Old 12-13-2011, 02:21 PM   #10561
Ross Brown
One AU out
Ross Brown's Avatar
Oddometer: 70
Originally Posted by Stormforce8 View Post
Did you forget to use a smiley.........
I never joined the EU zone but I used to belong to the cub scouts as a nipper though
Ross Brown is offline   Reply With Quote
Old 12-13-2011, 09:12 PM   #10562
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,147
Wheel bearings
Guys do you have to have a press to do the wheel bearings on the RDO7 gold rims?
Reidy008 is online now   Reply With Quote
Old 12-13-2011, 09:19 PM   #10563
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,960
You can generally just tap them out with a long punch and a hammer
IF you heat the HUB first.
I still haven't had to replace my RIM bearings yet
Ladder106 is offline   Reply With Quote
Old 12-13-2011, 09:45 PM   #10564
Reidy008
Reidy008's Avatar
Oddometer: 2,147
How about getting the new ones in?
Old 12-14-2011, 12:34 AM   #10565
Ladder106
Ladder106's Avatar
Oddometer: 4,960
Same thing...a bit of heat...a plumbers torch works best. It takes a bit but can't really get hot enough to do any damage except to paint if you keep it in one place too long.
The new bearing will almost fall right in. Don't forget the spacer if there is one since you'll ruin the new bearing getting it out again. If heat isn't enough, use the old bearing to tap in the new one by placing it on top and taping on the outer race only. You can even put the new bearing in the freezer for maximum shrinkage.
You can tap out the old bearings from their inner race since they are not going to be used again. Never do this to a new bearing
Old 12-14-2011, 12:49 AM   #10566
Joz
What could go wrong?
Joz's Avatar
Oddometer: 1,858
+1 on using both heat and cold. Grease the bearings first. Pop them in the freezer for at least a few hours. Heat the hub and you can pretty much push them in by hand. You might need a little gentle persuasion (rubber mallet). It works great.
Africa Twin, CRM250-AR, TLM220R, CT90, SY250
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Joz is online now   Reply With Quote
Old 12-14-2011, 01:02 AM   #10567
Ross Brown
One AU out
Ross Brown's Avatar
Oddometer: 70
Use a Kettle with boiling water to heat the hub is another way. And no flame-damage risk.
Old 12-14-2011, 06:41 AM   #10568
Joz
Joz's Avatar
Oddometer: 1,858
Very good idea. I often use the oven to heat parts.....and get some very strange looks and comments about my cooking skills!
Old 12-14-2011, 07:02 AM   #10569
Stormforce8
Farkle Tart
Stormforce8's Avatar
Oddometer: 520
Kitchen's are great for spannering:
Oven - for heating parts
Fridge / Freezer - for cooling parts
Dishwasher - for cleaning parts
Sofa - for relaxing and admiring your spannering
Gaggia - for sustenance
www.ruggedroads.com
2000 Honda XRV750 Africa Twin RD07A - Rugged Roads Rallye Sport,
2002 Honda XRV750 Africa Twin RD07A - RWB
1989 Honda XRV750 Africa Twin RD04 - HRC
'Maybe I'm just simple - but can't we all just get along..........'
Stormforce8 is offline   Reply With Quote
Old 12-15-2011, 02:40 AM   #10570
raulghe
V-master
raulghe's Avatar
Oddometer: 25
HI!!..What type of handelbar you have here? thank you!!
raulghe is offline   Reply With Quote
Old 12-15-2011, 10:07 AM   #10571
Roadkill.dk
Oddometer: 1
Hi
Originally Posted by Twinmike View Post
Hi
on the pic i spot the resistor R5 (the blue one) one pin is unsoldered, i have only a list from the resistor values
maybe that helps
Hi
Thanks alot for the help , this is great !!!
Christian
Roadkill.dk is offline   Reply With Quote
Old 12-15-2011, 01:38 PM   #10572
Twiniver
Twiniver's Avatar
Oddometer: 64
Originally Posted by Roadkill.dk View Post
Hi
Christian
Hey Christian, and welcome.....
Was it usefull?
Twiniver.
Twiniver is offline   Reply With Quote
Old 12-15-2011, 03:12 PM   #10573
Ross Brown
One AU out
Ross Brown's Avatar
Oddometer: 70
"Oven - for heating parts
Gaggia - for sustenance"
I can see an all new Jamie Oliver tv series "Cooking with my AT'.
I've had my Montesa trials bike in the kitchen before; fun getting it up the steps and through the front door (and only to be undertaken when the MRs is out of town). But an @. That takes the cake!!
Old 12-16-2011, 03:13 PM   #10574
Stormforce8
Farkle Tart
Oddometer: 520
I think those were a set of BMW 1200GS bars that I was trying out at the time, but they were far too heavy.
I've been using a set of Pro Taper Pastrana FMX bars for the past 18 months - perfect for me.
www.ruggedroads.com
Old 12-16-2011, 03:41 PM   #10575
goran e
Oddometer: 114
A šta kažete na ovo...
http://youtu.be/5DJ6FP0XL2c
goran e is offline   Reply With Quote
Times are GMT -7.   It's 06:00 PM.
