Old 01-15-2012, 12:18 AM   #10681
DakarBlues
One-everythinged man
Oddometer: 1,290
Originally Posted by Stormforce8 View Post
Yup - I'll see if I can find a decent image. IIRC it was on the R/H and faired into the tank............
Here you go (sorry about the quality)
I have to tell you that this engine was very low compression to begin with, this coupled with automatic decompressor made kicking it a breeze
He, whose nuts skim the ground while airborne, won't crash very far!
Pedibus Cum Jambus 1200 S
IBA # 38875
DakarBlues is online now   Reply With Quote
Old 01-15-2012, 07:56 AM   #10682
john_aero
john_aero's Avatar
Oddometer: 1,166
was out today giving the @ a service, dropped oil, cleaned bike up a bit, great, put new filter on and wiped down old oil.
hand threaded the sump plug in, check manual, 35n/m??? seems tight so set torque wrench at 30NM and away i go, half a turn and bang, treads stripped.
So anyone know a solution to repair the threads without having drop engine out?
it was awful tight when took it off so think someone might have cross threaded it hen last put it in as i had baerly startd tighten it up when went
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 01-15-2012, 09:53 AM   #10683
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 627
It might be a good excuse to install something like this (link is provided as an example only, size might not fit):
http://www.aircraftspruce.com/catalo...axoilvalve.php
A-Wind is offline   Reply With Quote
Old 01-15-2012, 10:11 AM   #10684
john_aero
john_aero's Avatar
Oddometer: 1,166
now i like th elook of that, that be a nice solution to it and make servicing easy
Old 01-15-2012, 12:09 PM   #10685
A-Wind
Andreas RD07a
A-Wind's Avatar
Oddometer: 627
There are different versions of it and I'm planning to install something similar myself in the future. I just have to check what works best with the limited space that we have.
http://www.youtube.com/watch?v=Wrcm-...ature=youtu.be
Old 01-15-2012, 12:12 PM   #10686
john_aero
john_aero's Avatar
Oddometer: 1,166
if it had a right angle on it be great instead of pissing oil over the frame
Old 01-15-2012, 12:45 PM   #10687
GSPD750
GSPD750's Avatar
Oddometer: 1,446
I'm not sure why you would want a qwik drain valve and besides you still have to deal with the damaged threads. Seeing that it is a 14 mm plug you can try chasing the threads with a sparkplug threadchaser and maybe even extend the hole if it will allow you. You could then use a longer threaded plug.
http://www.mytoolstore.com/kd/kdengi11.html
Helicoil or Timesert is also a more permanent repair. Timesert is the preferred as it is more robust where as the Helicoil is a springy type thread.
http://www.timesert.com/html/drainplug.html
Some of these thread repair kits can be costly and if your also not comfortable doing it then just roll your chassis to the dealer and they will do it for you in the frame.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 01-15-2012, 12:51 PM   #10688
john_aero
john_aero's Avatar
Oddometer: 1,166
timesert looks be the way to go i think
just have try get engine out now to do it
Old 01-15-2012, 01:01 PM   #10689
GSPD750
GSPD750's Avatar
Oddometer: 1,446
Why engine out?
Old 01-15-2012, 02:06 PM   #10690
john_aero
john_aero's Avatar
Oddometer: 1,166
not enough room get a tap into it
Old 01-15-2012, 02:21 PM   #10691
GSPD750
GSPD750's Avatar
Oddometer: 1,446
Search around for a shorter one instead of a long conventional tap. That's alot of work when it could probably be done in situ even if you have to modify or shorten the tap/reamer.
Such as....
GSPD750 screwed with this post 01-15-2012 at 03:05 PM
Old 01-15-2012, 02:31 PM   #10692
john_aero
john_aero's Avatar
Oddometer: 1,166
i like that, where you find it?
Old 01-15-2012, 03:01 PM   #10693
GSPD750
GSPD750's Avatar
Oddometer: 1,446
Your local auto parts supply store should stock those or something similar...I think the one in that pic was a KD. Following on ebay.uk
http://www.ebay.co.uk/sch/sis.html?_...t+14mm+Kit+Set
http://www.ebay.co.uk/itm/14mm-SPARK...item3a68344ec3
Old 01-15-2012, 09:00 PM   #10694
nomad guy
A legal alien
nomad guy's Avatar
Oddometer: 824
Is there a u.s online store for AT parts?
I am trying to buy a few AT parts for a friend in south America and i havent been able to locate a u.s dealer with the AT micro fiche online.
Thank you for your input.
Cheers
Guy
04 KTM ADV 950S GO!!!!!
09 KTM 690 ENDURO R
nomad guy is online now   Reply With Quote
Old 01-15-2012, 09:14 PM   #10695
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 470
Get the part numbers you need and try it over at servicehonda.com. Not all parts are available here in the US.
For the parts you can't find here, consider wemoto, cmsnl or sending the part numbers to your friend and having them ask a local Honda dealer.
Pm me on the parts you are looking for. I am close to you and might be able to help out.
00 Honda Africa Twin XRV750 RD07a -- Rebuild Story
89 Honda Africa Twin XRV650 RD03 -- Its here!! -- Restoration
69 Honda CB750 Sandcast - Restoring Now
ujeni is offline   Reply With Quote
Times are GMT -7.   It's 08:49 PM.
