Old 11-10-2011, 04:39 AM   #10411
MakS
MakS's Avatar
Oddometer: 84
Это абсолютно оригинальная вилка !!
с замененными пружинами !
This is an absolutely original fork!
replaced with springs!
MakS is offline   Reply With Quote
Old 11-10-2011, 04:45 AM   #10412
DoctorAbo
friends call me Mitsulas
DoctorAbo's Avatar
Oddometer: 269
Good ! This thread bacomes again interesting. Gongrats MAKS bro !!You have done a fantastic job on teh bike.
I would suhhest you to make a special thread presenting all teh job on the bike !!!!!!
Riding along, singing a song, side by side, cha cha cha !!! :
DoctorAbo is offline   Reply With Quote
Old 11-10-2011, 04:58 AM   #10413
MakS
MakS's Avatar
Oddometer: 84
Я не так много переделал)))
В перспективе :
Дополнительные топливные баки на хвост.
Заднее колесо на 18 "
Заменя амортизатора.
In the long term:
Additional fuel tanks on its tail.
Rear wheel 18 "
Replacing the shock absorber.
Old 11-10-2011, 04:59 AM   #10414
Heno
Lover Of Perfection
Heno's Avatar
Oddometer: 60
Great Max. I am doing the same. Progressive Hyperpro springs and + 40 mm tuning. My Wilbers rear shock is 10 mm longer than original, which causes 25mm more on the wheel + 18" rear rim, which means aditional 12,5 mm Finally it is 37,5mm on the wheel.
Heno is offline   Reply With Quote
Old 11-10-2011, 05:06 AM   #10415
MakS
MakS's Avatar
Oddometer: 84
Я переделал линк прогресии, укоротил на 10мм. это прибавило 50мм высоты задней подвеске.
I rewrote link progression, shortened by 10mm. it has added 50mm height rear suspension.
От чего ты использовал заднее колесо на 18"???
Какие у негоразмеры ширины обода? 2.15, 2.5 или 3.00
What did you use the rear wheel on 18 "??
What are the dimensions of the width of the rim? 2.15, 2.5 or 3.00
Old 11-10-2011, 05:14 AM   #10416
Heno
Lover Of Perfection
Heno's Avatar
Oddometer: 60
50mm? Too much. No problems with chain tensions?
It is Excel 18x2,50, 32 holes, undrilled.
Old 11-10-2011, 05:32 AM   #10417
MakS
MakS's Avatar
Oddometer: 84
проблем нет ! т.к. подвеска находится в допустимых пределах.
я предпочитаю цепь не сильно натягивать, что бы не порвать на приземлении с неожиданного прамплина.
Короткий линк прогрессии обошелся мне в 4500 руб это 150$. + комплект подшипников ссальников.
no problem! as suspension is within acceptable limits.
I prefer the chain does not stretch much, that would not break on the landing with a sudden jump.
Short link progression cost me 4,500 rubles is $ 150. + Set of bearings, seals.
Колесо ты устанавливал на Трансальп?
У африки надо обод шириой 3.00, в Москве он очень дорогой.
The wheel you installed on Transalp?
In Africa, have a width of 3.00 rim, in Moscow, it is very expensive.
Old 11-10-2011, 06:00 AM   #10418
Heno
Lover Of Perfection
Heno's Avatar
Oddometer: 60
I am just thinking of point, where chain touches the rear frame. There could be a problem with 50mm and more.
Alternative to Excel is Morad rim. On my Transalp I had stock rims.
Old 11-10-2011, 06:39 AM   #10419
MakS
MakS's Avatar
Oddometer: 84
Я планировал поставить ДИД.
За гонку и 5000 км. пока проблем нет.
I had planned to put the DID.
During the race, and 5,000 km. while there is no problem.
Old 11-10-2011, 03:29 PM   #10420
Squily
Squily
Squily's Avatar
Oddometer: 1,224
[QUOTE=MakS;17272956]Short link progression cost me 4,500 rubles is $ 150. + Set of bearings, seals. {/QUOTE]
Maks- at that price: do you want to make some extra ans seel? I'd be interested
Squily
Squily is offline   Reply With Quote
Old 11-10-2011, 05:09 PM   #10421
GSPD750
GSPD750's Avatar
Oddometer: 1,453
Originally Posted by Africa_Twin View Post
WOW!!! Franken-moto!!!
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 11-10-2011, 05:22 PM   #10422
GSPD750
GSPD750's Avatar
Oddometer: 1,453
I find that amazing. Their has to be something said for an Africa Twin right out of the box. Original AT triple clamps apparently do the job just fine from what i see.
Old 11-10-2011, 08:31 PM   #10423
MakS
MakS's Avatar
Oddometer: 84
[QUOTE=Squily;17277147]
Вас интересует укороченный рычаг качалки?
Are you interested in a shorter lever rocking?
Old 11-10-2011, 08:33 PM   #10424
MakS
MakS's Avatar
Oddometer: 84
Originally Posted by GSPD750 View Post
Надо подумать о сборке такогодруга!)))
We need to think about building such a friend!)))
Old 11-10-2011, 11:03 PM   #10425
MakS
MakS's Avatar
Oddometer: 84
Photos of our races.
Times are GMT -7.   It's 12:16 AM.
