Old 04-16-2014, 06:07 AM   #13366
amageo929
amageo929's Avatar
Oddometer: 13
amageo929 is offline   Reply With Quote
Old 04-16-2014, 09:54 AM   #13367
E-Bum
E-Bum's Avatar
Oddometer: 715
Originally Posted by GSPD750 View Post
You risk having an oil leak should you leave that old gasket residue on. Isopropyl alcohol will soften it up and then find yourself a sharp sturdy plastic scraper (no metal) and some elbow grease. You could also shop for some "Gasket Remover" in an aerosol can at your local auto supply. Yeah it's a pain.
What's this Itilian gasket you speak of? I thought they were all paper.
It's the one sold for the RD03 at Wemoto; http://www.wemoto.com/bikes/honda/xr..._cover_gasket/
Haven't opened it yet, so I'm not sure of the material. I wasn't able to source an OEM one, or else I would have gone with that. By the way, what is the original gasket made from? The one I am losing my finger nails to seemed to be some sort of fiber...
In other news, I'm replacing the clutch now. One advantage of having the engine out of the frame is that to remove the clutch lock nut, I just throw it into the car, head down to the auto shop and use their impact gun.
Only concern at the moment is for the state of my clutch center. The interior finish seems to be damaged. Not sure how this happens... heat? I hope it to be only superficial, nothing looks like structural cracks. I would like to hear your opinion though. The outer basket also shows signs of wear where the friction disks contact the 'teeth' of the basket.
Clutch center damage.
Outer clutch basket (can't see actual wear in pics).
E-Bum is offline   Reply With Quote
Old 04-16-2014, 10:28 AM   #13368
GSPD750
GSPD750's Avatar
Oddometer: 1,447
Hello ebum....double post Re: staked clutch nut.
http://www.xrv.org.uk/forums/africa-...tml#post897505
That gasket from Wemoto is a standard paper one. honda p/n 11394-MV1-850
Your Honda dealer should have it as it's the same p/n for a Honda Shadow and the Transalp.
Do you have the Haynes Manual?
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 screwed with this post 04-16-2014 at 10:33 AM
GSPD750 is offline   Reply With Quote
Old 04-16-2014, 10:49 AM   #13369
E-Bum
E-Bum's Avatar
Oddometer: 715
My parts fiche says the R crankcase cover gasket is 11394-mr1-000. I searched my Honda dealer's site and Partzilla, but it is unavailable: http://www.partzilla.com/parts/detai...4-MR1-000.html
Didn't know 11394-MV1-850 existed... I suppose it must have superceded the 11394-mr1-000 I was searching for. I suppose if it fits a 1988 NT650, it should work on the RD03.
I don't have the Hayne's. Don't think there is one for the XRV 650. I am using the Honda Workshop manual though, which is great.
About the photo. I wasn't talking about the staked clutch nut, already got one of those. I am talking about the wear you can see in the cast aluminum at the base of the spring posts. In the photos it looks like it's only oil perhaps, but it is actually oil seeped into cracks that seem to have formed in the piece's finish. I just found that the part is $65, so not terrible. Just wonder if it's worth replacing...
Old 04-16-2014, 01:04 PM   #13370
GSPD750
GSPD750's Avatar
Oddometer: 1,447
Ooops...sorry my bad. Ohhh...the casting imperfections. I'm sure I've seen that before. Cant remember if it was my TA or my AT clutch. I don't think it's so unusual. Someone concur with me here as I'm sure I have seen that on a clutch basket. Providing it's not flaking off it's probably nothing to worry about.
Ok....'88 XRV 650. Yes it's the same p/n for the r/h side cover gasket.
http://www.bike-parts-honda.com/piec...+TWIN+650.html
Old 04-16-2014, 01:36 PM   #13371
E-Bum
E-Bum's Avatar
Oddometer: 715
Brilliant, thanks for giving me that cross-reference... I should have been more robust in my initial searches.
I made sure the surface wasn't flaking off, so it may be casting imperfections, like you say. Now that you mention it, I believe I remember seeing similar imperfections in small recesses while sanding the crankcase. I can't envision another explanation.
Old 04-16-2014, 03:55 PM   #13372
gpmucci
gpmucci
Oddometer: 250
I need you help!
I try different colors.
These are the two I like more.
What do you prefer?
Inviato dal mio iPad utilizzando Tapatalk
gpmucci is offline   Reply With Quote
Old 04-16-2014, 04:10 PM   #13373
2old2Bbold
was 2bold2getold
Oddometer: 1,734
Originally Posted by gpmucci View Post
I need you help!
What do you prefer?
This one.
2old2Bbold is online now   Reply With Quote
Old 04-16-2014, 10:11 PM   #13374
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,986
Red, White and 2 Blues.
The black hides your beautiful curves.
Ladder106 is offline   Reply With Quote
Old 04-16-2014, 11:22 PM   #13375
ray3656
Oddometer: 81
Originally Posted by 2bold2getold View Post
This one.
HRC colours suit it best
ray3656 is offline   Reply With Quote
Old 04-16-2014, 11:46 PM   #13376
jjdavidson
jjdavidson's Avatar
Oddometer: 46
My vote to red white blue :)
jjdavidson is offline   Reply With Quote
Old 04-17-2014, 01:04 AM   #13377
catweasel67
Oddometer: 8,856
Which just happens the colours of the 1991 AT that I finally took hold of today :) Pictures (and, no doubt, countless noob questions) to follow when I've time.
catweasel67 is offline   Reply With Quote
Old 04-17-2014, 06:26 AM   #13378
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
What do you prefer?
Red, white and blue. Bleu blanc rouge. Rosso, bianco e blu.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 04-17-2014, 01:52 PM   #13379
Ladder106
Ladder106's Avatar
Oddometer: 4,986
E-Bum,
Are those casting "imperfections" small raised ridges or actual cracks. Hard to tell from the photo.
If they are ridges - you're OK. If cracks your should replace the part.
I'm betting they are ridges since I have them on my TA castings also. They seem to occur in tightly angled or curved areas. Seems to just be part of the casting process.
For AT parts, try David Silver Spares in the UK. They seem to ship to the USA with reasonable prices.
Old 04-18-2014, 01:58 AM   #13380
lukasteam
Life is beautiful !!!
lukasteam's Avatar
Oddometer: 519
I need you help!
What do you prefer?
I like the black one
lukasteam is offline   Reply With Quote
Times are GMT -7.   It's 04:54 PM.
