Old 10-01-2013, 05:19 AM   #12781
tserts
Chaotic Neutral
tserts's Avatar
Oddometer: 2,706
Originally Posted by twinie View Post
Front page material right there.. (although it's not an @ :p)
BMW F 800 GS 2010 - My Brunhilde
New toys to brake!
Road Rush (Romania, Serbia)
Peloponnese Peninsula on two Africa Twins
9 countries in 15 days - Tserts.eu
tserts is offline   Reply With Quote
Old 10-01-2013, 09:32 AM   #12782
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,002
The rocky rutted sections are very similar to my immediate riding area. Limited though it is, you have to be very much on your game to get a bit trailie through those sections.
I also had to remember that it never looks as steep on camera as it truly is.
Impressive riding.
The last time the Dakar was held in europe/africa (2004 IIRC) early sections went through Portugal. I remember thinking that is was a great place for off-road riding and wondering if areas like that were open or were only used with special permission for the Rallye.
Ladder106 is offline   Reply With Quote
Old 10-01-2013, 12:13 PM   #12783
mechahayai
Oddometer: 142
Sprocket Carrier Bearing
I've got my wheels taken down for a bit of PM and it feels like my sprocket carrier bearing is on the way out. Axle bearings are fine. Does anyone have an alternate US part # for the sprocket bearing? I believe the UK part # is 6204-2RS1/C3. I'm also looking at replacing the seal as well, but I don't have the part number for that. I'm wondering if the WR650R bearings will work.
mechahayai is offline   Reply With Quote
Old 10-01-2013, 12:59 PM   #12784
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Take your bearing for a match to:
Whisler Industrial Supply
3399 N Cascade Ave
Colorado Springs
(719) 475-7217
www.whislerindustrial.com
Much cheaper.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 10-01-2013, 01:37 PM   #12785
Joz
What could go wrong?
Joz's Avatar
Oddometer: 1,884
Yup. I've used Whistler in Denver. They're great.
Africa Twin, CRM250-AR, TLM220R, CT90, SY250
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Joz is offline   Reply With Quote
Old 10-01-2013, 01:40 PM   #12786
mechahayai
Oddometer: 142
Thanks Jim! This is my first bearing job, but I figure I'll replace them all while I'm at it. Is there an easy way to drive all the bearings out of the hub? The XRVforum 'push the sleeve aside and drive the bearing out with a drift' method isn't working for me. I can't get it moved aside enough to get a good bite. Maybe I need a new brass drift.
Old 10-01-2013, 01:48 PM   #12787
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
I used to have a bearing tool.
Jim Rowley
Black Forest, CO
Old 10-01-2013, 02:09 PM   #12788
raoulserban
vrrummm
raoulserban's Avatar
Oddometer: 100
Hello. Has anyone a clue how i can get a rd03 swingarm. I need one for my project.thx
raoulserban is offline   Reply With Quote
Old 10-01-2013, 03:08 PM   #12789
GSPD750
GSPD750's Avatar
Oddometer: 1,454
My notes tell me the sprocket bearing is 6204-2RSH/C3 for RDO3/4/7 which are already sealed. Use a quality Japanese bearing such as SKF. Watch out for a cheap China version.
For pulling i like to use a blind bearing puller...or a slide hammer set up. A brass drift can work to. For installation put the bearing in the freezer prior to installing after heating the hub with a heat gun. It should just drop right in with light taps. If you have to hammer in a sealed bearing during installation such as this one then you are doing it wrong and risk damage and will only be replacing it again shortly down the road.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 screwed with this post 10-01-2013 at 05:06 PM
GSPD750 is offline   Reply With Quote
Old 10-01-2013, 03:18 PM   #12790
GSPD750
GSPD750's Avatar
Oddometer: 1,454
Swingarms for an RD07 seem readily available...for an RD03 you may have to search a little harder.
http://www.ebay.de/sch/i.html?_odkw=...garm+&_sacat=0
Old 10-01-2013, 04:45 PM   #12791
mechahayai
Oddometer: 142
You should be able to find what you need in/near Greece.
Old 10-01-2013, 09:14 PM   #12792
SD Splash
Oddometer: 47
Africa Twin RD04 Fuel Tank: Stock or Non-Stock
AT Members: I've scanned the AT forums and Internet sites for an application of the bolt mounts on my AT's fuel tank. They appear to be uncommon and I would like to learn if this is a stock fuel tank or an after-market fuel tank. I don't think the mounts are for a map pocket or panel. Could the mounts possibly be for an aftermarket air intake or snorkel? Please reply if you can confirm if this is a Honda OEM tank or an aftermarket tank. Sorry for the poor quality of the images. Thanks in advance! Splash
SD Splash is offline   Reply With Quote
Old 10-01-2013, 11:40 PM   #12793
raoulserban
vrrummm
Oddometer: 100
Hy, did not find any rd03 swingarm in ebay.gr, de, co.uk ,at etc. only one in. it but do not like it :(
The tank looks to be from a rally/marathon africa twin (made by Honda) , late 80'2, early 90's. There you would fit the map, and other stuff. It is original from HRC. you got something there
http://www.youtube.com/watch?v=fnEHAjt_XPw
Uploaded with ImageShack.com
Old 10-02-2013, 06:10 AM   #12794
Gian
dreamer
Gian's Avatar
Oddometer: 1,221
Indeed it could be an original Africa Twin Marathon tank, if so... where the hell you find it? Would be nice to have some more photos, though!
Gian is offline   Reply With Quote
Old 10-02-2013, 03:13 PM   #12795
SD Splash
Oddometer: 47
Gian/raoulserban: Hello and thank you for your replies. Well, your responses are interesting since the motorcycle also has a stock-looking crossbar to reinforce the fairing & windshield, a cut-out of the air-filter on the left side panel for easy access/replacement, rear brackets to mount small leather 80's-ish toolbags off the rear subframe and headlight grill/guard mount. It would be interesting to learn if this specific Italian Africa Twin motorcycle participated in any rally racing.... not sure if that would be good for longevity of the engine. Btw, did HRC include any performance upgrades on XRV750 rally motorcycles? Thanks again! Splash
SD Splash screwed with this post 10-02-2013 at 04:21 PM
Times are GMT -7.   It's 02:39 AM.
