Old 11-29-2011, 02:23 AM   #10471
diskow
diskow's Avatar
Oddometer: 177
Heno -
Your rebuild looks awesome. Congratulations.
Some questions goingh through my mind:
- Have you used longer Wilbers (extended strut) or just shorter U bone at the back for more ground clearance?
- I think You ll need Much longer brake cables at the front
- I see you use aftermarket brake disc. No offense but I very doubt they will work as much good as original. Let us know how they work....
- SW motech footpegs look very interesting and nicely strong build (without rubber for my use). Are they lower as original?
- Your extensions for Magura are very high. Try maybe rather not so much long extensions but put them leaned more forward to straighten the angle. Than magura can be straight up with the line of forks.
Let us know
diskow is offline   Reply With Quote
Old 11-29-2011, 02:30 AM   #10472
Heno
Lover Of Perfection
Heno's Avatar
Oddometer: 60
Ze_zaskar...Thank you Here, see the specs.
Front suspension:
  • HYPERPRO Progressive springs
  • 44mm lifting kit
Rear suspension:
  • Custom build, fully tuned WILBERS 641 shock
  • Built accordance to these specs:
    • Honda XRV 750 Africa Twin (RD 07A)
    • Built 1996
    • Bike weight 250kg
    • Driver weight 120kg
    • Occasional passenger weight 70kg
    • Occasional baggage weight 50kg
    • On-Road riding 50% of whole riding time
    • Off-Road riding 50% of whole riding time
    • 10mm longer shock
    • Hydraulic Pre-Load
Heno is offline   Reply With Quote
Old 11-29-2011, 02:42 AM   #10473
Heno
Lover Of Perfection
Heno's Avatar
Oddometer: 60
diskow
  • Wilbers offers up to 20mm shock length change. How they do it? Dont know. U-bone is original.
  • Brake lines gonna be Hel stainless brake lines. Length will be set to actual conditions.
  • Will see ;)
  • Foot pegs are standard height with 15mm possibility of vertical setting, I think.
  • Gonna try this setting, than will see. Thanks ;)
I definitely will.
Old 11-29-2011, 03:43 AM   #10474
Ze_zaskar
Ze_zaskar's Avatar
Oddometer: 304
Amazing how you got so much ground clearance with so little suspension height increase. Ever thought about going the Boano Sachs fork kit route?
And whats the plan for the fairing?
Ze_zaskar is offline   Reply With Quote
Old 11-29-2011, 03:59 AM   #10475
diskow
diskow's Avatar
Oddometer: 177
I have 15mm longer Ohlins than original on my AT.
It gave me around 4cm more at the back.
Old 11-29-2011, 05:14 AM   #10476
Heno
Lover Of Perfection
Heno's Avatar
Oddometer: 60
Ze_zaskar...Boano Sachs fork kit is too expensive. For riding type, I am used to, original fork with prog. springs is faaaar enough Boano fairing? Most ugliest fairing ever. (sorry for those who have it) I am just going to change the angle of original fairing for rallye purposes.
Old 11-29-2011, 05:32 AM   #10477
Joz
What could go wrong?
Joz's Avatar
Oddometer: 1,654
Originally Posted by Heno View Post
That's so pretty how will you bring your self to get it dirty??
'00 XRV750 Africa Twin, '99 CRM250-AR, '88 TLM220R, '77 TS-50
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Diesel RV build
Joz is online now   Reply With Quote
Old 11-29-2011, 05:34 AM   #10478
Heno
Lover Of Perfection
Heno's Avatar
Oddometer: 60
Its never gonna get dirty I´ll take care of this.
Old 11-29-2011, 06:32 AM   #10479
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 329
Send a message via MSN to Africa_Twin
I agree!
I am interested in learning more about this.
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin is offline   Reply With Quote
Old 11-29-2011, 06:49 AM   #10480
Ze_zaskar
Ze_zaskar's Avatar
Oddometer: 304
About the fairing, to each it's own, I guess. I happen to be a fan of the Boano's one, but the stock is sexy as well.
Forgot to ask about the tank, will you keep it stock or go for a big one?
By the way, saw your former Transalp 700 on SmugMug, really cool. I don't understand how that bike isn't more popular, it can get really nice with some upgrades
Old 11-29-2011, 07:07 AM   #10481
Heno
Lover Of Perfection
Heno's Avatar
Oddometer: 60
I mean something similar to this, but not so straight.
Will keep original tank.
Old 11-29-2011, 09:13 AM   #10482
@dreamer
@dreamer's Avatar
Oddometer: 112
Could some one please explain to me this front suspension mod that Heno has done. From what I can tell it's an extension that goes on top of the fork tube but I'm not sure. How does it attach, do you have to use a progressive spring, strength, also where did you source them from?
I am looking to replace the wheels on my RD04, I will just get them relaced on the original hubs but I was thinking of going with an 18" rear and from what I gather you cant just put an 18" rear wheel on due to the changes in the geometry so I was thinking that this "lift kit" might be a simpler way of compensating for the change in the geometry due to the fact that the rear will be taller. What width wheel should I be looking at for the best options for tires, I will be putting a dual sport tire back on, not a knobbie or road tire, the roads here in Thailand are bad and once I move there will be alot of dirt/gravel roads.
Thanks for the help in advance.
Keith
@dreamer is offline   Reply With Quote
Old 11-29-2011, 09:20 AM   #10483
@dreamer
@dreamer's Avatar
Oddometer: 112
Sorry, one more thing I need to do some kind of tank sealer on my fuel tank due to rust. I found one on the internet that is called Gold Standard Tank Sealer, looks like a good product but I was wondering if the tank gets dented will this stuff crack off inside the tank or will it flex. Anyone have any suggestion for a tank sealer if this isn't what I should use?
Keith
Old 11-29-2011, 09:34 AM   #10484
Twiniver
Twiniver's Avatar
Oddometer: 62
Thumb
Hey Heno....
Nice projekt, i am following you on your smugmug album, it looks really nice!!!! I totally agre on the Boano fairing, so i will be looking foreward to seeing the result of your rebuild of the original, keep up the good work .
Twiniver.
Twiniver is offline   Reply With Quote
Old 11-29-2011, 12:02 PM   #10485
dennism
dennism
dennism's Avatar
Oddometer: 91
Keith[/QUOTE]
http://www.caswellplating.com/aids/epoxygas.htm
This one comes highly recommended, even for fiberglass tanks. I haven't needed it .....yet. DennisM.
dennism is offline   Reply With Quote
Times are GMT -7.   It's 09:08 PM.
