Old 03-21-2012, 08:47 PM   #11011
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,306
Parts ordered
I got the plate and bolts ordered up today. What if any has been the best idea to help the output shaft not ware so quickly? My sprocket has a little play in it and I would like to prevent the ware if possible with the hope of not having to split cases and replace the output shaft down the road.
Reidy008 is offline   Reply With Quote
Old 03-21-2012, 09:05 PM   #11012
GSPD750
GSPD750's Avatar
Oddometer: 1,468
Not much really...other than using an OEM rubber cushioned sprocket and good chain maintenance. But then again I have heard of others who have used after market sprockets (non-cushioned) who claim they have had no appreciable spline wear. Applying some spline lube i suppose won't hurt....but it's not really called for.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 03-22-2012, 02:49 AM   #11013
DC,Chad
DC,Chad's Avatar
Oddometer: 322
as stated just keep it adjusted and lubed properly , @s really hate chains adjusted to tight this is mostly the cause of premature output shaft wear.
GS gone now on a 1990 Electraglide sport natural balance gone to Ratshit
RD03 Africa twin slowly coming together
DC,Chad is offline   Reply With Quote
Old 03-22-2012, 04:55 AM   #11014
GSPD750
GSPD750's Avatar
Oddometer: 1,468
Not only will it affect splines from an overly tight chain but also the output shaft bearing for radial play which can eventually lead to an oil leak through the shaft seal or even the engine grenading if it lets go.
The following vid is from an RDO7A output shaft bearing that I replaced some years ago now...I barely made it home on that bearing after a long trip without destroying my engine...it was moments away.
I've posted this before....beware.
http://www.youtube.com/watch?v=2x-LqbBscdY
Old 03-22-2012, 05:05 AM   #11015
DC,Chad
DC,Chad's Avatar
Oddometer: 322
yup and it never cease get this reaction
Old 03-22-2012, 01:24 PM   #11016
john_aero
john_aero's Avatar
Oddometer: 1,174
Originally Posted by Ladder106 View Post
Do you really need an answer to this question?
more i was checking to see if people mad made adaptor plate or something seen as you mentioned it may work thats all
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 03-22-2012, 01:26 PM   #11017
john_aero
john_aero's Avatar
Oddometer: 1,174
ok have few bits still for sale
front forks, top clamps, brake callipers, brake line, lower fork mudguard and side for 180 euro
will also have a rear shock in 4-5 weeks and may also sell my SM PRO front wheel or set if someone wanted a new set of wheels if willing do deal with your old rear hub so i can re lace a new rim on
Old 03-22-2012, 06:20 PM   #11018
Reidy008
Reidy008's Avatar
Oddometer: 2,306
Africa twin Rally
Guys when I first got my AT I understood that every second year there was a US AT rally or meet up lets say. Is there any plans for one this year?
Old 03-22-2012, 07:15 PM   #11019
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Are you volunteering?
I'm still in my radiation treatment and haven't ridden since November, except for one half hour. BUT, I am so looking forward to April 13th. That will be the first free day and I won't care if it's a Friday. After that, I will be available to plan a get together if no one else steps up. I'm thinking end of August.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 03-22-2012, 08:43 PM   #11020
Reidy008
Reidy008's Avatar
Oddometer: 2,306
I would be in..
I would be happy to step up and host here in Arizona... I could have some fantastic rides planned that could be as hard as you like or easy. I could plan routes for both. What has happened in the past?
Old 03-24-2012, 07:53 AM   #11021
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Most don't want single track pucker up rides as they would still have to ride home. But blue runs (ski slope rating) would be good with an alternative of pavement or a combination of boths. I'm not sure about August in Arizona though. You would have to plan something around Prescott or Sedona. I'll even do Yarnell hill with knobbies.
Jim Rowley
Black Forest, CO
Old 03-25-2012, 11:34 AM   #11022
goran e
Oddometer: 114
(Powered by frubar.net)
goran e is offline   Reply With Quote
Old 03-26-2012, 11:28 AM   #11023
goran e
Oddometer: 114
Old 03-26-2012, 04:42 PM   #11024
twinie
traveler
twinie's Avatar
Oddometer: 184
Africa Twin Red Bull Rallye
hey guys
so after 4 years with my beloved AT, i have come to some king of an "ending" to what i had first imagined it to be.
here's some pics!
cheers
part of the ideia was to keep the bike a with its original look, but a bit more "updated", so i decided to keep most of the original color scheme, and change the front, giving it new black parts in the bottom half of the bike.
so everything started by changing the oil of the front forks to a thicker one, 10W. Its a great thing to do, the front seems more "responsive" and a bit harder, not as (too) soft as before.
then the usual replacement of the spark plugs, the radiator liquid, air filter, oil filter, and so on...
the new front!
the puzzle...
...and here it is!
here's a few details:
so this is it.
also, this was a little private joke i had to share...
cheers!
http://www.emazimute.com/
twinie is offline   Reply With Quote
Old 03-26-2012, 10:45 PM   #11025
Reidy008
Reidy008's Avatar
Oddometer: 2,306
Clutch questions
Ok guys about to pull the clutch I fried and do the repair. Anyone got any good tips to make this easier? Also unless I am wrong I have to pull the exhaust to remove the case cover. Am I wrong on that one?
Times are GMT -7.   It's 10:43 PM.
