Old 06-25-2012, 11:32 AM   #11401
ericGSsti
ericGSsti's Avatar
Oddometer: 252
Originally Posted by @dreamer View Post
Hi everyone, hope that everyone is doing good. Have a question about the throttle cables, I have new cables that are routed as strait as they can be so I feel these two issues aren't going to be my problem and I have the original spring on the carbs so I am wondering if anyone has gone to only one throttle cable in order to minimize drag so that you get more of a snap on the throttle return. When I ride I always have my hand on the throttle and in modulating the speed I'm always pushing and pulling the throttle but when its on the side stand and you give it some gas it doesn't always go back and sometimes it slowly goes back. Hope this make since, also I have looked in the throttle housing and the cables are routed correctly.
Stormforce, how is that old rusty AT that you found coming along?
Had the same problem, lubricated the cable and throttle (white bit under the hand grip) and changed the grips and it sorted it.
2008 KTM 640 adventure.
Africa Twin XRV750 RD04
IBA membership no.35934
"In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar -
ericGSsti is offline   Reply With Quote
Old 06-25-2012, 01:54 PM   #11402
GSPD750
GSPD750's Avatar
Oddometer: 1,202
Happiness is a throttle that snaps back to idle...i hear ya. A properly rigged and routed throttle cable should do that providing their is no damage in the circuit. Is the cable guide (#17) installed correctly or is it worn? Order a new one if it's effed.
Properly installed that white plastic thingy does not really require lube as already suggested as that will only attract dust and dirt and make it worse in the end. Only the cable ends need a touch of lube.
Are the 2 throttle housing halves lined up to the punch marks on the OEM handlebars. If not OEM bars then rotate as req'd until their is no friction and cables are at their slackest and not tight and stretched. Order a new tube and grip from Honda (#12) if worn.
Patience and persistance...keep fiddleing in the grip area and you will solve it. Obviously with those cables disconnected it sounds like you have already eliminated the cable run/conduits/spring.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
"Almost no other bike has the road presence of the Africa Twin and cars seem to melt out of its way, once they see the angry glare of its lights in their mirrors." ...
GSPD750 is offline   Reply With Quote
Old 06-25-2012, 07:00 PM   #11403
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,476
Originally Posted by GSPD750 View Post
Timely post of that pic GSPD...
Noob question - what are the short wires (with terminals) coming out of each switchblock for? Immediately left of the number 10 and above/right 42 in the pic.
01 Africa Twin RD07A
05 HP2
09 R1200GSA - for sale!
10 DR650
farcall is offline   Reply With Quote
Old 06-26-2012, 02:05 AM   #11404
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 9,758
front brake light switch and clutch lockout switch
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is online now   Reply With Quote
Old 06-26-2012, 02:34 AM   #11405
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,476
Cheers.
The leads (not switches) are not plugged into anything... and the clutch lock out and brake light are both working.
Are we talking bout the same thing?
Screwdriver points to the switch. Unplugged leads dangling nearby.
05 HP2
10 DR650
Old 06-26-2012, 03:09 AM   #11406
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 329
Send a message via MSN to Africa_Twin
Well, there is a lubrification hole on the bottom of the throttle guide housing (part#16) which is covered by the rubber boot (part#2)... a squirt of WD40 every now and then has never made any harm to mine... and after recently disassembling it for throttle grip replacement, I haven´t found any dust or dirt in there... after 4 years of owning this bike and 45k kms later. Just make sure the boot covers the lubrication hole.
In fact, I've cured many a sticking throttle simply by squirting a bit of WD40 into this hole and/or by correcting the cables' routing to the carbs and/or by pulling the throttle handle weight a bit outwards so that the handle weight does not rub against the tip of the throttle grip rubber... as a joke, we call this weight a "poor man's cruise control" because if you tap the weight inwards enough with the palm of your hand, you can make the throttle stick into any given position... I wouldn't recommend doing this while on the move, though... you may lose control of the bike. If you want to try it, do it with the bike stopped and make sure you use it only for cruising on longer trips... like you would with a "normal" cruise control. When done, pull the weight out again, so as to release the throttle grip...
