Old 08-06-2011, 09:07 AM   #9916
GSPD750
GSPD750's Avatar
Oddometer: 1,454
Originally Posted by Rookie_Rider View Post
I have changed the stator now, it was no problem at all. And I found the culprit. A small metal "thing", that looks like a needle from a needle bearing, but is now very rounded and unidentifiable. It had wedged between the stator coils or whatever they are called, and had caused some mayhem to some of the coils. Probably just shorting out the magnets, not the actual coil wiring. I have no idea where this thing came from but it is out now.
Where their has been one needle bearing that has come apart....you can usually count on more to fillow. Don't run your engine until you find the culprit or you will only cause more damage. You may want to remove your oil filter and cut it open to check for metal.
Also check the inside magnet part of the rotor for metal. Removing the rotor bolt is another story as it is a L/H thread.
The rotor sits on a needle/roller bearing on the crankshaft and if one of those got pounded out I would assume you would also have some vibration.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 08-06-2011, 09:38 AM   #9917
Rookie_Rider
Oddometer: 49
I will remove the cover and have a look tomorrow.
Here are pictures of the small object. it is very small, the pen next to it, the tip is 0.3mm so the object is about 4mm long and 2mm thick.
The second picture shows where this object was wedged in. If it caused the rotating drum with the magnets to be out of round, then wouldn't it have rubbed against the other parts of the old stator? It looks perfect except what you see in the picture.
Rookie_Rider is offline   Reply With Quote
Old 08-06-2011, 03:09 PM   #9918
GSPD750
GSPD750's Avatar
Oddometer: 1,454
Somebody you know missing a silver tooth. What the heck is that.
Old 08-06-2011, 03:50 PM   #9919
Kamuk
lost in the ozone again
Oddometer: 117
Ufm
I question if that is a needle bearing... though chewed up as it is... ?
By my experience needle bearings, being of somewhat tensile steel, will shatter upon break up under duress before getting so worn in such a way.
From the photo it does not really look cylindrical, but oval shaped; and maybe of a more malleable metal that what would be used in a bearing... ?
The photo of the stator has much better lighting and definition however.
A "hammer test" on the bit could be in order?
And certainly - unidentified flying material (UFM) inside the cases is something to define before crank up...
Kamuk is offline   Reply With Quote
Old 08-06-2011, 04:17 PM   #9920
Game over
Haha
Game over's Avatar
Oddometer: 137
Is it a chunk of solder?
Game over is offline   Reply With Quote
Old 08-06-2011, 04:22 PM   #9921
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,002
The starter gears are also located under that cover.
Maybe have a look at all the starter gear teeth? If one broke off it might easily be attracted to that nice big magnet.
Next would be one of the small starter gear spague clutch bits - like needle bearings but more "dog-bone" shaped. You'll have to pull the rotor to have a look at this but I think it's worth the trouble. Maybe that would account for the other ugly noises you're hearing from the left hand side.
Just trying to think of stuff short of engine removal and case splitting.
Ladder106 screwed with this post 08-06-2011 at 04:30 PM
Ladder106 is offline   Reply With Quote
Old 08-06-2011, 05:32 PM   #9922
Rookie_Rider
Oddometer: 49
Yeah, I don't think it is from a needle bearing either, because I think I would have noticed if a bearing broke that much.
Also, when I was riding it back with a new battery (after my battery ran out of juice because of the stator not working hence the battery wouldn't charge) it did not make any strange noises. The noises appeared after I changed the stator. So I will check tomorrow and see why it is making these noises.
The new stator was 5mm thinner than the original one. So I had to find 5mm shorter bolts for it. But that shouldn't be a problem, causing the noises.
Old 08-07-2011, 04:21 AM   #9923
KT1
RD07A Adventure
KT1's Avatar
Oddometer: 208
Originally Posted by Reidy008 View Post
Is the grass growing up out of the belly pan?
Yes, new life is born...
Africa Twin Owner's Club Hungary
Honda MTX-125 -1983
Honda XL600LM -1987
Honda XRV-750 -1998
www.balkanbistro.hu
KT1 is offline   Reply With Quote
Old 08-07-2011, 10:09 AM   #9924
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,238
Nuetral Light
Can some one please tell me when the switch is on the motor for the neatral light? I can trace it back back I know some one can save me some time. My light isn't working and I would like to correct that... and I have checked the bulb.
Reidy008 is offline   Reply With Quote
Old 08-07-2011, 11:36 AM   #9925
XRGRIFF
Oddometer: 38
I would agree, starter clutch and would need to make sure none of the other bits have gone walkabout, unless you are very lucky its an engine out job.
Griff
XRGRIFF is offline   Reply With Quote
Old 08-07-2011, 12:57 PM   #9926
Ladder106
Ladder106's Avatar
Oddometer: 5,002
Neutral light switch is under a black rubber cover at about the 10 o'clock position using the gear shift shaft as the center point. It's usually covered with dirt and chain lube. Remove the countershaft sprocket cover and take a look.
Sometimes it's just the wire that had come off the switch and not the switch itself.
This is from the Transalp engine but the AT should be almost identical here.
Old 08-07-2011, 09:11 PM   #9927
Reidy008
Reidy008's Avatar
Oddometer: 2,238
Cheers Mate
Thanks.
Old 08-08-2011, 03:48 AM   #9928
Analogo
As if.
Analogo's Avatar
Oddometer: 4
Talking XRV 750 adventure | project
Hi there fellow riders. Regular visitor on ADV forums, but never posted a pic of my bike before. So here it is.
Some upgrades done this year.
- OHLINS rear spring
- WIRTH progressive springs in front forks
- refurbished rims and new spokes
- custom license plate holder
- customized front fender and fork protection
- new XRV logo on side panels / vector files available ;)
IMG_0850
IMG_0851
IMG_0852
IMG_0854
Keep on Truckin' !
Analogo is offline   Reply With Quote
Old 08-08-2011, 12:03 PM   #9929
Ladder106
Ladder106's Avatar
Oddometer: 5,002
Actually more like the 7 o'clock position....I was going from memory (which apparently is not as good as I thought)
Welcome Analogo,
Nice first post. Where are you in the world?
Old 08-08-2011, 12:56 PM   #9930
Analogo
As if.
Analogo's Avatar
Oddometer: 4
Cool2
Welcome Analogo,
Thank You...;)
I'm located in Slovenia. Small dot in the world map ;)
Keep on Truckin' !
Times are GMT -7.   It's 11:46 PM.
