Old 09-20-2009, 07:06 PM   #4276
E-Bum
E-Bum's Avatar
Oddometer: 707
Originally Posted by A-Wind
Is your front axle straight? How about the fork tubes?
My axle is straight.
Correct me if I'm wrong, but wouldn't the front fork tubes have to be aligned if my axle were straight and vice versa? It would be impossible to thread the axle through the first fork and into the second if they either the forks or the axle were bent correct?
E-Bum is offline   Reply With Quote
Old 09-21-2009, 02:17 AM   #4277
Jim Davis
Owner, Eastern Beaver Co
Jim Davis's Avatar
Oddometer: 229
Originally Posted by E-Bum
How much space do you other RD03 owners have at this interface?
I just checked. My disc is 5.5mm thick first of all and it's really really close to the caliper at the outside point but NOT touching...
Have you checked that your brake pads are the right thickness? I mean the total including steel backing.
It is possible to get an axle in even if the tubes are bent I suppose. I mean they'd have been bent with the axle in place, right?
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics.
2012 Yamaha WR250R in Japan.
Jim Davis is offline   Reply With Quote
Old 09-21-2009, 02:12 PM   #4278
E-Bum
E-Bum's Avatar
Oddometer: 707
Hm that's interesting that you too have a 5.5 mm disc... I mean the OEM specs call for a 4.5 mm disc.
Something must be wrong with my assembly though, since your 5.5 mm disc doesn't touch. Is there anyway you could take a pic from a similar angle so I can take a look?
Here is the overall picture. Looks pretty normal.... although a small distance is going to be hard to notice I guess.
Here are some pictures from below the forks to get an idea of what the spacing looks like. I'm a little curious as to this picture below:
What I'm looking at is that space between the fork tube and the speedometer assembly. There's a good 5-6 mm of visible axle (where the blue grease is). Is that space suppose to be there? The wheel does not slide from side to side in any way along the axle.... And really, the only thing that would close that gap and shift the wheel a few mm's away from that caliper bracket is if I had a bit longer distance collar...
Old 09-21-2009, 02:26 PM   #4279
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
E-Bum, Your axle doesn't look like it's all the way in. It protrudes too much outside the fork clamp. The shoulder part of the axle should be touching the speedo drive.
Jim.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 09-21-2009, 03:42 PM   #4280
Mario Shi
Mario Shi's Avatar
Oddometer: 516
PM sent. I may be able to give you some ideas as I had something similar happen to me.
Jim, now you know why I bought those new discs (one of mine got warped due to misalignment and rubbing on that bracket). Thanks to you, I'm now good to go! Mario
Mario Shi
1985 CH150D
1994 R100 GS PD
1967 R60/2
1989 XL600V TRANSALP
1999 XRV750X Africa Twin
1998 XR400r - plated & electric start
1999 XR250r - plated
1998 M900
Ahhh, if it was that, then it would be it - Butt Head
Mario Shi is offline   Reply With Quote
Old 09-21-2009, 04:09 PM   #4281
E-Bum
E-Bum's Avatar
Oddometer: 707
I'll get in contact with you XRV.
Jim, I think my axle is in as far as it goes. The end of the axle protrudes about .5-1mm out from my other fork, which is what I remember it doing. I also compared it to my brother's 89 Transalp, which looks exactly the same as mine as far as protruding distance goes. How much of the axle sticks out on yours?
Old 09-21-2009, 05:49 PM   #4282
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,484
Take out the disk and put everything back together, but without the disk and see how it goes...and from the pics the wheel is more the right side of the bike...
Carlos locorider
From Puerto Rico to Georgia and beyond...
locorider screwed with this post 09-21-2009 at 05:57 PM
Old 09-21-2009, 07:06 PM   #4283
Jim Davis
Jim Davis's Avatar
Oddometer: 229
I took some photos, mine looks just like yours by the speedo drive. I don't believe you have a problem there.
Have you actually measured the thickness of your rotor?
Speedo Drive Area:
Looking Down the Disc, Fork Side:
Disc Spoke Side:
Old 09-22-2009, 12:00 AM   #4284
ravelv
from Baltic side of river
Oddometer: 444
Don't look to right speedo side of axle, yours looks same as on my Transalp. Most important is left side where brake rotor is and also spacer between wheel bearing and fork- this is what defines rotor's position against caliper. Take apart wheel bearings, compare also spacer to TA's spacer- they must be same. you can try also TA's wheel, wheels are same between RD03 and TA up to 1996.
ravelv is offline   Reply With Quote
Old 09-22-2009, 03:28 PM   #4285
Menasco Pirate
Menasco Pirate's Avatar
Oddometer: 349
parts list for 94 RD07
Looking for a parts list or fish for a 1994 RD07 AT.
Are the RD07 engines identical (or close) to the RD04 engines?
Steve
XLV750, RTL250S, 1989 XL600V, 1990 XL600V Transalps Red and Moonstone, 1992 XL600V Green, 1993 CRM250R, 1994 XRV750 Africa Twin
2009 FE390 tagged, 2011 FE450 tagged, 2011 FE570S super motard, 2011 FE570S
Menasco Pirate is offline   Reply With Quote
Old 09-22-2009, 07:17 PM   #4286
GSPD750
GSPD750's Avatar
Oddometer: 1,439
Steve
Link to an 'R' model. Should be close enough.
http://zsf-motorrad.de/en/Spares/XRV750R-G-50P
Some Pulse Generator coils and HT coil differences between the models you mention.
More here.
Free workshop manual download for Honda Africa Twin+Transalp 650
You gotta pretty big stable there. Cool.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 09-22-2009, 07:43 PM   #4287
Menasco Pirate
Oddometer: 349
Thank you very much Just what I was looking for. Wish they would ship to USA. I'll try David Silver Spares now that I can identify the parts.
Steve
More here.
Old 09-22-2009, 08:18 PM   #4288
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I have had good luck with DSS before.
Jim Rowley
Black Forest, CO
Old 09-22-2009, 08:36 PM   #4289
Menasco Pirate
Oddometer: 349
Hi Jim, I agree
DSS ships faster than most US based internet parts suppliers.
Steve
Old 09-23-2009, 02:32 AM   #4290
stege
Wonderer
stege's Avatar
Oddometer: 288
Honda is working (according to Motorrad DE) on a Africa Twin followup, namely Africa Four, equipped with the 1200c V4 from the new VFR1200.
PIC
the older I get the faster I was
stege is offline   Reply With Quote
Times are GMT -7.   It's 09:55 AM.
