Old 09-07-2010, 08:25 AM   #7651
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I couldn't attach the pic so here's the link to it.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 09-07-2010, 08:43 AM   #7652
Menasco Pirate
Menasco Pirate's Avatar
Oddometer: 349
Nice looking, who makes it and where to get?
Steve
XLV750, RTL250S, 1989 XL600V, 1990 XL600V Transalps Red and Moonstone, 1992 XL600V Green, 1993 CRM250R, 1994 XRV750 Africa Twin
2009 FE390 tagged, 2011 FE450 tagged, 2011 FE570S super motard, 2011 FE570S
Menasco Pirate is offline   Reply With Quote
Old 09-07-2010, 08:59 AM   #7653
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Steve
Pingel does I think and any shop can order it, if not in stock.
Jim Rowley
Black Forest, CO
Old 09-07-2010, 09:14 AM   #7654
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,105
I'll jump in on your order, Steve.......since you'll be buying in bulk.
Ladder106 is offline   Reply With Quote
Old 09-07-2010, 09:57 AM   #7655
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I actually have a card full of the stock filters
Jim Rowley
Black Forest, CO
Old 09-07-2010, 11:30 AM   #7656
*thomas*
*thomas*
*thomas*'s Avatar
Oddometer: 170
Hi,
anyone has an idea what kind of fuel tank this is?
http://stormforce8.smugmug.com/Motor...19216945_xApkq
*thomas* is offline   Reply With Quote
Old 09-07-2010, 11:57 AM   #7657
Rookie_Rider
Oddometer: 49
Rookie_Rider
Hello fellow AT riders
I would just like to introduce myself and thank you for all the great posts and eyecandy in this thread
My name is Daniel, 28 years old and I live in Sweden. I just bought my first bike on Saturday. I have ridden motocross back in the late 1990's just messing around, but just now started to take driving lessons to get my license. For those of you who like to read about trips and see lots of pictures, have a look at my road trip "diary" from last summer, though be warned, I did drive my jeep and not a bike!
Well enough boring trivia about me and on to the bike.
I think I have found a gem. I first went to look at a pretty old Honda Dominator, but it was tiny, sounded boring, and had an oil leak. So back on the hunt for another bike and by chance I found it:
An Africa Twin from 2002, with less than 3000miles on the odometer. Yes you read it correctly! 4680km! It looks like it has just now left the Honda factory (if it wasn't for a LITTLE oxidation on the bare aluminum parts, I guess that can happen if it just sits there for 8 years)
I just took a few pics of it when I bought it and I have yet to take it home.
So here it is:
Rookie_Rider is offline   Reply With Quote
Old 09-07-2010, 12:11 PM   #7658
Gerd
Oddometer: 46
Thumb
Originally Posted by Rookie_Rider
Sexiest motorcycle ever made... this color scheme is the best, in my opinion.
'10 Honda NX 400
'08 Honda SDH 125 (sold)
Gerd is offline   Reply With Quote
Old 09-07-2010, 02:48 PM   #7659
longuito
EcuaItalian on an RD07A
longuito's Avatar
Oddometer: 69
Originally Posted by Ladder106
Here are my suspects listed in order or priority.
1.
Main jet is too small. ...Drilling out the carb slide bleed holes is just designed to get the slides up faster. This will likely make your symptoms worse if mains aren't changed.
Hi Ladder. I'm always interested in reading what you ahev to say about the carbs. I'd like to know a little bit more about these "carb slide bleed holes". Where are they? (pointing to them on a microfiche would be the best - I could send you one via PM is necessary). What are the desired effects of this modification? Thanks again,
G. Luigi Rota
ATIC# 1977
longuito is offline   Reply With Quote
Old 09-07-2010, 05:01 PM   #7660
Squily
Squily
Squily's Avatar
Oddometer: 1,241
1.
Main jet is too small. Your descriptions are good and from what you say, the bikes fueling is fine until you hit the main jet....then it runs lean. It accelerates fine so the diaphragms are most likely OK and you said you just drilled even larger holes in your baffles to make your pipe flow even more. Drilling out the carb slide bleed holes is just designed to get the slides up faster. This will likely make your symptoms worse if mains aren't changed.
2.
Small hole or crack in the slide diaphragm. I know, I said this was not likely but it can be the problem if it is positioned just right so that it opens a hole only when the slide comes up to the very top. Not normally where they crack since you don't ride at full throttle that often but it is possible.
3. Water in the float bowl. It is possible to get water in your fuel even if you fill at good service stations (why do we still call them that if no one there can actually service your machine any more and you spend more time waiting in line behind people buying GROCERIES??) If it's just a bit of water it will sit down at the bottom of the carb and only interfere when fuel starts coming up the main jet. Probably not because this symptom usually starts at 2/3 or greater throttle and not just at WFO. In any case, drain the bowls into a clear container of some sort so any water or debris can be visualized....otherwise you'll never know.
Thanks Ladder. All valid points and I'll investigate.
Squily
Squily is offline   Reply With Quote
Old 09-07-2010, 06:53 PM   #7661
longuito
longuito's Avatar
Oddometer: 69
... I think I have found a gem. I first went to look at a pretty old Honda Dominator, but it was tiny, sounded boring, and had an oil leak. So back on the hunt for another bike and by chance I found it:
Welcome to the group, and congratulations - That is truly an impossible find! Enjoy it to the max!
G. Luigi Rota
ATIC# 1977
Old 09-07-2010, 07:35 PM   #7662
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,633
Sure you did!!!! Beginers luck? Just plenty of those in the euro market...
Welcome to the enlightment!
So here it is:
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 09-07-2010, 07:35 PM   #7663
locorider
locorider's Avatar
Oddometer: 2,633
Guys...I have a short ride report here: http://www.advrider.com/forums/showthread.php?t=618089
Carlos locorider
Old 09-07-2010, 07:56 PM   #7664
Negrocow
Oddometer: 5
hello friends! my name is andrew! I'm from Cordoba Argentina, tomorrow if all goes well i´m gonna get my first africa, now I have a transalp 95. I have some photos of the africa from my brother. Good routes!
My brother and me:
some friends
Negrocow is offline   Reply With Quote
Old 09-07-2010, 08:25 PM   #7665
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Welcome Andrew.
Jim Rowley
Black Forest, CO
Times are GMT -7.   It's 11:58 AM.
