02-15-2013, 11:09 AM
#12121 |
ca vaut le detour !!
Oddometer: 573
...and i'm now waiting another 24 years to ship a 660 Tenere overhere !!! let s keep in touch , Wayne
04 GS 1150 93 Africa twin RD07 |
02-15-2013, 12:16 PM
#12122 | |
Oddometer: 1,203
Hopefully it will look like Jim's from Eastern Beaver. His pic. ![]() My task today is to install the following.
1999 XRV 750 Africa Twin 1996 XL 600v Transalp "Almost no other bike has the road presence of the Africa Twin and cars seem to melt out of its way, once they see the angry glare of its lights in their mirrors." ... |
02-15-2013, 06:59 PM
#12123 |
Oddometer: 93
Is that an FH008?
02-15-2013, 07:41 PM
#12124 |
Oddometer: 1,203
It's actually the FH020AA. More here at an earlier post #11863
Anyhow...I just finished the install and am quite pleased. Fired it up and it was still putting out 14.4 vdc with grips and lights on. One of the old connectors ( 3 wires/3 phase yellow) had evidence of overheat but no real damage. That connector gets changed with the new generation Delphi connector from Eastern Beaver (see pic). Those are the only 3 wires you solder for the whole install and then it all just snaps in.
02-16-2013, 07:27 AM
#12125 |
Oddometer: 93
How did the final install go? IIRC the 12 and 20 are a bit taller. I believe Jim originally installed an FH008 on is AT as it is closest to the stock size. I picked up an FH008BA and hope to do a direct plug and play, but it's going to take a little tinkering to get it there.
02-16-2013, 10:33 AM
#12126 | |
Oddometer: 1,203
I thought the FH008 had the same foot print and mounting holes as the 0012/0020 and it's the 0010 and 0011 that are taller? Anyhow, the 0020 that I installed now supercedes the 0012 which has the same dimensions and specs but with some minor changes to the heat sink casting. The 0020 fit nicely on my RD07A as you can see in the pic. Notice the old white round connector in the middle which is not used now. I blanked off the inside with a plastic plug. Tie wrapped below that is the new Delphi 3 yellow wire connector (no particiular order). The hole you see between green and white connector was where the old 3 yellow wire connector lived. That connector gets tossed and was prone to overheat and high resistance. To the left and in front of the starter relay you can see the new 30 amp fuse holder and the black and red wire that now go directly to the battery. In the end their are a total of 5 wires that you need to pinch and solder (3 phase yellow) and the 2 pos/neg wires to the battery. I say "pinch and solder" because that was my method as I did not have a fancy crimper. Carefully bend the wire tabs over with some small needle nose pliers followed up with a dab of solder. Jim has a link here. pinching and soldering This is an easy and worthwhile mod IMO and certainly a preventative one if your running old connectors that could can be prone to high resistance and eventual meltdown. The MOSFET is more effecient and produces less heat at the R/R so that the mounting/cooling is not so much an issue anymore.
1999 XRV 750 Africa Twin 1996 XL 600v Transalp "Almost no other bike has the road presence of the Africa Twin and cars seem to melt out of its way, once they see the angry glare of its lights in their mirrors." ... GSPD750 screwed with this post 02-16-2013 at 12:56 PM |
02-16-2013, 12:27 PM
#12127 |
Oddometer: 93
That looks good. Thanks for the pic. Mine is a 7 wire set up so it's a bit different.
mechahayai screwed with this post 02-16-2013 at 03:27 PM |
02-18-2013, 12:04 AM
#12128 |
Oddometer: 64
Can these R/R charge a lithium battery?
02-18-2013, 06:04 AM
#12129 | |
Oddometer: 6
THIS IS BRILANT...
![]() Quote:
02-18-2013, 12:48 PM
#12130 |
Oddometer: 1,203
I don't see why not but I'm still digesting all that lithium battery stuff. Their certainly is a considerable amount of weight to be saved thats for sure.
See links below...yeah....to much to read. Shorai Motorcycle Battery vs. Ballistic Motorcycle Battery Comparison - webBikeWorld http://www.batterybusiness.com.au/products/lithium Shorai LFX14A1-BS12 Battery - £129.95 Ballistic Battery 12V LiFePO4 8 Cell EVO 2 Vehicle Replacement Batteries for Motorcycles, ATV, Watercraft, Snowmobile, Utility Vehicle Ballistic Battery 12V LiFePO4 EVO 2 Review - YouTube Ballistic Battery EVO2 Review at Motochanic.com - YouTube Shorai Lightweight Motorcycle Battery Review - Make your motorcycle 4 pounds lighter. - YouTube
02-23-2013, 08:25 AM
#12131 |
Oddometer: 29
Shock rebuild
Hi, anybody in the UK had an RD04 shock rebuilt? I've got a few possibilities to have this done but was wondering if anyone had any recommendations,where you have had a good service or anybody that should be avoided,thanks, Roy.
Roymacnic |
02-24-2013, 05:48 AM
#12132 |
Oddometer: 25
many news on the official Africa-twin TRIP public page ;)
like it if you use FB we need to have a lot of followers to ask sponsorings https://www.facebook.com/tripmoto2013 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Next trip 2013 France -> Turkey
02-24-2013, 05:51 AM
#12133 |
Oddometer: 25
Me and my Half-build AT Rallye, 'll be paint soon
02-24-2013, 09:33 AM
#12134 | |
Farkle Tart
Oddometer: 501
Before ![]() After
www.ruggedroads.com Honda XRV750 Africa Twin RD07A - Rugged Roads Rallye Sport, Honda XRV750 Africa Twin RD04 - HRC BMW R1150GS - Graphitan Yamaha XT600Z Tenere 3AJ - BYRD, Aprilia Moto 6.5 - Starck Orange, Cagiva N90 - Lucky Explorer 'Maybe I'm just simple - but can't we all just get along..........' |
02-24-2013, 12:17 PM
#12135 |
Oddometer: 29
Thanks for that Stormforce8,thats just what I'm looking for.
Roymacnic |
