Old 09-12-2011, 10:00 AM   #10156
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 472
Oh boy...look what I found for my RD07a rebuild!!!!
04 ktm front end for the Africa Twin
Brakes and fender for the Africa twin
Came from a 2004 KTM 950 Adventure. Stormforce8 is already connecting me with all the info and parts I need as he has done this on his bike and others.
My rebuild just got interesting!
00 Honda Africa Twin XRV750 RD07a -- Rebuild Story
89 Honda Africa Twin XRV650 RD03 -- Its here!! -- Restoration
69 Honda CB750 Sandcast - Restoring Now
ujeni is offline   Reply With Quote
Old 09-12-2011, 08:58 PM   #10157
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,197
Speedo clasp
Originally Posted by GSPD750 View Post
Cable comes down through the center of the plastic spash gaurd between the forks and then to the outside at the top of the fork protector....and then inside where it goes through the special speedo clamp that has a cutout for the cable. Special speedo clamp is item #2...and not a hose clamp as you mentioned.
Has anyone got an actual pic of item #2 I cant find a source and want to see if I can fab this little bracket. Cheers
Reidy008 is offline   Reply With Quote
Old 09-13-2011, 01:28 AM   #10158
Hectoe
Oddometer: 25
Originally Posted by Antti View Post
At Finland I think
That's correct.
By the way, here is another video of mine for the Africa Twiners in this thread.
Hectoe is offline   Reply With Quote
Old 09-13-2011, 01:59 AM   #10159
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 363
Hi Ujeni, on a side note, what speaker cab is that? Is it a vintage Marshall?
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin is offline   Reply With Quote
Old 09-13-2011, 06:27 AM   #10160
john_aero
john_aero's Avatar
Oddometer: 1,173
beautiful forks there lad.
where did you find them
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 09-13-2011, 11:00 AM   #10161
Isoiivari
Oddometer: 15
Originally Posted by Hectoe View Post
That's correct.
Did you put E10 in your AT???
Isoiivari is offline   Reply With Quote
Old 09-13-2011, 08:36 PM   #10162
alainmax
ca vaut le detour !!
alainmax's Avatar
Oddometer: 618
wheel bearings
Hello all,
looks like my rear wheel bearing set got tired after Alaska/ Yukon ride...
Now for this RD07, are the NAPA ( SKF 6204-2ZJ) ok to use? THey are double sealed . Advantage of double seal vs single? The dust /oil/grease seal would be the main barrier anyway, no?
Any experience with napa bearings? Or better to go with OEM...
they are the same set for an RD04 , right? As a matter of fact, aren't they the same for the transalp as well?
As always thank you
04 GS 1150
93 Africa twin RD07
alainmax is offline   Reply With Quote
Old 09-13-2011, 08:53 PM   #10163
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Originally Posted by alainmax View Post
Hello all,
As always thank you
Salut Alain. Not sure if they're the same for all three but since you have all three there in your garage, you tell us. Double sealed would be my choice. My method to replace them would be to extract the bearings, measure with calipers and replace with same size. I'm sure you have a shop dedicated to bearings of all types there. I have one here. The key is to have the right tool, a quality bearing removal tool, not a screwdriver. I have this setup.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 09-13-2011, 10:09 PM   #10164
Hectoe
Oddometer: 25
That was Shell V-Power 99 E5.
Old 09-13-2011, 10:40 PM   #10165
Squily
Squily
Squily's Avatar
Oddometer: 1,223
Where you get that from Jim?
Squily
Squily is offline   Reply With Quote
Old 09-14-2011, 08:25 AM   #10166
Isoiivari
Oddometer: 15
I wasn't sure so had to ask
Nice riding and nice clip.
Old 09-14-2011, 09:23 AM   #10167
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,984
Jim,
I'm pretty good with tools but haven't ever seen the bearing removal stuff.
How does is work? Does the tapered rod get driven into the slot?
My method involves heat, brute force and a bit of ignorance.
Ladder106 is offline   Reply With Quote
Old 09-14-2011, 10:46 AM   #10168
GSPD750
GSPD750's Avatar
Oddometer: 1,447
Hello all,
As always thank you
Hello Alain. SKF is a quality bearing...one of the best, but I'm not so sure about that part # you posted. I would use the #'s is the following link.
http://www.atic.org/faq/bearings.php
ModelFrontRear 'left'Rear 'right'Rear 'sprocket'
RD036202-2RS1/C3 (2x)6203-2RS1/C36203-2RS1/C36204-2RS1/C3
RD04/RD076203-2RS1/C3 (2x)6303-2RS1/C36203-2RS1/C36204-2RS1/C3
You need one each of the following 6303-2RS1/C3, 6203-2RS1/C3, 6204-2RS1/C3. One of those is for the sprocket which you might as well do while you are in there.
Go to any Bearing Supply Store in your yellow pages and they will have those bearings. SKF is not necessary however it is recommended as with Koyo, NSK or any of those Japanese made berarings. Avoid Chinese made.
An installation tip is to heat the wheel hub and freeze the bearing so that it will drop in easy. For removel I have used a blind bearing puller that has a slide hammer setup...a bit different than Jim's but the same principle.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 09-14-2011, 11:03 AM   #10169
alainmax
alainmax's Avatar
Oddometer: 618
Jim, Wayne,
thank you both.
yes I'm planning on replacing the sprocket one as well. i may even "freshen up" the front wheel with a new set.....and steering!
Still need to order the seals.
Nice tools, I have used the "Ray" method in the past
you guys rock
04 GS 1150
93 Africa twin RD07
Old 09-14-2011, 01:36 PM   #10170
Reidy008
Reidy008's Avatar
Oddometer: 2,197
Come on guys can some one take a quick pic of the speedo cable bracket on the lower fork leg for me please.
Times are GMT -7.   It's 01:20 AM.
