Old 08-09-2013, 01:13 AM   #12646
Oscarr
Oddometer: 2
Spacer
Originally Posted by Fliegenfischer View Post
The other way.
Hi all! New on the forum.. . Hope the link above worked. I am looking for a drawing of a spacer like this (+15mm). Anyone got one or can provide the measurements? Or maybe there'se a maker out there?
// Oscar
Oscarr is offline   Reply With Quote
Old 08-09-2013, 07:16 AM   #12647
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,176
Link
What link?
Reidy008 is online now   Reply With Quote
Old 08-09-2013, 09:09 AM   #12648
Oscarr
Oddometer: 2
I tried to reply to a post where there was a picture of a rear shock extension clamp...
Old 08-11-2013, 07:50 AM   #12649
L3on
Big nOOb
Oddometer: 62
Started with cleaning the rear-end of the bike
With the wheel removed.
After 1 hour of cleaning.
Ordered a 17T front sprocket, For the highway miles.
I don't know where the jerney will end, but I know where it starts
L3on is offline   Reply With Quote
Old 08-12-2013, 04:00 PM   #12650
al bowlly
Oddometer: 40
Originally Posted by Africa_Twin View Post
There is a breathing hose that sits between the carbs. If this tube is mis-located the bike will lose power at a given rpm range. When deisassembling/reassembling, it's easy to mis-locate this tube with another breather tube that sits closer to the rear damper unit, only in a lower position that the first breather tube... originating hesitation and power-cutting problems. I recently came across an AT with this same problem... it's worth checking this.
From all the descriptions, the other thing I can think of are the ignition coils themselves, or the spark plugs cables...
Africa Twin,
Thanks for the leads. I'm in Tokyo until the weekend but on return I hope to get started with the suggestions list I've received here. Your symptoms sound the same.
Tom
al bowlly is offline   Reply With Quote
Old 08-13-2013, 02:25 AM   #12651
*thomas*
*thomas*
*thomas*'s Avatar
Oddometer: 170
selling with regret :(
For sale is an unfunished Africa Twin XRV650 Marathon Replica (in other words, a replica of the factory marathon bikes that ran the dakar from 1988 till 1990).
The bike has had a complete stripdown, and the frame has had a sandblast and new powdercoating. Many parts have been changed, using Honda spares or very good quality parts, this is just a short list of what has been done:
- wilbers fully adjustable rear shock and new bearings and bushes in prolink - wilbers front springs, oil and new seals
- new fuel pump and fuel pomp relay
- new set of CDIs
- new front wheel
- new tyres (TKC80) and tubes
- new EBC disks and pads
- complete brake master cilinder and caliper overhaul
- HEL brake lines
- new marving silincer
- new filters, spark plugs, oil and coolant
- new chain and sprocket set
- new set of handle bars
- new EBC clutch set
Why is it a marathon?
- front 42L tank
- rear 17L tank (side covers are included)
What needs to be done?
- saddle made to fit
- side stand made to fit
The bike is fully running. The carbs have been cleaned, inlet manifold changed and everything synchronised.
The bike has been build over the past 4 years, but I simply don't have the time to finish the project. I am selling it with regret, but letting a bike gathering dust in the shed is a waste.
I am open to offers, as long as they are reasonable and I prefer talking this over in front off the bike. Viewing is more than welcome. The bike is located near Brussels.
for more pictures or info: thomassalute at hotmail dot com
WKR Thomas
Africa Twin XRV650 (project bike)
Cagiva Elefant 900 AC (almost finished)
Aprilia TXR312M (project bike)
*thomas* is offline   Reply With Quote
Old 08-13-2013, 10:40 AM   #12652
Atwin
Atwin's Avatar
Oddometer: 12
I just recently bought an RD04 ; black & red from Austria, it has only 47 k.
I bought it because I want to build a rally replica of some sort during this winter.
Any similar projects running or have been done ? Any photos or ideas?
I want to do following:
- raise it for a few cm
- rally fairing
- new color scheme + stickers
- knobby tyres
- perhaps some small decals and add-ons
Sorry if I opend this topic again, but I don't want to view all 800 something posts on this tread
Thanks to all
Atwin is offline   Reply With Quote
Old 08-14-2013, 10:36 AM   #12653
Fliegenfischer
Fliegenfischer's Avatar
Oddometer: 43
http://www.atoc-moto.com/forumm/view...hp?f=12&t=1924
- rally fairing
- knobby tyres
Thanks to all
Fliegenfischer is offline   Reply With Quote
Old 08-14-2013, 10:42 AM   #12654
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Anyone have a pdf copy of an RD04 manual? I could use a replacement. Thanks.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 08-14-2013, 11:13 AM   #12655
Belgian Waffles
Oddometer: 874
I'll send you the PDF I have when I get home today. I think it's the Clymer one that has all AT and TA except for RD03.
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying.
Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials
Past: 1999 KLR 650, 1990 Tengai 650
Belgian Waffles is offline   Reply With Quote
Old 08-14-2013, 11:14 AM   #12656
Belgian Waffles
Oddometer: 874
I've just been made aware of the RD0 1/2
http://planetminis.com/forums/attach...3&d=1327013472
Old 08-14-2013, 11:23 AM   #12657
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Merci J.
Jim Rowley
Black Forest, CO
Old 08-14-2013, 01:37 PM   #12658
Atwin
Atwin's Avatar
Oddometer: 12
Excellent, thanks mate!
Anyone willing to sell front rally fairing for RD04 ? Can be used, I don't mind, as long it isn't broken.
or maybe just get it custom fabricated...
Old 08-14-2013, 04:39 PM   #12659
2old2Bbold
was 2bold2getold
Oddometer: 1,692
Looks like these guys can make you one.... http://www.perfect-fairings.com/en/p...y-fairing-_113
2old2Bbold is offline   Reply With Quote
Old 08-15-2013, 10:34 AM   #12660
Atwin
Atwin's Avatar
Oddometer: 12
Cool! Thanks!
Mixed feelings regarding the position of lights thoe. Horizontal dual lights look much better than vertical.
Would have to customise it for AT standard dual lights. OR, just tear apart the original AT fairing and add front fiberglass panel. Would probbably be cheaper also.
Anyone knows how to raise the thing using standard suspension and front forks?
Times are GMT -7.   It's 05:49 PM.
