Old 04-25-2011, 08:51 PM   #9331
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
He makes awesome camping coffee too.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 04-25-2011, 08:56 PM   #9332
GSPD750
GSPD750's Avatar
Oddometer: 1,455
Almost got it dirty here. Somewhere off the AK hiway.
Actually, the dirtiest my AT has ever been I think was at the NAATS in Oregon.
It was sooo muddy and sooo slick that I have no pictures as I couldn't hold the camera steady.
An hour later it was sparkling again from all the rain on the slab.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 04-25-2011, 09:04 PM   #9333
GSPD750
GSPD750's Avatar
Oddometer: 1,455
Hello Jim...when I'm solo it's the espresso maker.
Yeah...that 12 cupper pot was certainly the way to go with a group...eh.
Old 04-25-2011, 09:04 PM   #9334
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,017
Muddy....yeah
Slick....not so much
It's all about tire choice. This was the BEST day of the ride. Chris agrees. We were both on knobbies.....hmmmmmmmmmm.
..........but the morning coffee was well appreciated!
Are we getting nostalgic here? I guess we should do this again soon. eh?
Ladder106 screwed with this post 04-25-2011 at 09:17 PM
Ladder106 is online now   Reply With Quote
Old 04-25-2011, 09:18 PM   #9335
GSPD750
GSPD750's Avatar
Oddometer: 1,455
Originally Posted by Ladder106 View Post
Muddy....yeah
Good times.
Old 04-26-2011, 02:35 PM   #9336
Twiniver
Twiniver's Avatar
Oddometer: 64
Originally Posted by GSPD750 View Post
No, the gap need not be closed. The front axle is torqued to 47 ft lbs..effin tight. Only after that tq is achieved do you tq the axle clamp nuts...just snug.
Now...I betcha never seen the front spocket area this clean.
This was just after the cases were split for an output shaft bearing replacement. Yeah...chemicals can do wonders.
How on earth did you get it that clean?
Twiniver is offline   Reply With Quote
Old 04-26-2011, 08:07 PM   #9337
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,252
Brake pads
Ok guys I am in the prosess of going through the front brakes as they are terrible. When I got the bike the po had a full set of front and back pads with the bike, the fronts are not the right pads but the rear looks correct haven't pulled it yet. Take a look and let me know what you guys think. I have the RD07 original pads with the new still in the sealed bags.
and the rear
Reidy008 is offline   Reply With Quote
Old 04-26-2011, 09:56 PM   #9338
Reidy008
Reidy008's Avatar
Oddometer: 2,252
Another question
When I apply the brake lever with out the pads in there are two pistons and only one actually pushes out. Is this normal to you guys? Is only one coming out because there is no pressure on it to force the fluid to push out the second? Should both come out equally? Feed back much appreciated
Old 04-26-2011, 10:01 PM   #9339
Joz
What could go wrong?
Joz's Avatar
Oddometer: 1,884
Well, I just put a set of FA140's on the rear of my 2000 RD07A so I'd venture to guess that those are right.
I'd also guess that the FA121's are correct for the front from my high-tech research method: http://cgi.ebay.co.uk/HONDA-XRV750-A...item53e27f0a76
Africa Twin, CRM250-AR, TLM220R, CT90, SY250
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Joz is offline   Reply With Quote
Old 04-26-2011, 10:08 PM   #9340
Reidy008
Reidy008's Avatar
Oddometer: 2,252
Pistons and pads
The pads in the ebay listing do not look like the ones I have at all? Different hole patterns completely however the pads do look like what I need the ones I have will no way fit.
As far as the pistons go the pistons are on the same side next to each other. I understand the pressure will apply both pads but I would have thought both pistons would push out together applying even pressure along the entire pad?
Old 04-27-2011, 01:50 AM   #9341
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 363
I think if you're servicing your brakes, you'd better go the all the way and do the callipers as well, i.e. remove the pistons and old seals, clean the callipers really well and replace with new seals and/or pistons. As some other inmates here did, you could even get your callipers powder-coated for a shiny like-new look. :)
Also, the brake fluid replacement is something that should be done every 2 years as this type of fluid absorbs moisture and negatively affects brake power. You won't believe the braking power after a full service to the brakes...
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin is offline   Reply With Quote
Old 04-27-2011, 12:07 PM   #9342
Reidy008
Reidy008's Avatar
Oddometer: 2,252
Agree
I agree with that statement and my intention is to do just that. I am not sure how quickly I can shut down and not ride the bike but if it needs it now I will bite the bullet and just ride some of my other bikes,,, but man I like this one.
Old 04-27-2011, 02:30 PM   #9343
4ad
ochlacrat
4ad's Avatar
Oddometer: 2,727
I would'nt worry too much about this unless the tight piston is siezed in the bore. The piston with the least resistance will move first when there is no "load" on them.
This was all fun banter until 4ad posted a pic of a rapist/murderer.- GP640
4ad is offline   Reply With Quote
Old 04-27-2011, 08:13 PM   #9344
Joz
Joz's Avatar
Oddometer: 1,884
Yeah. Maybe hold the moving piston with a C clamp or something and see if the other piston moves.
Old 04-27-2011, 09:34 PM   #9345
Reidy008
Reidy008's Avatar
Oddometer: 2,252
Front pads
and the rear
So it would now seem like I have a set of brake pads that don't work for my bike. Anyone know if they are good for another year or model looking at them?
Times are GMT -7.   It's 07:53 AM.
