03-30-2012, 07:06 PM
#11056 | |
Oddometer: 1,202
It's not like it's a cylinder head bolt.
1999 XRV 750 Africa Twin 1996 XL 600v Transalp "Almost no other bike has the road presence of the Africa Twin and cars seem to melt out of its way, once they see the angry glare of its lights in their mirrors." ... |
03-30-2012, 07:23 PM
#11057 |
I,m in if we go fast
Oddometer: 1,431
loctite
What's the feeling on loctite on these?
03-30-2012, 08:50 PM
#11058 |
Oddometer: 1,202
I have no manual in front of me but I don't believe it's req'd in that location. 104 inch lbs should do the trick...however if you want to dab them with some low strength blue loctite i suppose it won't hurt.
03-31-2012, 04:10 PM
#11059 |
dennism
Oddometer: 91
Reidy, I believe you'll find better tensile strength bolts at an auto supplier like NAPA. They probably won't be washer head type, like the Honda ones. In Phoenix, there must be a supplier of fasteners to the trades, and they may well have the exact ones you need. Take a sample with you. Good luck.
03-31-2012, 05:13 PM
#11060 |
Oddometer: 1,431
Clutch done
Got the clutch done and buttoned up. Go to start the bike and the fuel pump is not working at all. Going to check fuse first and then if not that simple I will do the fuel pump upgrade as well. Anyone got a quick answer as to what fuse the pump is tied into?
03-31-2012, 05:38 PM
#11061 | |
Oddometer: 1,202
How do the contacts look on the pump? Take the screw out and pry the cap off for inspection. To confirm your pump is bad try checking for voltage and also note the fuel cut-off relay in this circuit. Or.... just bypass the pump entirely with the supply hose and fill your tank to the brim. Might be Facet time.
03-31-2012, 06:40 PM
#11062 |
Oddometer: 1,431
Fuel pump
Well pulled the fuel pump and really cant beleive it was working as long as it did. It is rusted and the points are shot. Can you shoot me a link or info on the pump you spoke of the facet. I know the stock ones are not the best and I now have two broken ones. Cheers
I did bypass the pump and the bike runs great.... yeah. |
03-31-2012, 08:23 PM
#11063 | |
Oddometer: 1,202
I've also heard NAPA may carry it (part # 610-1051). http://www.aircraftspruce.com/menus/...telectric.html Installation instructions here...yeah thats me again. I can't believe it has almost 50k views. Hard to beat a solid state pump that they use on ultralight aircraft. http://www.xrv.org.uk/forums/mechani...tion-long.html
03-31-2012, 08:28 PM
#11064 |
Oddometer: 1,431
Order
Got the pump ordered and thanks again for all the help.
04-01-2012, 02:14 PM
#11065 |
Oddometer: 12
04-02-2012, 12:17 AM
#11066 |
Oddometer: 58
hi, where buy this screen ?
![]() I found in Boano, but it does not seem to be the same. Thx ! |
04-02-2012, 12:26 AM
#11067 |
Desktop Adventurer.
Oddometer: 1,093
04-02-2012, 12:41 AM
#11068 |
Oddometer: 12
04-02-2012, 02:04 AM
#11069 | |
Oddometer: 66
http://www.africanqueens.de/
www.samiv.org |
04-02-2012, 05:18 AM
#11070 | |
Oddometer: 58
but this is not a screen for africa twin? another bike? XR400/600?
