Old 11-10-2009, 01:36 PM   #31
canadaler
canadaler's Avatar
Oddometer: 339
Originally Posted by Flashman1
I would hate to think the new bike gained 30 pounds.
Yeah...kind of hard to believe that isn't it?
Maybe the swingarm isn't just anodized black but is made of steel....
'10 Gas Gas EC300
'08 Husaberg FE550
'09 Husqvarna TXC250
'84 Honda VT500FT Ascot
Tuareg Rally 2009
canadaler is online now   Reply With Quote
Old 11-10-2009, 01:37 PM   #32
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,351
[/LEFT]
and painted with Lead Based paint
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE
Robert
rwamf homepage
rwamf is offline   Reply With Quote
Old 11-10-2009, 01:53 PM   #33
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
new double overhead cam set up...
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 11-10-2009, 05:54 PM   #34
switchback
Eatin' Dirt Since 1982
switchback's Avatar
Oddometer: 1,485
Technical specs
http://resmarket.com/husqvarna/images/10HusqTE630.pdf
Dimensions, Weight, Capacities
Wheelbase......................................... ............1485mm / 58.46 in
Overall length............................................ .....2260mm / 88.98 in
Overall width............................................. .......820mm / 32.28 in
Overall height............................................ .....1240mm / 48.82 in
Seat height............................................ ...........945mm / 37.20 in
Min. ground clearance.....................................300m m / 11.81 in
Trail............................................. .......................115mm / 4.53 in
Dry weight............................................ .......... 150Kg / 330.7 lbs.
Fuel tank capacity.....................................12L / 3.17 U.S. Gallons
Transmission oil.......................................... 2L / 2.11 U.S. Quarts
Engine
Type...................................... single cylinder, 4-stroke, 4V DOHC
Bore.............................................. .....................100mm / 3.94 in
Stroke............................................ ................... 76.4mm / 3.01 in
Displacement...................................... ..................600cc / 36.6 in
Compression ratio............................................. ................. 12.4:1
Starting.......................................... ................................... electric
Cooling........................................... ..........................liquid-cooled
Radiator.......................................... ..............two with electric fan
Timing system
Lubrication.................. wet-sump with oil pump & cartridge filter
Ignition.............. electronic, inductive discharge, w/digital control
Spark plug type .................................................. ...... NGK CR8EB
Spark plug gap................................. 0.7-0.8mm / 0.027-0.031 in
Fuel system............................................ . electronic injection feed
Throttle body.............................................. .............. MIKUNI D45
Clutch..................................... wet, multiplate; hydraulic actuated
Driving disc no................................................ ........................... 8
Driven disc no................................................ ............................ 7
Primary drive
Engine sprocket.......................................... ........................... 32T
Clutch gear.............................................. ............................... 75T
Transmission ratio............................................. ................. 2.343
Transmission type..................................constant mesh gear type
Speeds............................................ ........................................... 6
Internal ratios
.................................................. .......................1st 2,615 (34/13)
.................................................. ......................2nd 1,812 (29/16)
.................................................. ...................... 3rd 1,350 (27/20)
.................................................. ...................... 4th 1,091 (24/22)
.................................................. ...................... 5th 0,916 (22/24)
.................................................. ...................... 6th 0,769 (20/26)
Secondary drive
Countershaft sprocket.......................................... .................. 15T
Rear wheel sprocket.......................................... ..................... 42T
Transmission ratio............................................. ................. 2,800
Driving chain........................................... DID 520 V6 (5/8”x1/4”)
Overall ratios
.................................................. ................................. 1st 17,163
.................................................. ................................ 2nd 11,894
.................................................. ................................... 3rd 8,859
.................................................. ................................... 4th 7,159
.................................................. ................................... 5th 6,016
.................................................. ................................... 6th 5,048
Chassis
Main frame............................................. ..Steel single tube cradle
Sub-frame............................................. ........................aluminum
Front suspension.................................45mm Marzocchi Upside-
Down” with advanced axle; rebound stroke adjustment
Front wheel travel ........................................... 270mm / 10.63 in
Rear suspension........................... Progressive “Soft Damp” type
with single SACHS shock absorber; spring preload adjust,
compression and rebound adjustment (compression stroke:
double adjustment)
Reaer wheel travel............................................ . 320 mm / 12.6 in
Front brake...........disc with hydraulic control and floating caliper
Front brake disc diameter................................260mm / 10.24 in
Rear brake.................................. fixed disc with hydraulic control
Rear brake disc diameter.................................. 220mm / 9.45 in
Front wheel rim............................................... 1.6 x 21 aluminum
Rear wheel rim..............................................a luminum 2.15 x 18
Front tire......... 90/90x21 PIRELLI MT 21/METZELER MCE Karoo
Rear tire.........140/80-18 PIRELLI MT 21/METZELER MCE Karoo
Electrical system............................................ ....................... 12 V
Head light .................................................. .................. 60 / 55 W
Pilot light .................................................. .............................5 W
Tail light............................................. ....................................LED
Stop light............................................. ................................21 W
Turn signals........................................... ..............................10 W
Battery........................................... ..............................12 V-14Ah
David
Wind is strong and cold
Rain blurs the winding road ahead
I live on two wheels
switchback is offline   Reply With Quote
Old 11-10-2009, 06:03 PM   #35
Flashman1
Flashman1's Avatar
Oddometer: 5,361
Somehow it picked up 30 pounds - has to be more than the dual exhaust.
