09-16-2009, 10:41 AM
#1 |
The Stuffman
Oddometer: 3
NEED 1971 CB350 Carb/Diaphragm
Hello.
I have a classic 1971 Honda CB350 that I recently restored to an almost-new condition. Although, I reused the carburetors. The diaphragms looked great when I was rebuilding the carburetors, but now the right side of the engine sounds horrible. (and I'm certain that is is the diaphragm) I'm looking to buy [preferably a pair of] diaphragms to replace my current ones. Or if anyone has carbs available that have good diaphragms, that will work as well. If anyone has these parts to sell, or knows a place where I could buy them, I would really appreciate it. btw, sorry if this post is in the wrong section or something. Thanks, Stuff180 ![]()
Stuff180 screwed with this post 09-16-2009 at 10:57 AM |
09-16-2009, 11:55 AM
#2 |
Aspiring advrider
Oddometer: 3,345
You can probobly find them at http://www.siriusconinc.com up in Canada. If you do order keyster kits, ensure you measure the parts for accuracy vs. stock and plan to order some OEM gaskets as the Keyster ones run big and can obstruct the floats.
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub "Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer |
09-16-2009, 06:21 PM
#3 | |
Oddometer: 613
Diaphrams are tough to find without buying old carbs and hoping for the best. As someone else posted, siriusconic has 'new' replacement ones - they're the only supplier that I know of and they work well from what I've heard (you glue them on), but they sure aren't cheap. What makes you so sure it's the diaphrams? I assume it's running lean when you get on the throttle? A crack in the rubber on the intake side of the carb could cause the same problem. |
09-16-2009, 06:25 PM
#4 |
I reckon so
Oddometer: 1,037
Give these guys a try.....
2006 KTM 640 Adventure ![]() 2013 HusabergTE300 |
