Old 09-08-2012, 02:27 PM   #11566
cas121
cas121's Avatar
Oddometer: 14
Originally Posted by locorider View Post
Take your time....
and an impact driver...
cas121 is offline   Reply With Quote
Old 09-08-2012, 02:31 PM   #11567
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 577
Problem with the fairing bolts is that the nuts turn in the rubber thingy, causing me to be unable to get them out... I'm going to try by using pliers on the nut side, an impact driver won't help because these parts of the fairing are not supported, I might break it...
| KTM 690 SMC RRP | Honda RD04 Africa Twin |
Balkan ADV - RR around Europe on the AT
Bacon trip log map
LethPhaos screwed with this post 09-08-2012 at 02:31 PM Reason: typo
LethPhaos is offline   Reply With Quote
Old 09-08-2012, 07:35 PM   #11568
GSPD750
GSPD750's Avatar
Oddometer: 1,445
It's only a rubber well nut...just pinch it with your fingers while you
remove the screw. As for you front wheel removel...let the air out of the rear tire and put a sack of potatoes on the seat.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 09-09-2012, 06:15 AM   #11569
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 577
pinching with my fingers didn't help, pinging the rubber with pliers didn't help, removing the rubber with a knife and pinching the metal helped, but not for all nuts...
I tried drilling them out, no luck (melted the plastic), drilling on low speed, no luck either (still melted)
It melted through so fairing is off now, but not in the way I intended...
Now, tacho fix time :)
Apparently one of the previous owners found it a good idea to connect the 12v connector to one of the tacho cables...
I got the problem where the needle won't go over 4k rpm even if I rev the engine. This can be fixed, by soldering in some new parts. Any ideas how to open the tacho housing? Got the internals loose and the cable off, but can't seem to find a way to open the housing to get the internals out...
Bacon trip log map
Old 09-09-2012, 01:23 PM   #11570
john_aero
john_aero's Avatar
Oddometer: 1,166
got finger out over weekend anf fairing ready and finished
cant post pics for some daft reason
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 09-09-2012, 02:35 PM   #11571
wrryder
wrryder's Avatar
Oddometer: 165
Here in the U.S. the best Africa Twin is any one you can buy.
That said, I agree with your assessment.
Originally Posted by gpmucci View Post
The best are the last.
The Rd07A 750 is the best. Years of development correct all the weak points of the bike. But all the At are good bikes with some little work to do. The last one is the best.
Inviato dal mio HTC EVO 3D X515m con Tapatalk 2
Craig
RD07a
Sacramento, CA
Don't Feed the Bearcat!
wrryder is offline   Reply With Quote
Old 09-09-2012, 02:40 PM   #11572
ericGSsti
ericGSsti's Avatar
Oddometer: 540
Here you go John. Took them off XrvIreland for you.
2003 KTM 525 EXC
2004 KTM 950 Adventure S. (GO!!!!!!!!!!!)
IBA membership no.35934
"In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar -
ericGSsti is offline   Reply With Quote
Old 09-09-2012, 04:23 PM   #11573
bunkmuffin
Bunkmuffin
bunkmuffin's Avatar
Location: Oshawa Ontario The original home of General Motors
Oddometer: 9
XRV750 spark plug wires
Can anybody out there help me... I am restoring a 92 RD04 AT and have discovered that the spark plug wires have lost all of their flex life. I am unable to remove the HT wires from the coils and assume that they are a one piece item
I would like to replace the plug wires but my manual is of little help and the parts vendors appear to sell the coil with HT wire attached leaving the sparkplug end to be installed by the poor sap who just spent a bucket full of cash for the coils that were not needed.......
Ok I know that was a little harsh but c'mon this is 2012 coil separate item, wires like a car, separate item............
Thanks for anyones help.
Billy Bob
bunkmuffin is offline   Reply With Quote
Old 09-10-2012, 05:02 AM   #11574
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
chasing a KTM
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg screwed with this post 09-10-2012 at 05:37 AM
atgreg is offline   Reply With Quote
Old 09-10-2012, 06:05 AM   #11575
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 577
Billy Bob
Don't know about the AT, don't know it that well yet, but usually it is separate indeed (at least on my 690 the wire and the connector are separate). Can't you just buy a generic wire and connect that? Since you're not going to be able to use the current coils as there are attached to the wire, I'd try pulling them off with force to see if they'll come apart. If not, or if you break it, you can order a spare, as you'd have to do anyway, if you can separate them, you might be able to just add a new wire.
Bacon trip log map
Old 09-10-2012, 06:18 AM   #11576
bunkmuffin
Bunkmuffin
bunkmuffin's Avatar
Oddometer: 9
The wires and coil are sealed as one unit if I were to pull the existing wire off "with force" then I'm pretty sure I would just be breaking a perfectly good part and I am not a troglodyte.. I'm checking with anyone with experience so I don't spend large needlessly.
I would normally not ask such a mundane question. This is not my firs vehicle. My first was 1965....
Old 09-10-2012, 06:21 AM   #11577
LethPhaos
brb
LethPhaos's Avatar
Oddometer: 577
you're saying yourself that you're wanting to replace them, so I wouldn't call them perfectly good ;)
fine by me either way though, let us know if you've found a good way, so we can learn from your experience :)
Bacon trip log map
Old 09-10-2012, 06:29 AM   #11578
john_aero
john_aero's Avatar
Oddometer: 1,166
cheers eric
Old 09-10-2012, 10:47 AM   #11579
The Apostle
The Apostle's Avatar
Oddometer: 29
Is there anything similar for the RD04 ????
I think that my RD04 has only numbers after the "RD04########" part.
At least on the license is like that.
Originally Posted by Stormforce8 View Post
According to Honda - my RD07A was built at the Hamamatsu factory in Japan
I agree that the RD03 had the highest build quality - the way I explain it is:
  • RD03 - designed & built by mechanics
  • RD04 - designed & built by mechanics with advice from accountants
  • RD07 - designed by accountants & built by mechanics
  • RD07A - designed & built by accountants
The Apostle is offline   Reply With Quote
Old 09-10-2012, 11:30 AM   #11580
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
Very cool info, thanks. I would have thought that restricted bikes are made closer to the countries they were designated to. I would of though Atessa or Montessa, Italy.
Made by Honda Japan
RDO7B - Restricted (but converted to full power)
X (errors)
96 Model
Hamamatsu Factory.
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Times are GMT -7.   It's 10:42 AM.
