Old 04-03-2011, 11:15 AM   #9076
Jerrycotton
Oddometer: 20
Originally Posted by Gian View Post
Ok very interesting! And what's that little grid between the airbox and the tank?
Gian
That' the main air intake now... i modified the air box and made then a scoop in the back side of the fairing to direct air into the box... i should get enough flow through the venting grid and not get any dust or dirt from rear wheel into the box
-Mika
Jerrycotton is offline   Reply With Quote
Old 04-03-2011, 12:15 PM   #9077
Jim Rowley
Now what?
Jim Rowley's Avatar
Oddometer: 2,255
Mika, what an excellent build. Is it due to your long winters or do you just have a lot of time on your hands?
Jim Rowley
Colorado Springs, CO
M. A. P.
Jim Rowley is offline   Reply With Quote
Old 04-03-2011, 12:56 PM   #9078
Jerrycotton
Oddometer: 20
My new AT
Time is very, very limited
But I'm a quick builder and it took about 16 months to make this... most work went to fairing.
Now as this is pretty much finished - except suspension tuning - I need to start to look for a new project!
-Mika
Old 04-03-2011, 01:07 PM   #9079
621andy
Location: Turkey, Myanmar, or sometimes at home in Germany!
Oddometer: 121
Been lurking for some time but thought it was time to post my humble offering
A '93 RD07 with 43000km on it...currently in Turkey, but based in Germany.
621andy is offline   Reply With Quote
Old 04-03-2011, 01:13 PM   #9080
ray3656
Oddometer: 48
Originally Posted by Jerrycotton View Post
Yes, I rebuilt all wiring by using motogadgets M-unit, Ignitech's ignition and Bussmann's integrated relay/fuse box
Ignitech's unit is really nice! everything is configurable with computer and I can now use either RD04 carbs without TPS or RD07 with TPS just by enabling/disabling TPS in the unit.
Another practical detail is that the unit runs the fuel pump before motor starts so even if gas has evaporated from the carbs, they are filled before starting.
-Mika
I fitted an ignitech to an XLV 750R.. been very impressed with it...
have you also relocated the battery to the front of the bash plate too?
Great build....
ray3656 is offline   Reply With Quote
Old 04-03-2011, 02:22 PM   #9081
Jerrycotton
Oddometer: 20
My new AT
Yes i have. As I'm using a WP shock from 640ktm the old battery tray had to be cut off.
-Mika
Old 04-03-2011, 02:43 PM   #9082
Belgian Waffles
Oddometer: 795
Thank you! So after searching for these on the internet it seems they are just standard bearings that I can find almost anywhere for around $2 - $10. Does that sound right? I don't need to find any that are specifically rated for the weight or speed of a motorcycle or anything?
Originally Posted by A-Wind View Post
You need
2x 6203 for the wheel and
1x 6204 for the rear sprocket.
I found this info on www.AfricaTwin.de
You can also read more about it in English on ATiC http://www.atic.org/faq/bearings.php
Something like this comes also pretty handy:
http://www.thisoldtractor.com/gtbender/bearing.htm
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying.
Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials
Past: 1999 KLR 650, 1990 Tengai 650
Belgian Waffles is offline   Reply With Quote
Old 04-03-2011, 02:48 PM   #9083
Jim Rowley
Now what?
Jim Rowley's Avatar
Oddometer: 2,255
You may need new seals too. Parle a ton père. Je l'ai expliqué par facebook.
Jim Rowley
M. A. P.
Old 04-03-2011, 04:58 PM   #9084
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,268
Uhmmm....how about mass production (or at least 10 copies or so..side tank first, fairing next)...
Ladder106 is offline   Reply With Quote
Old 04-03-2011, 05:47 PM   #9085
Belgian Waffles
Oddometer: 795
Merci merci!
Old 04-03-2011, 06:53 PM   #9086
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 522
I would go with some good brand like SKF and that's all. ATiC has the right extensions for you.
A-Wind is offline   Reply With Quote
Old 04-04-2011, 01:14 AM   #9087
diskow
diskow's Avatar
Oddometer: 177
There is a possibility to make your Ohlins Longer.
Just for info if anyone is interested, here are some ideas how i did.
I made it with longer piston rod (strut) on my Ohlins. I think there are three option of the strut length. I have chosen 15 mm which gave me about 45mm at the back. After installing the longer rod you have to place preload 15mm lower.
It gave me:
- more ground clearance
- higher seat position
- Longer spring travel
Here is my new "longer" shock, compared with the original strut.
There are other possibilities to lengthen your shock, for example with longer tail shown here in the picture.
Of course if you make more ground clearance you have to lengthen your side stand, I did one "thin rostfrei" version with my local mechanic. I hope it will last for some time. (on the picture not finished yet)
And this is how she looks like now with longer shock at the back:
Now after I raised my bike with longer forks and longer shock I am selling Complete African Queens Underbody-heightening Kit on flea bay: check out item: 130502204256
diskow is offline   Reply With Quote
Old 04-04-2011, 05:41 AM   #9088
Gian
dreamer
Gian's Avatar
Oddometer: 645
-Mika
always more interasting! Owning a RD03 I'm not familiar with RD04, so where actually are the CDI and regulator?
Gian is offline   Reply With Quote
Old 04-04-2011, 06:08 AM   #9089
Jerrycotton
Oddometer: 20
My new AT
CDI is in the same place as in normal RD04: in the back of the air box (the CDI is visible in the picture: a black box :))
Regulator obviously is where the battery used to be!
Old 04-04-2011, 06:29 AM   #9090
ray3656
Oddometer: 48
ha notice the 9 pin computer socket.. this is for the 'new' ignitech unit that replaces the CDIs..
given how cheap this unit is I dont understand why folk will pay 200-500 Euros for second hand Ebay stuff.. As said I replaced the two CDIs on an XLV with one of these...
Mika this is a superb remodeling of this Bike.. well done .. more inpressed every time I see more of it
Times are GMT -7.   It's 09:02 PM.
