Old 02-29-2012, 06:09 AM   #10906
Clockwatcher
Oddometer: 514
White????
Originally Posted by Reidy008 View Post
Guys I don't think it matters but what grease are you using to pack the speedo housing to best protect the nylon drive gear?
I had a mechanic tell me that the petro based grease in the speedo drive would eventually break down the nylon gear. He suggested using white lithuim grease which I have done. I also clean the speedo housing about every 3rd tire change and replace the grease.
Seems to work so I will stick with it, just my 2 cents worth.......
Clockwatcher is offline   Reply With Quote
Old 02-29-2012, 06:14 AM   #10907
novack
Oddometer: 52
Originally Posted by teddy750 View Post
did you install the crash bars on the white africa or did you bought it like that? from africas crashing here in GREECE there was always the problem of broken engine mountings near the frame. the small triangle above the front gear. i think the best type of crash bars is the GIVI model. they mount at the foot pegs, and it is better to loose a bolt from the foot peg than the engine mount. anyway it's just my opinion. still two AFRICA? I'M WAITING TO SEE THEM COMPLETE.
The Givi bars looks much sturdier than other brands. The only disadvantage of these bars is that they blocking the front sprocket cover so removing it is somewhat difficult.
novack is offline   Reply With Quote
Old 02-29-2012, 10:17 AM   #10908
orenburg
orenburg's Avatar
Oddometer: 20
Originally Posted by rusic View Post
got one question, did anyone replace the front plastic on the tripmaster? or polish it? mine is all cracked up and you can't see anything during the day :(
here you go.. http://www.morban.info/wp/?p=416
orenburg is offline   Reply With Quote
Old 02-29-2012, 01:52 PM   #10909
rusic
rusic's Avatar
Oddometer: 51
Originally Posted by orenburg View Post
thanks! I'll try the procedure with sand paper & polish...
rusic is offline   Reply With Quote
Old 02-29-2012, 04:50 PM   #10910
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,237
English
Can you post up this stuff in English so i can figure out if it is possible to get that stuff here in the USA. Cheers
Reidy008 is offline   Reply With Quote
Old 02-29-2012, 05:15 PM   #10911
GSPD750
GSPD750's Avatar
Oddometer: 1,453
Micro-Mesh....same principle.
http://www.ebay.ca/itm/Micro-Mesh-Cr...item22fcdf371c
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 03-01-2012, 09:20 PM   #10912
raoulserban
vrrummm
raoulserban's Avatar
Oddometer: 100
if you are short of money , you can use toothpaste for removing scratches. i've done it with some binnoculas lenses and a couple of watches. a soft piece of textile and toothpaste!
i've tried it even with the ATwindshield but i did not have enough pacience. for the amount of energy invested the windshield , it looked pretty nice. and the smell.... :)
raoulserban is offline   Reply With Quote
Old 03-02-2012, 12:08 AM   #10913
rusic
rusic's Avatar
Oddometer: 51
http://translate.google.com/translat...p%2F%3Fp%3D416
the point is to use a sandpaper... and then very fine sandpaper... and then use a polish... or toothpaste ;)
Old 03-02-2012, 04:37 PM   #10914
Twinmike
Grandpa
Twinmike's Avatar
Oddometer: 146
Hi
i used wet sandpaper 800 - 1200 - 1500 - 2000 and at last Xerapol scratch remover i have used different products, but Xerapol works best for the Tripmasterglass.
Xerapol
deep scratches
polish with wet sandpaper
finish better than before
Twinmike screwed with this post 03-03-2012 at 02:26 PM
Twinmike is offline   Reply With Quote
Old 03-04-2012, 10:06 AM   #10915
diskow
diskow's Avatar
Oddometer: 226
Teaser
Back from Tunisia. Amazing trip.
I promise report will follow.
At least some pictures.
diskow is offline   Reply With Quote
Old 03-04-2012, 12:06 PM   #10916
john_aero
john_aero's Avatar
Oddometer: 1,173
that looks like one class trip
more pics please
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 03-05-2012, 03:33 AM   #10917
Belgian Waffles
Oddometer: 874
Went for a ride in South Africa yesterday. (Sounds weird to say that...) It wasn't with an AT, unfortunately. I was riding a borrowed Yamaha XT660R. I was thinking about Africa Twins the whole time though I swear! There was also a Tenere 750... So I'm getting close with the dual headlights, right? Anyway, Im going to stop trying to justify myself and just post the link.
BW
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying.
Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials
Past: 1999 KLR 650, 1990 Tengai 650
Belgian Waffles is offline   Reply With Quote
Old 03-06-2012, 11:01 AM   #10918
Rookie_Rider
Oddometer: 49
My AT doesn't start!
I rode it to my friends house this fall and put it in the garage. Almost full tank.
Today when i took it out, battery is fresh and has been charged over winter. it just won't start, not even a cough or studder. using starter gas it starts right up for a short while but as soon as it has consumed the gas it dies.
Any ideas? i will go there again tomorrow to try to fix it and want to be armed with ideas before.
Thanks for any input.
Rookie_Rider is offline   Reply With Quote
Old 03-06-2012, 11:05 AM   #10919
ujeni
just doesn't get it
ujeni's Avatar
Oddometer: 476
Sounds like either bad fuel, bad fuel pump or a combination of the two.
Double check that your air filter is clean and that all your sparks are firing. Drain out the old fuel, put fresh fuel in with a good cleaning additive (I use a product called "Sea Foam") and check the electrical connection to your fuel pump. Then try to start it again. At the same time, put your hand on the fuel pump. You should feel it pumping fuel every few seconds. If not, then your fuel pump is bad.
Honda Africa Twins: 2000 XRV750 RD07a and three 1988 XRV650 RD03s
PM me if you are interested in buying a restored XRV650!
ujeni is offline   Reply With Quote
Old 03-07-2012, 01:00 PM   #10920
Rookie_Rider
Oddometer: 49
The problem was the cable between the fusebox and the pump, well actually between fusebox and the connector under the seat. Replaced the wires and voila it runs again. How a cable can "break" during winter storage when nobody has moved the bike is beyond me.
Times are GMT -7.   It's 12:00 AM.