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin screwed with this post 06-26-2012 at 03:15 AM
Africa_Twin is offline   Reply With Quote
Old 06-26-2012, 03:13 AM   #11407
Africa_Twin
Africa Twiner
Oddometer: 329
Cheers.
Here:
EDIT: you sure the clutch works as intended with the clutch switch leads disconnected?
Old 06-26-2012, 03:36 AM   #11408
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,476
Originally Posted by Africa_Twin View Post
Here:
Ummm... I think I now know what's happened.
The switches worked when I first got the bike and checked it over. I never noticed, one way or the other, whether those leads were dangling or not. Straight after that the stripping project started. My mate gave me a hand day 1. He was working at the front end. I'm guessing he unplugged them when stripping the electrics on the front end and me, the unobservant one, missed the change.
Thanks fellas.
I knew it was a silly noob question.
05 HP2
10 DR650
Old 06-26-2012, 05:09 AM   #11409
GSPD750
GSPD750's Avatar
Oddometer: 1,202
I doubt Mr Honda put that hole there as a lubrication point but if it works for you then use it as one...it's purpose is more likely a water drain. Like I mentioned earlier the recommended lubrication points are at the cable ends and thats where I apply mine using a multi purpose grease. If it's wet IMO then it will only attract dust and dirt which can lead to grit and and abrasive.
Old 06-26-2012, 12:43 PM   #11410
ninety
Oddometer: 15
Suspension upgrade completed and very happy with the result!
front: RuggedRoads steering stem for WP usd with Reiger suspension = 4cm lift
rear: Technoflex suspension and 18" rim
chears,
Simon
ninety is offline   Reply With Quote
Old 06-26-2012, 01:56 PM   #11411
tserts
Gas Burner
tserts's Avatar
Oddometer: 1,950
Simon
That looks yummy...
How much did the whole shenanigan cost?
If I had that suspension, ABS and a 6th gear I would never think of changing that bike..
Africa Twin RD07 '00 - My Kleopatra
Malfunction specialist...
Road Rush (Romania, Serbia)
Peloponnese Peninsula on two Africa Twins
9 countries in 15 days - Tserts.com
tserts is offline   Reply With Quote
Old 06-26-2012, 02:34 PM   #11412
ninety
Oddometer: 15
I don't keep track off the costs, that would spoil the fun! But it was a hard dissision to sacrifice my other, older AT for this.
Old 06-27-2012, 03:46 AM   #11413
Faceplant
Faceplant's Avatar
Oddometer: 237
Send a message via Skype™ to Faceplant
Just had to remove and strip my RD04 engine due to excessive bearing noises. I have priced replacement OEM parts which seem a bit expensive. Also I have an issue with importing bits, I live in Tanzania, and I saw somewhere, either on this forum or on XRV's that there are options for replacement big-ends and mains bearings, cam-chains etc. Have searched both sites fruitlessly, Does some kind sole have the link to the list of options please? I would like to source as much locally as possible naturally.
Many thanks in advance
"The only function of economic forecasting is to make astrology look respectable." Ezra Solomon
"Capitalism is the exploitation of man by man. Yes? Well socialism is exactly the reverse." Len Deighton
Faceplant is offline   Reply With Quote
Old 06-28-2012, 01:17 PM   #11414
gpmucci
gpmucci
Oddometer: 164
My Nxr project:
19 lt rear, 42 front
gpmucci is online now   Reply With Quote
Old 06-28-2012, 01:24 PM   #11415
Stormforce8
Farkle Tart
Stormforce8's Avatar
Oddometer: 501
Originally Posted by gpmucci View Post
My Nxr project:
Are you going to make an NXR exhaust system:to go on it ..........
www.ruggedroads.com
Honda XRV750 Africa Twin RD07A - Rugged Roads Rallye Sport,
Honda XRV750 Africa Twin RD04 - HRC
BMW R1150GS - Graphitan
Yamaha XT600Z Tenere 3AJ - BYRD,
Aprilia Moto 6.5 - Starck Orange,
Cagiva N90 - Lucky Explorer
'Maybe I'm just simple - but can't we all just get along..........'
Stormforce8 is offline   Reply With Quote
Times are GMT -7.   It's 12:37 AM.
