Old 09-14-2011, 03:18 PM   #10171
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,957
Here's the Afric-Alp version on NX fork legs but I gotta think the AT bit would be identical..
Apologies, I figgured the guys with the real ATs would want to share
Ladder106 is offline   Reply With Quote
Old 09-14-2011, 03:20 PM   #10172
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,144
Great
Thanks mate, that will be an easy fab from a hose clamp. Appreciate the pics.
I was trying to figure out if the nipple or casting on the forks was integreated into this or not.
Reidy008 is offline   Reply With Quote
Old 09-14-2011, 03:34 PM   #10173
GSPD750
GSPD750's Avatar
Oddometer: 1,439
Yes, the casting on the fork is part of keeping it secure. Ray beat me to it but heres some pics anyway. It appears much the same as the alp.
Why can't you just order one from the UK?
blurry front view.
viewed from the rear
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 09-14-2011, 04:43 PM   #10174
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 469
Originally Posted by Africa_Twin View Post
Hi Ujeni, on a side note, what speaker cab is that? Is it a vintage Marshall?
1965 Fender Super Reverb.
00 Honda Africa Twin XRV750 RD07a -- Rebuild Story
89 Honda Africa Twin XRV650 RD03 -- Its here!! -- Restoration
69 Honda CB750 Sandcast - Restoring Now
ujeni is offline   Reply With Quote
Old 09-14-2011, 04:46 PM   #10175
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 469
Originally Posted by john_aero View Post
beautiful forks there lad.
where did you find them
I put an ad here on advrider.com about six months ago. Never got anything off it until last weekend. Turns out there was a fellow only 20 miles from me with the forks, triple trees, brakes and fender. He was planning on putting them on his Cagiva, but decided to keep it stock. Only wanted what he paid for them.
Looking forward to riding with them, I hear they are some of the best forks out there!
Old 09-14-2011, 10:18 PM   #10176
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Originally Posted by Squily View Post
Where you get that from Jim?
K&L Supply. It's a motorcycle parts/tool distributor.
Ray, yes you insert the right size tool into the bearing, put the drift/wedge through the hub and into the slot. You then expand the drift/wedge by hammering it into the tool while it's on the floor or workbench and finally drive the bearing out. Simple yet effective.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 09-14-2011, 11:43 PM   #10177
Reidy008
Reidy008's Avatar
Oddometer: 2,144
blurry front view.
I looked on wemoto and Dave's and I could not find the part. Probably more my lack of ability than not there. I should be able to fab a little something pretty easy. Thanks guys.
Old 09-15-2011, 01:49 AM   #10178
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,021
18" rear wheel ""
OK, seems both my rear wheels have terminal Gold Honda DID Rot so Im up for new rims & spokes for both Not to bad I guess as they are 21 years old.
So this is the chance to swap to 18" rears , what say the collective ??, plusses / minuses , if youve done it what gearing did you change to etc
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 09-15-2011, 04:49 AM   #10179
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 363
Huuummm, tasty!
I have a '63 AC30 Top Boost converted and a '76 4x12 and '68 8x10, both marshall
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin is offline   Reply With Quote
Old 09-15-2011, 05:12 AM   #10180
diskow
diskow's Avatar
Oddometer: 219
1.) I strongly suggest you use 18'' with 2.5 wide and not 3.0 as i did. In this case you can go with Excel.
You will spare on the actual weight But most important if you will do some offroad with low pressure tires as i do alot, the edges of your rim will be safer with 2.5 wide.
2.) Consider changes with 18'':
- much higher bike, specially with tires like M. Desert because of actual 18'' rim
- you will have to extend side stand
- gear ratio Mixed again (nobody warned me about this one) well i should think on this before. also chain links could be different.
- tire is little closer to the frame on the front, so you want to put it more to the back, (because of that bike is higher again at the back)
3.) Conclusion:
I took Morad wheel 3.00 and its very robust and strong build. But if I would do it again i would use Excel 2.5.
Just to mention my gear ratios on 17'' compared to new 18'':
Offroad 16/48 (124 links) on 17'' is almost the same as 16/51 on 18'' (126 links)
Travel 17/43 (124 links) on 17'' is almost the same as 17/46 on 18'' (126 links)
Plusses:
- Michelin Desert
- slight better offroad stability over holes
- much Better hill climbing
- even more ground clearance (optional, but good for me 6.5 feet) :)
Minuses:
- slight more weight with larger gearing etc...
- can not fit Mitas C02 anymore :(
I know this will help ;)
diskow screwed with this post 09-15-2011 at 05:21 AM
diskow is offline   Reply With Quote
Old 09-15-2011, 05:56 AM   #10181
diskow
diskow's Avatar
Oddometer: 219
New report / lots of AT action
I havent been active for some time:
Here is my Ride report from my latest enduro trip with friends in MNE.
Its written in Serbo-Croatian - But the pictures can tell the story
http://www.nolimitbikers.com/forum/viewtopic.php?f=16&t=4046 (AT comes in action on page 2)
Enjoy the beauty of Monte Negro mountains.
Just a teaser of report:
AND:
In case you missed my AT action older trips with RReports:
Island Rab
http://www.advrider.com/forums/showthread.php?p=15590341#post15590341
Enduromania
http://www.advrider.com/forums/showthread.php?t=618140
Old 09-15-2011, 03:07 PM   #10182
tserts
Praise San Irritrack
tserts's Avatar
Oddometer: 2,685
Super je! Jako lepo!
BMW F 800 GS 2010 - My Brunhilde
New toys to brake!
Road Rush (Romania, Serbia)
Peloponnese Peninsula on two Africa Twins
9 countries in 15 days - Tserts.eu
tserts is offline   Reply With Quote
Old 09-15-2011, 05:56 PM   #10183
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I had an 18"x2.50" laced on before I even rode the bike when I bought it. I didn't want to hunt for 17" knobbies. Lots of 18" dirt tires though. I even ran 120/90-18 on my R1100GS. Yeah, I converted that one too. I have a 45 tooth sprocket on the AT. I run tires from a 120 to a 140 without any issues.
Jim Rowley
Black Forest, CO
Old 09-16-2011, 10:47 PM   #10184
Reidy008
Reidy008's Avatar
Oddometer: 2,144
Lights
Guys are both lights on when they are in low beam mode or just the left one? I am getting both on high but only one on low? Thanks.
Old 09-16-2011, 11:03 PM   #10185
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 469
German models have only one light on in low and both on in high. Both of my ATs had this behavior. It is a simple matter for bridging between the two lights to convert it back to both lights on in low.
I used the info in this thread to modify mine successfully:
http://www.xrv.org.uk/forums/africa-...eadlights.html
Times are GMT -7.   It's 06:14 AM.
