Old 01-21-2013, 09:20 AM   #12031
Africa_Twin
Africa Twiner
Africa_Twin's Avatar
Oddometer: 329
Send a message via MSN to Africa_Twin
Originally Posted by ZORBA View Post
Going slightly mad here...
This morning, without doing anything, the bike started...
Then, I disassembled the on-off switch, sprayed it with contact cleaner, went for a short ride and started it a few times.
All went well...
I ll do some more riding to verify tomorow.
Good show!! You mean the ignition switch or the emergency stop switch on the right handle?
Riding to the sunset... on my Africa Twin...
http://i95.photobucket.com/albums/l1...ar/sigATCP.gif
Africa_Twin screwed with this post 01-22-2013 at 02:30 AM
Africa_Twin is offline   Reply With Quote
Old 01-21-2013, 09:21 AM   #12032
ZORBA
Oddometer: 62
The emergency switch on the right handlebar...
I hope it is this one causing the problem.
I''ll test the next few days and report.
ZORBA is offline   Reply With Quote
Old 01-21-2013, 03:40 PM   #12033
Squily
Squily
Squily's Avatar
Oddometer: 1,037
Sorry for maybe asking simething that's been dealt with before, but I'm to lazy to go back and read all teh posts...
Have you checked the side stand switch? Mine has dropped me in the crap a few times till I bypasses it completely. Depending on dirt and water, it can cause intermittend cut-out issues.
Squily
Squily is offline   Reply With Quote
Old 01-21-2013, 10:15 PM   #12034
ZORBA
Oddometer: 62
I have bypassed the sidestand switch many years ago.
Old 01-22-2013, 02:49 AM   #12035
Africa_Twin
Africa Twiner
Oddometer: 329
I now remembered: a few months a go, a friend removed the fuel tank on his Africa Twin and disconnected a few connectors localted under the tank, to the front of the bike, near the thermostast housing. One of those connectors belongs to that on/off kill switch on the right handlebar. He disconnected them to clean them and spray them with contact cleaner but apparently, he failed to connect all of them correctly. You guessed it, the mis-connected connector was the kill switch connector and one day while riding the bike (not very long after removing the tank and luckily to him, not far from his home), the engine simply shut down and wouldn't start again. He pushed the bike home and when looking for possible causes, he found the connector disconnected.
So, have you been disconnecting stuff lately on your bike? Could it be the connector for the kill switch on your bike is poorly connected? Or having bent of ill-connected terminals inside? I would check to see this first as sometimes the vibrations from the engine may cause poorly connected connectors to come completely apart... I actually had this happening to me on the tripmaster connector...
I hope the cause is actually something simple and not too expensive to fix.
Africa_Twin screwed with this post 01-28-2013 at 02:34 AM
Old 01-26-2013, 10:42 AM   #12036
La Case
La Case's Avatar
Oddometer: 25
Hey guys!
I live in France and I've 25. And I am customing an Africa Twin to do in August a trip to Istanbul in Turkey.
I've decided to give a rallye look to my bike and lengthen the suspensions (+7cm). And make a little lightweight.
My Rd04 one month ago :
The tail after painting :
During a jaunt in the mud :
Before / After :
My future color :
It will be finished, I think, in two weeks
See you soon
La Case is offline   Reply With Quote
Old 01-27-2013, 12:38 AM   #12037
Danielmoben
Danielmoben's Avatar
Oddometer: 24
Nice!!!!!!!
Danielmoben is offline   Reply With Quote
Old 01-27-2013, 02:25 AM   #12038
Dutchy506
Oddometer: 31
Thumb
wicked!
what kind of fairing are you planning to use?
Dutchy506 is offline   Reply With Quote
Old 01-27-2013, 03:04 AM   #12039
La Case
La Case's Avatar
Oddometer: 25
thks guys.
I do my rally front Fairing. I work in fiberglass tech. Here in France, I will make a limited production of rally fairing for my local AFRICA Owners Club.
Old 01-27-2013, 03:28 AM   #12040
lemovice
lemovice's Avatar
Oddometer: 132
Originally Posted by La Case View Post
thks guys.
vien nous voir l'ami
http://africatwin.forumactif.com/
tu sera le bienvenu
lemovice is offline   Reply With Quote
Old 01-27-2013, 08:37 AM   #12041
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,270
Wonderful color choices LaCase. A great looking fairing.
Can we see photos from other angles. i'd like to see what you've done with the headlamps etc.
Would you post photos as you build up the Rallye fairings?
Will you base the fairings on the RD03/04 tank and bodywork or will they be based on the RD07?
I would be interested in more detailed information and possibly a purchase if the fairing will adapt to the RD03/04 platrform.
Ladder106 is online now   Reply With Quote
Old 01-27-2013, 08:55 AM   #12042
La Case
La Case's Avatar
Oddometer: 25
thks LADDER (et merci LEMOVICE, dès que j'ai un peu de temps, je fonce vous voir sur ton forum)
My fairing fits on RD04/03, I havent do the model for RD07 yet.
It is a one piece fiberglass fairing with 3 fiber skins, and GELCOAT surface finishing.
Instalation is easy because it uses origin mouting supports. (It just needs to bend forward the 2 front IronTube supports of the windscreen to fit correctly to the RallyFairing)
I've doing an image to show you:
I will paint all my fairing during next week. I'll so give you more picture of my work.
As soon as I finish my Africa, in fews weeks, I'll start the production of the RD04/03 RallyFairing.
Next trip 2013 France -> Turkey
Old 01-27-2013, 09:05 AM   #12043
Ladder106
Ladder106's Avatar
Oddometer: 4,270
Right,
I've had that front fairing on and off quite a few times, so I'm familiar with how this will work.
Just changing the front fairing and leaving the standard side fairing is a very nice concept and should be easy to both work with and to be able to change back to the standard Honda piece of necessary.
I'm very interested in one of these.
Do you have any prices in mind for a purchase?
Old 01-27-2013, 10:16 AM   #12044
gpmucci
gpmucci
Oddometer: 165
Ciao!
One week and I'll use it:
gpmucci is online now   Reply With Quote
Old 01-27-2013, 10:23 AM   #12045
Jim Rowley
Now what?
Jim Rowley's Avatar
Oddometer: 2,253
Art on two wheels!!!
Jim Rowley
Colorado Springs, CO
M. A. P.
Jim Rowley is offline   Reply With Quote
Times are GMT -7.   It's 01:51 PM.
