08-29-2010, 02:44 PM
#7606 | |
Farkle Tart
Oddometer: 503
And how is your Marathon coming along?
www.ruggedroads.com Honda XRV750 Africa Twin RD07A - Rugged Roads Rallye Sport, Honda XRV750 Africa Twin RD04 - HRC BMW R1150GS - Graphitan Yamaha XT600Z Tenere 3AJ - BYRD, Aprilia Moto 6.5 - Starck Orange, Cagiva N90 - Lucky Explorer 'Maybe I'm just simple - but can't we all just get along..........' |
08-29-2010, 03:00 PM
#7607 |
Oddometer: 66
Cédric, your marathon is just getting GREAT
08-29-2010, 03:41 PM
#7608 |
*thomas*
Oddometer: 164
pictures of the marathon rebuild?
08-29-2010, 03:55 PM
#7609 |
Squily
Oddometer: 1,042
Varadero question
I'm thinking of getting an eagle-screen for the Varadero. The standard one is pretty crap/low. They offer many variations in terms of size and width. My biggest concern is ending up with wind-buffeting if I go too big. Anybody tried one of their screens or have some suggestions please? I'm 6' 4"
![]() Squily |
08-29-2010, 04:26 PM
#7610 |
Oddometer: 1,217
Furthermore to my brake rotor enquiry. I think I may have found the OEM rotors at a fairly decent price over at Davidsilver.spares...quite a bit cheaper than I originally thought they would be.
Something tells me I would regret in the long run purchasing those ebay rotors.
1999 XRV 750 Africa Twin 1996 XL 600v Transalp "Almost no other bike has the road presence of the Africa Twin and cars seem to melt out of its way, once they see the angry glare of its lights in their mirrors." ... |
08-29-2010, 09:32 PM
#7611 |
It's a short cut, really
Oddometer: 4,302
I put one of the ebay rotors on the back of my bike.
I don't use the rear brake all that hard so thought it would be worth a try. No problems after 4000 miles or so. No warpage or strange wear patterns or anything. Fronts are more critical and may be a different story. You might try http://www.jtbraking.com/ They have engineering drawings of all the discs. You can find the specs for the RD07 then go down the list of bikes available in the US and Canada and see if any other model that's more available will match.....or you can just buy from them. |
08-29-2010, 11:39 PM
#7612 |
Desktop Adventurer.
Oddometer: 1,113
![]() Im yet to name her.
KTM Adventure 950S ![]() Honda XR650R ![]() Suzuki DRZ400S & M Honda XR125L
08-30-2010, 04:06 AM
#7613 | |
Oddometer: 1,217
Great info. thanks!
08-30-2010, 09:45 AM
#7614 |
Oddometer: 133
Saw once a pair of dics "wave" for about 300euros, but can't it anymore...
08-30-2010, 02:26 PM
#7615 | |
Oddometer: 10
![]() Some pictures ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() With her sister ![]() ![]() The sister ![]() Uploaded with ImageShack.us Uploaded with ImageShack.us
CB 125 K5 1975 CB 750 Four K6 1976 CBR 1100 XX 1999 DT 125R 1989 XT 600 2KF 1987 XRV 650 Africa Twin Marathon 1988 XRV 650 Africa Twin Marathon 1988 XTZ 750 SuperT 1990 Solex 3800 1966 |
08-30-2010, 02:29 PM
#7616 |
EcuaItalian on an RD07A
Choke cable and Carb overflow / Breather tube routing
Hi Guys,
I recently cleaned the carbs on my RD07A and it was all running like a dream with the new aluminum choke screws and sprigs (Thanks Alain!), and then I decided to connect the choke cables and test the movement of the lever. I tried several different cable routings and none seemed quite right... Most importantly, the bike started running like Sh___, until I disconnected the choke cable and re-inserted the plungers and the problem went away. Great! Now I know it's the cable routing, but now how do I get it right? I tried searching the thread with no luck. Anyone happen to have a photo or maybe could take one of their bike? On a similar note, since it's not very often that the tank and carbs come off, I decided to do a thorough cleaning of all the engine area and took all the tubes and hoses out of the lower stay (near the centerstand). I managed to put all of the hoses back where they belong, except for the hose the comes from the carb overfow: there seems to be one that goes up (where does it go to or come from?? ) and one that leads down by the other hoses... Help! I have looked in the factory service manual, as well as in the Haynes and there is no clear picture of the choke cable routing or the breather tube routing. Would anyone be able to lend a hand? Thanks,
G. Luigi Rota ATIC# 1977
08-30-2010, 04:35 PM
#7617 |
Oddometer: 4,302
I'm having similar problems with the heavier springs.
The bike ran fine for about 400 miles but now the cable to the right side choke seems to be hanging up and keeping the choke open. I can reach in through the right side air vent behind the radiator and wiggle this cable and the idle will even out. The bike will run fine for a while but then it comes back. Dunno if replacing the choke cable set is the best idea?? I'm also toying with the idea of blanking off the choke to the right side carb and just running the cable to the left one. With my climate, I rarely use the choke unless its the dead of winter. I'm thinking that only one carb with choke should still start the bike. I've tried a number of different cable routings....all with no real sucess. The problem, I think, lies with the fact that the right side cable makes a 90 deg bend as it comes out of the splitter and then another 90 deg bend at the carb. Getting frustrated with this. On your carb hose.....Dunno specifics on the RD07 but normally CV type carbs will have one vent hose run open to the atmosphere. This hose neutralizes the pressure either on top of or under the diaphragm (depending on how the carbs lift their slides). You want to run this hose to atmosphere NOT into the air box since pressures change here alot and also NOT out into an open air stream. If the air blows across this hose (like blowing over the end of a soda straw) the pressure drops and your slides do funny things. Somewhere under the seat and along the frame tube seems to work best. Again, this is general since I've never had an RD07 apart. If you ride in dusty conditions or if your a chronic worrier like me, put a small foam end filter on the line. K&N makes a neat line filter for vent lines also. |
08-30-2010, 07:49 PM
#7618 | |
I'll try routing the breather tube tomorrow as suggested by you and post results. Cheers!
08-30-2010, 11:01 PM
#7619 | |
Desktop Adventurer.
Oddometer: 1,113
Is it normal to have a slight popping when decenting a hill in first or second gear ? ( engine braking)
08-31-2010, 04:00 AM
#7620 | |
Africa Twiner
Riding to the sunset... on my Africa Twin... http://i95.photobucket.com/albums/l1...ar/sigATCP.gif |
