernen Heimat,
andy
Andy G is offline   Reply With Quote
Old 09-03-2009, 01:10 PM   #4209
GSPD750
GSPD750's Avatar
Oddometer: 1,217
hello all !
thanks in advance
axel
What exactly is the problem with the countershaft? I'm assuming the splines are worn on the shaft where the front sprocket rides. If you want to know a trick and get back on the road again soon then I would suggest have someone weld a new spocket to the countershaft...right where the splines are worn (item #19 to #4) . It's been done before.
Replacing the countershaft is labour intensive as you have to split the cases. The shaft alone is 140 euro, amongst all the gaskets you will require. Many of those parts will have to come from europe. Item #30 is the output shaft bearing, and if that has excessive radial play then you will also have problems...including an oil leak. Hopefully that bearing is ok.
Qwik fix...weld new sprocket onto countershaft. Sprocket can be sourced locally from any honda motorcycle dealer for about $40 cdn.
You will also need a seal..item #18 in the second pic. This seal will have to be kept cool with wet rags while the welding is carried out. That will also be a challange.
Pic of the shaft with the oil seal removed. You can see the outputshaft bearing...which is pressed in from the inside of the case.
Keep us posted.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
"Almost no other bike has the road presence of the Africa Twin and cars seem to melt out of its way, once they see the angry glare of its lights in their mirrors." ...
GSPD750 is offline   Reply With Quote
Old 09-03-2009, 03:04 PM   #4210
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 523
Originally Posted by Andy G
...there was a guy some pages back, also on RTW, who destroyed the upper half of his engine, maybe you can get the remains of his engine...
I'm in contact with him, but as far as I know he has to send the remainder of his engine back to his country of origin to fullfill his carnet requirement. He is on the road again for over a week. I belive his engine is already on the way back home.
Old 09-03-2009, 03:25 PM   #4211
axel32
Oddometer: 5
hello again,
thanks for all the replys! welding could be an option... but what i will do when that welded sproked is worn out....?! weld a new one on....
i ve got a working visa for canada and i will work untill next mai in BC and then ride over to new york and ship from there to capetown SA. the african twin got sold there and parts are avalible...but it would be nice to do it by myself or with assitance!in canada. ( and i don t want to mess around with that in the middel of africa)
a friend comes over from europe next month, he could bring the parts!
would be a good thing to do, while i am here working anyway.
the guy with the broken engine i think he was from singapore.... i rode in his block that he had to ship his engine back to singapore ?! but i wrote him an email anyway.
so, anybody done that before?
thanks in advance
axel from hamburg
Old 09-03-2009, 03:28 PM   #4212
GSPD750
GSPD750's Avatar
Oddometer: 1,217
hello all !
i am axel from hamburg germany ... in BC canada
axel
What part of BC are you in? I'm heading there next week in the Nelson area of the Kootenays.
Engine on german ebay. I know the engine # is RDO4 (for your AT), however the auction does say RD04...or is that the bike model # ???
http://cgi.ebay.de/Honda-Africa-Twin...d=p3286.c0.m14
Old 09-03-2009, 03:33 PM   #4213
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 9,781
hello again,
Yep, I welded on a sprocket, did 25,000km, ground it off & welded on another one. Eventually I replaced the countershaft. It's a really big job !!!. The shaft itself isnt big $$ but all the gaskets etc add up. & also if your engine has high km and you are inside anyway then do the rings, valve recut & stem seals, cam chains & check all bearings etc really adds up
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 09-03-2009, 03:36 PM   #4214
GSPD750
GSPD750's Avatar
Oddometer: 1,217
hello again,
thanks in advance
axel from hamburg
Welding is the option if your stuck in Timbuctu...but if your staying in Canada for the winter then fixing it properly would be the way to go. Have your friend bring all the parts/gaskets from Germany and fix it. I've split my cases in the past on my AT for the output shaft bearing so if you have any questions.....
Old 09-03-2009, 03:42 PM   #4215
GSPD750
GSPD750's Avatar
Oddometer: 1,217
Good point Greg. It can add up indeed. 160,000 kms is alot of kms...it's ready for o'haul IMO too. It's all doable if you have the time and $... and your here till May.
Times are GMT -7.   It's 03:09 AM.
