Old 01-02-2012, 04:15 PM   #10606
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,197
Chain guide
Anyone know if the rear lower chain guide matches any other bikes so i could get one local or am I off to wemoto? Cheers
Reidy008 is offline   Reply With Quote
Old 01-03-2012, 08:57 AM   #10607
Stormforce8
Farkle Tart
Stormforce8's Avatar
Oddometer: 522
The Lower Chainguard (#13 in diagram above) is part # 52156-KB7-000.
This part is shared with:
  • Transalp XL600V
  • Africa Twin XRV650
  • Africa Twin XRV750
  • NX250
  • NX500
  • Dominator NX650
$26.99 from your local dealer (item #10 - they should be able to order one in for you)
Hope this helps -
www.ruggedroads.com
2000 Honda XRV750 Africa Twin RD07A - Rugged Roads Rallye Sport,
2002 Honda XRV750 Africa Twin RD07A - RWB
1989 Honda XRV750 Africa Twin RD04 - HRC
'Maybe I'm just simple - but can't we all just get along..........'
Stormforce8 is offline   Reply With Quote
Old 01-03-2012, 09:57 AM   #10608
goran e
Oddometer: 114
Evo mojih uzoraka Alu Kofera koje pravim za Africu Twin
(Powered by frubar.net)
goran e is offline   Reply With Quote
Old 01-03-2012, 10:45 AM   #10609
Dutchy506
Oddometer: 33
Thumb
looks good!
Dutchy506 is offline   Reply With Quote
Old 01-03-2012, 01:47 PM   #10610
Gummitarzan
Gummitarzan's Avatar
Oddometer: 30
Eh?
Originally Posted by Eeickey View Post
Just randomly picked this guy up in Florida...Now I had a TransAlp in the past but this bike rocks! I know they are rare but how rare?
Never seen these kind of crashbars for the AT before..
Africa Twin RD04 92
Gummitarzan is offline   Reply With Quote
Old 01-03-2012, 02:15 PM   #10611
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 472
I have them on mine. They are an early version of the Ricky Cross crash bars. No longer being made.
00 Honda Africa Twin XRV750 RD07a -- Rebuild Story
89 Honda Africa Twin XRV650 RD03 -- Its here!! -- Restoration
69 Honda CB750 Sandcast - Restoring Now
ujeni is offline   Reply With Quote
Old 01-03-2012, 02:59 PM   #10612
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,984
PINK.......really?
This alone should tell you that Honda has rectal-cranial inversion.
Ladder106 is offline   Reply With Quote
Old 01-03-2012, 04:24 PM   #10613
Squily
Squily
Squily's Avatar
Oddometer: 1,223
Maybe it's been asked before and answered (if so- sorry):
Steering dampers for the AT: Anybody have some advise? What works and what doesn't?
Squily
Squily is offline   Reply With Quote
Old 01-03-2012, 04:29 PM   #10614
Ladder106
Ladder106's Avatar
Oddometer: 4,984
What works
A good quality (not the stocker) rear shock with the sag/ride height set up to your weight and load.
Makes the wiggles go away......actually just setting the sag correctly will go a long way toward stability.
Old 01-03-2012, 04:38 PM   #10615
Squily
Squily
Squily's Avatar
Oddometer: 1,223
I think I know what you're referring to- my AT in standard form felt like it had a hinge built in. But I'm already running upgraded rear (not adjustable, but nice and firm for my big but).
However- she starts tank-slapping on the sand at speeds over 120. Don't think that's got anything to do with the rear suspension.
Squily
Old 01-03-2012, 05:15 PM   #10616
Ladder106
Ladder106's Avatar
Oddometer: 4,984
Sand is a whole different animal. The steering geometry changes with speed, load on the front, condition of the sand, throttle application etc. There's lots going on.
If you can visualize what's happening...the front contact patch is being essentially rolled forward and upward from its normal position under the front tire.
This makes the trail measurement shrink (less trail) and creates a condition similar to having your forks almost vertical.
To compensate, try increasing your rear sag by 1 to 1.5 in....I know, sounds like alot. The bike wont handle very well on the harder stuff but it should improve the sand handling.
Stormforce should know about mounting a stabilizer if anyone does. Don't remember if he has one on his bikes or not. (Not that it would be easy to see with everything else he has up there )
Old 01-03-2012, 05:29 PM   #10617
Reidy008
Reidy008's Avatar
Oddometer: 2,197
  • Transalp XL600V
  • NX250
  • NX500
  • Dominator NX650
Hope this helps -
Great stuff mate. Cheers
Old 01-04-2012, 02:40 AM   #10618
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 363
The stock unit is a Showa... isn't it? Why you you say it's bad quality?
I don't have any shimming at the steering, even with the top case fitted.
Wouldn't you say, probably the steering head bearings+steering head nut torque adjustment (refered to as "steering preload adjustment) have more influence on the steering wiggle?
Maybe a good quality set of roller bearings and a correct preload adjustment at the steering nut will do the trick?
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin is offline   Reply With Quote
Old 01-04-2012, 02:50 AM   #10619
Africa_Twin
Africa Twiner
Oddometer: 363
Now I see the "problem" lies when riding in the sand...
Different situation...
Old 01-04-2012, 02:58 AM   #10620
Squily
Squily
Squily's Avatar
Oddometer: 1,223
Top case fitted? Hmmm...
Maybe we're not on the same wave length here...
But seriously- I think the normal AT is set up for a smallish Japanese gentleman weighing in at aroun 70kg +1 + 20kg luggage max. The standard suspension is not "bad", its just that I weigh 130kg without riding gear or luggage, so I need a bit extra for when the going gets tough.
Squily
Times are GMT -7.   It's 07:45 PM.