Flashman1 is offline   Reply With Quote
Old 11-10-2009, 06:12 PM   #36
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
wow they dropped the ball on this one.
same shitty airbox too.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 11-10-2009, 06:30 PM   #37
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,368
Nice looking bike but thinking about the weight my 610 is still my friend.
Kinda reminds me of all the hoopla when the 08 KLR was anounced. The 08 KLR, it seems to me, was 30 or 40 pounds heavier.
This 630 is a whole new and hopefully better design (easier vqlve checks with the 2 cam cover) but a bunch heavier none the less. Thirty pounds is close to the difference between my TE 450 and my 610 and believe me, I notice it.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 11-10-2009, 07:03 PM   #38
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,351
But they removed the lower intakes.
Robert
rwamf homepage
Old 11-10-2009, 07:05 PM   #39
Wattner
Wattner's Avatar
Oddometer: 5,312
My SCHWIIINNNGGGG!!!!!! Has turned to schwaanngggg..... :-(
Come on 300+ lb.s STILL?????? Pump the 530 up to 600cc's or more and we have gotten somewhere...
Damn, I really had hopes
Wattner is offline   Reply With Quote
Old 11-10-2009, 08:49 PM   #40
K7MDL
TE450, TE610
Oddometer: 1,552
Noticed the picture above has a small tank under the air filter and rear brake reservoir where the clutch arm used to be. The cap is similar to the coolant tank on my '07.
K7MDL is offline   Reply With Quote
Old 11-10-2009, 09:19 PM   #41
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,270
Dry weight 330.7 pounds. My DR650 is 324 pounds dry. I am interested in a lighter big thumper Mr Motorcycle Manufacturers. Fail.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 11-11-2009, 03:32 AM   #42
mousitsas
mousitsas's Avatar
Oddometer: 2,786
There is no way your dr650 is 324 dry, unless you believe the specs. The husky on the other hand give accurate measurements.
The 610 of yesteryear was 140kgr dry exaclty.
The new one is 150kgr.
difference is 10kgs or 22 lbs.
loose the twin exhaust should you want, and the difference will drop at under 10lbs. No big deal.
PS the dr650 if I remember well is 160kgs true weight dry.
Old 11-11-2009, 04:10 AM   #43
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,197
+1
If your going to spend around $9000 for the TE630, it better be lightweight. Looks like the 510 enduro would be a better choice, plus it has black wheels. What are the MSRP for all the Huskys?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 11-11-2009, 06:18 AM   #44
30Bones
30Bones's Avatar
Oddometer: 4,639
Originally Posted by D.T.
+1
Fail, you want a lightweight bike, buy a lightweight bike. Any 600cc is not going to be "light". With light comes race specs and race maintenance. You choose. I soooo wanted a plated 450 until I realized the maintenance and the fact that I hate trailering my junk. So a big thumper is what I got.
450's and 510's are more spendy than the 610 IIRC and are more "race type" maintenance
09-10 TE450 MSRP $8299
09-10 TE510 MSRP $8599
09 TE610 MSRP $7999 (2010 630 price no out yet)
30Bones is offline   Reply With Quote
Old 11-11-2009, 06:40 AM   #45
LukasM
Oddometer: 5,418
Define dry.....
The DR weighs 156kgs with all operating fluids except fluid. The claimed dry weight (a pretty useless number anyway) difference is in line with what that of other manufacturers.
Times are GMT -7.   It's 06:51 PM.
