Old 01-07-2013, 04:11 AM   #11971
soolo
soolo's Avatar
Oddometer: 1
Originally Posted by SulytS View Post
I've recently bought a rd04 1990 and was making some strange noise. I decided to open the beating heart of the twini... bang.. cann rod damage, can anyone point mi a good deal on those parts. Piston pin, conn rod, ring set gasket set and if you now anything important please do say.What did they done before????
Hi! I have same problem last summer with my 92 RD 04. Caused by faulty carburettor, fuel leaks to cylinder and when you push the starter button...bang!
soolo is offline   Reply With Quote
Old 01-07-2013, 10:04 AM   #11972
SulytS
Oddometer: 6
Thanks for re-ply, but i think that the reason was the bike ran whit to fukier oil and the lubrication has poor...???but in that case should the conrod the first thin to damage?
SulytS is offline   Reply With Quote
Old 01-07-2013, 10:31 AM   #11973
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 363
Não achas melhor levar a moto a um mecânico?
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin is offline   Reply With Quote
Old 01-08-2013, 05:24 AM   #11974
Mika_AT
Mika_AT's Avatar
Oddometer: 68
Hi
The teaser of Meeting 2012 ATOC (AfricaTwin Transalp Owners Club, french club)
http://vimeo.com/56944917
how to embed video on post ?
Mika_AT is offline   Reply With Quote
Old 01-08-2013, 05:31 AM   #11975
Mika_AT
Mika_AT's Avatar
Oddometer: 68
clip ATOC 2012 from Jocelyn Olivier on Vimeo.
Old 01-08-2013, 06:35 AM   #11976
Squily
Squily
Squily's Avatar
Oddometer: 1,221
Originally Posted by Mika_AT View Post
Looked like lots'o fun
Squily
Squily is offline   Reply With Quote
Old 01-08-2013, 08:54 AM   #11977
Peke
Kloothommel
Peke's Avatar
Oddometer: 127
Originally Posted by twinie View Post
hey guys!
here are a few pics from this weekend's ride, in central portugal!
as you can see, a GREAT place for you to bring all your AT's for a ride!
cheers
Hi Twinie,
Can you please tell me the brand and type of this awesome Red Bull helmet. I would love to have one myself.
Thanks in advance.
Jeden Tag erhöht sich zwangsläufig die Zahl derer die mich am Arsch lecken können.
Peke is offline   Reply With Quote
Old 01-09-2013, 02:37 AM   #11978
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,860
OK you lot ...Kitped needs another 2 buyers before he can place the order for these 50mm fork extensions.
PM him pronto if you're a definite buyer - Kitped
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is offline   Reply With Quote
Old 01-09-2013, 04:32 AM   #11979
lemovice
lemovice's Avatar
Oddometer: 144
exelente la video Mika,c'était la chaine de l'étoile ou la croix de garlaban!
lemovice is offline   Reply With Quote
Old 01-09-2013, 04:44 AM   #11980
Mika_AT
Mika_AT's Avatar
Oddometer: 68
merci, ça dépends a quel moment ?
on a principalement fait marseilles/cassis pour les zones de route; le off-road, n'étant pas de cette région je sais pas te dire
Old 01-09-2013, 12:03 PM   #11981
lemovice
lemovice's Avatar
Oddometer: 144
entre les deux c'est le camp militaire de carpiane,c'est peut-etre ça.
est-ce-que tu vas à l'enduro du touquet !
Old 01-10-2013, 07:28 AM   #11982
ZORBA
Oddometer: 79
Need your help guys...
My bike wouldnt start when hot, changed the fuel pump with a facet, still wouldnt start when hot and now it doesnt start at all, even when cold.
Any help?
ZORBA is offline   Reply With Quote
Old 01-10-2013, 08:37 AM   #11983
Africa_Twin
Africa Twiner
Oddometer: 363
Any help?
Hoo, so much to look for... I suppose the battery and starter are good, and that you have gas in the tank so:
Did you connect the Facet correctly (i.e., the Facet outlet to the carbs and the inlet from the tank? It wouldn´t be the 1st time people revert this...
Also, is there a spark at the plugs? Check this by removing one plug on each cylinder and holding the plug tip real close to the engine head cover. Then crank the engine with the starter button and see if a spark jumps. If it does, then the coils are good...
Check you didn't turn the fuel cock off... I'm just stating the obvious here...
Africa_Twin screwed with this post 01-10-2013 at 08:46 AM
Old 01-10-2013, 08:42 AM   #11984
ZORBA
Oddometer: 79
The bike worked with the facet properly, the tank is full and I guess the reg-rec is fine.
I think I'll check the plugs first.
Could it be a faulty CDI?
Old 01-10-2013, 09:29 AM   #11985
Africa_Twin
Africa Twiner
Oddometer: 363
It could, but the only thing I can think of that would kill your CDI (apart, from maybe using the wrong kind of plugs for a long time and at high speed and a faulty REG/REC giving off high charging voltage) would be a lighting bolt caused by a short circuit somewhere within the CDI circuit wires.
The AT electrical system is protected by fuses, so that is unlikely, unless someone has been tampering with the fuses and changing them for higher Amps... So check the fuses for correct rating and for continuity with a multimeter... wiggle the fuse legs from side to side to make sure there are no micro-cracks in the fuse legs. I've seen that happening with a fuse for the tripmeter... If the fuses are OK, then look at the spark plugs. If you do have a spark jumping from at least one plug from each cylinder, then the coils are good and so is the CDI (at least the side of the CDI that governs the ignition coils).
But the easy way to check for a faulty CDI is to borrow a good-known CDI from a friend's bike, a bike that you know is running OK and installing it on your bike and see if it now runs... Basically, before going nuts, try the obvious and easy things first... pump correctly hooked (don't forget to check the fuel pump relay located to the right side of the REG/REC - this relay is also commanded by the CDI), fuses OK, spark at the plugs... assuming as I said the starter motor runs... if it does, then the clutch and the side stand switches are OK and you don't need to check those...
Times are GMT -7.   It's 04:20 PM.
