Old 06-01-2012, 01:27 PM   #11311
psi-
a tool
Oddometer: 21
Hi.
I believe some of the inmates here have the Ricor intiminators installed. I've had that job done (along with general front maintenance -- that's why I didn't do it myself). And now the front clunks.
It does it even with very slight pressure, I compress the (single leg) with like 10kg small weight and when it's just about coming back up, it clunks. So I took the emulator out, and without oil and just the spring and spacer, it's just like it was, soft and smooth movement front and backwards.
It does it with both 10W and 5W oil. I've aired the leg quite well (well, imo). Both legs (ie. both intiminators) seem to do this. The other one is out, the other is in place.
Intiminator is installed wide part down, then the long (afaiks original) spring, then the wide plate (bushing?) and on top of that Ricor supplied spacer-tube.
Thoughts?
psi- is offline   Reply With Quote
Old 06-03-2012, 01:54 AM   #11312
gpmucci
gpmucci
Oddometer: 246
Some update from my office:
The rear tank is the under seat frame.
:):):):screwy:
Inviato dal mio HTC EVO 3D X515m con Tapatalk 2
gpmucci is offline   Reply With Quote
Old 06-03-2012, 02:22 AM   #11313
DC,Chad
DC,Chad's Avatar
Oddometer: 322
thats looking brutal where are you re locating the battery and what sort are you going to use ?
GS gone now on a 1990 Electraglide sport natural balance gone to Ratshit
RD03 Africa twin slowly coming together
DC,Chad is offline   Reply With Quote
Old 06-03-2012, 10:30 PM   #11314
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,187
Frontfender
Is the front fender the same on the 89/90 Transalp and AT ?
Reidy008 is offline   Reply With Quote
Old 06-04-2012, 12:42 AM   #11315
brittatel
brittatel's Avatar
Oddometer: 6
RD03 Africa Twin from Costa Rica...
Greetings from San Jose Costa Rica....Central America
My name is Enrique Gonzalez and I own a 1988 Honda Africa Twin RD03 with some mods
Here are some pictures.....
Enrique Gonzalez
1988 Honda Africa Twin RD03 650
"The leg breaker"
brittatel screwed with this post 06-04-2012 at 10:08 PM Reason: missing pic
brittatel is offline   Reply With Quote
Old 06-04-2012, 03:27 AM   #11316
ericGSsti
ericGSsti's Avatar
Oddometer: 540
Originally Posted by brittatel View Post
Hello can somebody explain to me how to post pictures of my Africa Twin??
I have pics on skydrive but how do I post them here???
I use www.photobucket.com, up load your photo's there and copy the IMG CODE under the pic then just paste it in here.
Not up on skydrive but if it has an IMG CODE try coping and pasting it.
2003 KTM 525 EXC
2004 KTM 950 Adventure S. (GO!!!!!!!!!!!)
IBA membership no.35934
"In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar -
ericGSsti is offline   Reply With Quote
Old 06-04-2012, 08:57 AM   #11317
Squily
Squily
Squily's Avatar
Oddometer: 1,223
http://advrider.com/forums/showthread.php?t=919
Squily
Squily is offline   Reply With Quote
Old 06-04-2012, 11:51 AM   #11318
gpmucci
gpmucci
Oddometer: 246
No, it is a Kevlar 07 front fender.
But probably I will change it. My idea is to do something similar to original nxr.
Old 06-04-2012, 10:17 PM   #11319
mhouck
mhouck's Avatar
Oddometer: 154
Very Nice Enrique! I like the paint job! Looks like you have done a lot of work on her!
I've got an RD03 as well and am currently undertaking a complete restoration.
mhouck is offline   Reply With Quote
Old 06-04-2012, 10:52 PM   #11320
alainmax
ca vaut le detour !!
alainmax's Avatar
Oddometer: 618
very nice Enrique, ....very nice RD03, I lov'em!!
04 GS 1150
93 Africa twin RD07
alainmax is offline   Reply With Quote
Old 06-05-2012, 11:56 AM   #11321
raoulserban
vrrummm
raoulserban's Avatar
Oddometer: 100
The 6th Africa Twin meeting in Romania took place in Nadrag. We had a real good time and we proven once again that AT is a real adventure bike.
raoulserban is offline   Reply With Quote
Old 06-07-2012, 03:05 PM   #11322
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,487
Hey, I've a 97 africa twin and can't find info on the petcock reserve position. Off I got what's up and what's down. Thanks
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 06-07-2012, 06:47 PM   #11323
GSPD750
GSPD750's Avatar
Oddometer: 1,445
Fuel ON turn full counter clockwise....Fuel RESERVE full clockwise...horizontal is fuel OFF.
Just remember when driving turning it FORWARD is FULL gas and REARWARD is RESERVE gas.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 06-09-2012, 02:36 PM   #11324
cas121
cas121's Avatar
Oddometer: 14
Got the twin back today after full service, new battery, valve cover seals, stahlflex brake lines and regulator. Drives like new, with 97k!
cas121 is offline   Reply With Quote
Old 06-09-2012, 03:12 PM   #11325
gpmucci
gpmucci
Oddometer: 246
Times are GMT -7.   It's 08:38 AM.
