Old 07-15-2010, 05:57 PM   #6961
Stormforce8
Farkle Tart
Stormforce8's Avatar
Oddometer: 539
Originally Posted by G-Funk
Murphy is always lurking ......
G.
Lurking!!!!!...........he bloody lives with me full time!!!
www.ruggedroads.com
2000 Honda XRV750 Africa Twin RD07A - Rugged Roads Rallye Sport,
2002 Honda XRV750 Africa Twin RD07A - RWB
1989 Honda XRV750 Africa Twin RD04 - HRC
'Maybe I'm just simple - but can't we all just get along..........'
Stormforce8 is offline   Reply With Quote
Old 07-15-2010, 06:41 PM   #6962
wrryder
wrryder's Avatar
Oddometer: 165
Inmates to the rescue! Great job helping a friend in need.
This brings a thought to mind; what spares should we bring on the NAATS? I'm bringing a spare fuel pump and a 21" tube and my trusty tool roll.
Does anyone have a spare CDI or Regulator to bring? What else might we need?
I usually don't worry to much about this kind of stuff but having 15, or so, ATs in one place for the better part of a week might raise the odds a little that someone might have an "issue".
Craig
RD07a
Sacramento, CA
Don't Feed the Bearcat!
wrryder is offline   Reply With Quote
Old 07-15-2010, 08:13 PM   #6963
E-Bum
E-Bum's Avatar
Oddometer: 720
We'll have at least one spare RD03/TA CDI. Unless our dad already shipped it back (he had ordered the RD07 CDI, but got an RD03 one for some reason).
BTW, text from alainmax: "7000 motos Redmond"
E-Bum is offline   Reply With Quote
Old 07-15-2010, 08:33 PM   #6964
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 639
Originally Posted by GSPD750
I would recommend you install it to the switched side of the ignition. You really don't want any parasitic draw when it's direct to the battery.
YES, that is true!
However the ignition switch is also one of the main culprit if it comes to voltage drop. So if you are connecting the monitor after your ignition switch, depending on the condition of the ignition switch, the monitor might not respond early enough to any beginning regulator failure.
Even severe voltage drop at the ignition switch can be real. Indeed that is what I just had that on my truck. It was close to a full 6V drop, that lead to a diagnostic nightmare, but that's a whole different story.
My plan is to equip my voltage monitor with a regular Battery Tender connector and connect it to my preexisting Battery Tender cable every once in a while.
A-Wind is offline   Reply With Quote
Old 07-15-2010, 08:47 PM   #6965
GSPD750
GSPD750's Avatar
Oddometer: 1,459
Your bringing a spare fuel pump? Whaddya mean...you don't have a Facet? Yes, I will have a spare Reg/Rectifier for an RD07A amongst the 3 tire irons and patch kit including an electric air pump....and thats about it.
Hey it's a Honda...what can go wrong?
I can make coffee too by the side of the road if need be.
We have to stop these negative thoughts eh G-Funk. So G-Funk...does that mean your not bringing your 1/2" torque wrench for the clutch nut then.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 07-15-2010, 08:51 PM   #6966
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,049
Is there any reason to suspect that using a Garmin 276c GPS unit is not a good tool to use to measure the bike's voltage?
How would you do this?
I run my 60CX direct to my battery. Is there a way that it reads incoming voltage?
OR
Does high voltage just turn the GPS into molten slag? That's be a pretty expensive warning.
NO PHOTO FOR THE NAATS STICKIE????? I'm shocked
On the wrench-twirling front - valve covers are back on with new gaskets and some stupidily expensive Suzuki silicone seal (that actually works really well) just in case.
Just finished the valve covers when my neighbor showed up with 2 cold ones. Needless to say, work stopped for the day.
Reassembly tomorrow.....I still have a few days left to pack....oh wait I have to wire the radios and go to DMV and get the bike registered (hate that part)
Ladder106 is offline   Reply With Quote
Old 07-15-2010, 08:52 PM   #6967
GSPD750
GSPD750's Avatar
Oddometer: 1,459
Originally Posted by A-Wind
YES, that is true!
I can't remember where i tapped my Dyna Charge Monitor into..but i believe their are numerous circuits on an AT that should not cause any issues...no?
But if your going the battery tender way then i'm sure your ok there too.
Old 07-15-2010, 09:05 PM   #6968
Mario Shi
Mario Shi's Avatar
Oddometer: 516
Hi Ray,
I also have a 60CSx - I don't believe this unit has the ability to measure voltage??? I just picked up a 276c, which does have the option to meaure. For what it's worth, I have the unit connected directly to the battery (fused, of course).
ps Really wish I could have had the chance to meet all of you during this upcoming ride. I'm sure you will have a great time!
OR
Mario Shi
1985 CH150D
1994 R100 GS PD
1967 R60/2
1989 XL600V TRANSALP
1999 XRV750X Africa Twin
1998 XR400r - plated & electric start
1999 XR250r - plated
1998 M900
Ahhh, if it was that, then it would be it - Butt Head
Mario Shi is offline   Reply With Quote
Old 07-15-2010, 10:03 PM   #6969
wrryder
wrryder's Avatar
Oddometer: 165
I've got a Facet but I'm not sure everyone does
Craig
RD07a
Sacramento, CA
Old 07-15-2010, 10:06 PM   #6970
wrryder
wrryder's Avatar
Oddometer: 165
My Husky 610 runs at an alarming 15.5VDC and it hasn't hurt my 60CSx so far. Headlight bulbs are another story.....
OR
Craig
RD07a
Sacramento, CA
Old 07-15-2010, 10:30 PM   #6971
Joz
What could go wrong?
Joz's Avatar
Oddometer: 1,895
All you guys heading to the NAATS are making me sick! Here's the current condition of my RD07A:
Fully stripped now, ready to be blasted this weekend then painted! I've got my work cut out for me....
Africa Twin, CRM250-AR, TLM220R, CT90, SY250
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Joz is offline   Reply With Quote
Old 07-16-2010, 07:50 AM   #6972
alainmax
ca vaut le detour !!
alainmax's Avatar
Oddometer: 618
good news; Papapete & bros on the road again...
Bad news: I lost my I-pod ( fell off the bike)
04 GS 1150
93 Africa twin RD07
alainmax is offline   Reply With Quote
Old 07-16-2010, 08:03 AM   #6973
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 07-16-2010, 08:13 AM   #6974
G-Funk
That ... Umm ..... "Dude"
G-Funk's Avatar
Oddometer: 5,259
10 ......
03 Caponord
"The Funness out-weighs the Dumbness ....." - Mr. Jetmoto
G-Funk is offline   Reply With Quote
Old 07-16-2010, 08:14 AM   #6975
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
10 ......
I probably should start getting ready...
Jim Rowley
Black Forest, CO
Times are GMT -7.   It's 05:24 PM.
