Old 10-30-2012, 04:51 PM   #11776
alainmax
ca vaut le detour !!
alainmax's Avatar
Oddometer: 620
Originally Posted by ROYMACNIC View Post
Thanks Ladder ,but I have tried all that you mention,bike was running perfectly,all I did was switch it off ,wash it ,try to start it again, so I did suspect dampness or a bad connection so I have cleaned and sprayed all the connectors.
I suspect it will start fine once thoroughly dry!
We assume you did not use a pressure washer...
04 GS 1150
93 Africa twin RD07
alainmax is offline   Reply With Quote
Old 10-30-2012, 07:12 PM   #11777
coyotetrips
Traveller
coyotetrips's Avatar
Oddometer: 136
Originally Posted by GSPD750 View Post
I swear that I told him to start high, somewhere between $7-8k, NOT $10k+ !!!
If he gets, let's say, $12k for it then I'll put mine on the market too.
http://www.coyotetrips.com
2006-20?? Honda XRV750 Africa Twin RD07A (80,000+ km)
1999-2006 Honda NX650 Dominator RD02 (110,000 km)
coyotetrips is offline   Reply With Quote
Old 10-30-2012, 07:43 PM   #11778
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,097
I emailed him pretty quickly but was kinda put off by his asking price.
OK, ATs are rare in the US but not "non-existant"......and as much as I like them, where we're only a few thousand away from a brand new Tenere and the AT has 40K on the clock......the yellow flashing "you better think again" light went on.
Ladder106 is offline   Reply With Quote
Old 10-30-2012, 07:56 PM   #11779
coyotetrips
Traveller
Oddometer: 136
That price is ridiculous! Especially knowing that he needs to get rid of it by the end of the year, he is moving back to Denmark. I'm sure he'll drop the price when it gets closer to moving day and he still has the Twin in the garage.
Old 10-31-2012, 03:03 AM   #11780
The Apostle
The Apostle's Avatar
Oddometer: 29
For 8.000$ each I can load a container with AT's and send them there !!!! (custom's "tips" included )
Even better, I will bring each one personally in "a trip around the world".
The Apostle is offline   Reply With Quote
Old 10-31-2012, 03:13 AM   #11781
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,530
Did a bit of a quarry ride, I was on the twin.
stevh0 is offline   Reply With Quote
Old 10-31-2012, 09:23 AM   #11782
mechahayai
Oddometer: 142
That's a lot of cash. Be interesting to see what he gets for it. He's not too far from me. I should ride up there and take a pic of my identical 2001 next to his.
mechahayai is offline   Reply With Quote
Old 10-31-2012, 11:11 AM   #11783
ROYMACNIC
Oddometer: 64
Thanks for the advice guys,again though they are things I've checked,wasn't a pressure washer I used,did get a good clean though,which doesen't usually bother it .I didn't get a look at bike today,hopefully get a chance tomorrow,fingers crossed.
Roymacnic
ROYMACNIC is offline   Reply With Quote
Old 10-31-2012, 03:16 PM   #11784
Bambi
Bambi's Avatar
Oddometer: 722
Hello Roymacnic,
this 'also when I turn on the ignition switch the neutral light etc take a couple of seconds to come on' makes me think of a loose cable at the ignition-key-switch. A common fault on Suzuki DR Bigs (SR 41 and 42). Those have this switch in the tacho-/rev-counter-unit on top of the triple-tree. So the whole unit turns with your handle bar and the cables seem to be too short for this movement and shear off ...
Kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 11-01-2012, 06:13 AM   #11785
@dreamer
@dreamer's Avatar
Oddometer: 142
Alainmax, just out of curiousity what's the deal with using a pressure washer on an Africa twin, I reciently bought one of those small home models with every intention of using it on the twin. Now I wouldn't go spraying directly into electrical connections but I did replace all of the electrical connections with nice waterproof ones from Eastern Beaver so maybe I could.
Keith
@dreamer is offline   Reply With Quote
Old 11-01-2012, 06:48 AM   #11786
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Excessive water pressure is not good for places like bearings and connectors. It should be fine if you didn't point the nozzle directly at those areas.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 11-02-2012, 04:56 AM   #11787
teddy750
teddy750's Avatar
Oddometer: 54
chain too
keep the pressure away from the chain too. i didn't and had to replace it after a couple of months
teddy750 is offline   Reply With Quote
Old 11-02-2012, 06:56 AM   #11788
MrWahlstrom
Oddometer: 9
Hi guys! Really need some advise when it comes to chains and sprockets. What should I get? I dont really know the difference between oring xring and everything else. Just getting more and more confused :) So any suggestions for what I should get? Driving a some dirt but a lot of highway as well with my @ 1999
MrWahlstrom is offline   Reply With Quote
Old 11-02-2012, 07:01 AM   #11789
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 363
I think at least you should get a OEM pinion (drive sprocket) in order to protect your output shaft...
I always get the original OEM kit including drive and driven sprockes and chain... but that's just me.
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin is offline   Reply With Quote
Old 11-02-2012, 07:33 AM   #11790
MrWahlstrom
Oddometer: 9
I will get both front and rear sprocket and a chain. More kind of wondering what type of chain and any particular brand I should get/not get.
Times are GMT -7.   It's 07:23 PM.
