05-25-2011, 11:36 AM
#9571 | |
Oddometer: 1,216
Yeah...I think it's time I just sell my new spare SH and go with the Mosfet FH and do the upgrade. It's explained pretty good at the following link. http://www.triumphrat.net/speed-triple-forum/104504-charging-system-diagnostics-rectifier-regulator-upgrade.html
1999 XRV 750 Africa Twin 1996 XL 600v Transalp "Almost no other bike has the road presence of the Africa Twin and cars seem to melt out of its way, once they see the angry glare of its lights in their mirrors." ... |
05-25-2011, 11:56 AM
#9572 | |
Oddometer: 1,216
http://www.easternbeaver.com/Main/Elec__Products/Connectors/R_R_Connectors/body_r_r_connectors.html
05-25-2011, 12:49 PM
#9573 |
Oddometer: 41
Thanks for all the great offers!
Yesterday we managed to get 3 sets of sprockets (206 USD), JT for the Africa Twin shipped to Arizona. (Moto Chains was the company name) As I want to swap the chain in Phoenix (Az) or near there (need someone with tools to link the new chain), does anyone recommend a bikeshop there which will probably have the chain (525-124) on stock? Other option: anyone living around there who can help me out? Then I just order the chain and take it with me! Always the best to do it yourself and meet some people. other question: how difficult would it be to get tyres in Mexico? Daandus screwed with this post 05-25-2011 at 01:02 PM |
05-26-2011, 06:21 AM
#9574 |
Oddometer: 81
RD03 Engine color codes
Does anybody know which is the color code for the RD03 engine (the one in greenish-brown-bronze color), or how to get it?
Thank you MAZ p.s. this is my last step and obstacle for the total restoration of the XRV650 |
05-26-2011, 09:25 AM
#9575 |
Africa Twiner
You mean the colour code for the engine cases?
Riding to the sunset... on my Africa Twin... http://i95.photobucket.com/albums/l1...ar/sigATCP.gif |
05-26-2011, 09:36 AM
#9576 |
Oddometer: 81
05-27-2011, 11:30 AM
#9577 | |
Oddometer: 25
Hi
I just put in the FH008 this winter. A friend of mine did it too. We both got 14.5 v with the engine running, and it works just fine. The original RR was still ok, we did it just to upgrade because som many recommended it. The best thing though, was that we found that the big connector, connecting the RR to the system, was corroded. One of the wires on my friends bike was almost melted off because of bad connection. Wires were cut and fixed with proper connectors to avoid melting or even fire.. So even if you dont change the RR, check the wiring and connectors. It might need some cleaning ... ;-) Best Osmund Quote:
05-28-2011, 09:10 AM
#9578 |
Oddometer: 89
Hi Osmund.
Can you tell me where did you buy it from? ![]() ![]() Cheers Makis
Αν θες τα όνειρά σου να βγουν αληθινά, μην κοιμάσαι. ![]() If you want to make your dreams true, do not sleep. |
05-28-2011, 01:57 PM
#9579 |
rohirim
Oddometer: 7
It might need some cleaning ... ;-) Could you upload any photos from the work that you did? Thank's. |
05-28-2011, 02:21 PM
#9580 | |
Oddometer: 1,216
The FH012 is readily available new on ebay and has the same footprint as the FH008...difference being is the FH012 puts out 50 amps (a bit of overkill) as opposed to 35 amps on the FH008. Both will work.
05-28-2011, 03:42 PM
#9581 | |
Oddometer: 48
the 12 will only put out what is put in, and there is no way the Africa Twin gen can put put 50 amps.. ( that would require a 14.5v x 50 Amp generator i.e. 725 watt the Africa Twin gen is 300+, so the 12 is well in spec and low stressed and will run cooler I fitted a 10 which will cope with 100 amps!! it runs real cool , has the same foot print as the 8.... 12.. and the original R?R but is very very tall.. folk go for the 12 , because as you say its used in a lot of other bikes and you can pick them up on ebay ( I got the 10 there , thought it was a 12.. :-) as stated it a good mod.. but its still a shunt regulator.. so it shunts ( short circuits ) what it does not need, but as the MOS FET has a very low resistance there is less heat produced in the R/R.. however the generator gets some additional heat .. search forums for R1 regulator mod.. you will find that it,s not only Africa Twins that get this treatment :-) |
05-28-2011, 05:46 PM
#9582 | |
Oddometer: 1,216
How did your FH0010 fit on your AT with the extra length?
05-29-2011, 03:15 AM
#9583 |
Oddometer: 48
I had to relocate it to the side :-) its huge but works. I will not fit in the original location , but the 8 12 s will, its well worth getting the original connectors too..
I have an RD03 with an 04 Engine, so retained the coolant bottle where the oil cooler is on the 04/07s it has the RD04 rear & plastics too, so the FH010 is where the 04/07 coolant bottles would be.. may get the 12 and return it to its original location as it gets quite dirty :-) ray3656 screwed with this post 05-29-2011 at 08:38 AM |
05-29-2011, 05:24 AM
#9584 |
Oddometer: 7
Some pictures from my traveling around Greece
05-29-2011, 09:57 AM
#9585 |
Oddometer: 41
Greece!
nice pictures! pou einai? oi spilies? peloponisos...?
"Every day, do one thing that scares you" |
