Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 03-02-2010, 07:31 PM   #781
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,277
can you post a better quality pic of that wiring diagram Gus?
Ive got pretty good vision, but I cant make out the numbers on it.
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 03-02-2010, 07:38 PM   #782
mouthfulloflake
Not afraid
Oddometer: 17,277
you have probably seen this?
http://www.horizonsunlimited.com/hub...no-spark-35660
Old 03-02-2010, 09:30 PM   #783
Dragon43 OP
If you insist.
Dragon43's Avatar
Oddometer: 6,016
Originally Posted by mouthfulloflake
Not seen but have now, thanks.
Good site, I have printed that out and bookmarked it.
All I have is a scan from a guy in England that I copied and printed, let me see if I can get it and down load it and make it better. It is hard to read.
Shouda, woulda, coulda but dint.
Dragon43 is offline   Reply With Quote
Old 03-02-2010, 09:59 PM   #784
Dragon43 OP
If you insist.
Dragon43's Avatar
Oddometer: 6,016
XT 500 wiring diagram & ledgend.
Two pictures. (dial-up warning, one is big.)
http://www1.webng.com/dragon43/xt%20wire%20diagram.bmp
http://www1.webng.com/dragon43/xt%20wire%20ledgend.bmp
Old 03-03-2010, 04:47 PM   #785
Dragon43 OP
If you insist.
Dragon43's Avatar
Oddometer: 6,016
Spent some time sticking the multi-meter probes up the XT's coil's ass today. If not before, I am pretty sure now the coil is funky. The wiring diagram is not much help because it does not show the internal connections but I found a statement that the ignition coil side is not supposed to go to ground which would make sense in a way. But.... If that is so, then the rest of the diagram does not, as least according to what I can sorta see on the wiring diagram. Going to squint at it some more but even if I do not understand it, maybe the new coil will fix the problem.
If aircraft magnetos were wired like Yamaha does it, airplanes would be falling from the skies like dead Armadillos... Simple & safe it ain't...... Grrrrrrrrrrr
Old 03-03-2010, 05:39 PM   #786
TRZ Charlie
That's MR. Asshole
TRZ Charlie's Avatar
Oddometer: 15,891
Sounds like you're on the downhill side of it Gus, keep after it.
My SPOT - No tracks = not riding | Husky TR650 Thread Index | Husky TR650 OEM and Interchangeable Parts List | Cheap Beer & Tenderloins | "You know your getting old when a bad hair day includes your nose, eyebrows and ears" - Inmate - advNZer?
TRZ Charlie is offline   Reply With Quote
Old 03-03-2010, 07:21 PM   #787
Elvis70
No speed traps in the sky
Elvis70's Avatar
Oddometer: 5,056
I think you are supposed to try to kick start it 100 times as a test of the coil integrity.
I'll tape it to the handlebars, it's just logic George! If your hand is broken, you tape it to the bars! - Evil Knievel's reply to George Hamiliton's question, "How will you jump with a broken hand?".
Elvis70 is offline   Reply With Quote
Old 03-03-2010, 09:12 PM   #788
Dragon43 OP
If you insist.
Dragon43's Avatar
Oddometer: 6,016
I been thunkin: 5 miles East of me is a nice steep paved hill that is 1.2 miles long. I gots a truck, trailer & ramps. Me thinks that is much better than 100 kicks, unless it is me watching you do the kicking. Just sayin !!!!!
Old 03-04-2010, 02:59 AM   #789
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,338
Take somebody with you..thats a LOOONNNGGGG walk back up that hill by yourself!
DrLewall is offline   Reply With Quote
Old 03-04-2010, 03:22 AM   #790
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,338
hey Gus..here is a thread that you may wanna keep an eye on
http://www.advrider.com/forums/showthread.php?t=556026
Old 03-04-2010, 07:13 AM   #791
mouthfulloflake
Not afraid
Oddometer: 17,277
a point type ignition wont have that sort of a pickup I dont think.
BUT, those things are fairly easy to test.
put a meter on the wires coming out of it, and swipe a magnet past it, it should show a swell in voltage.
also, set meter to resistance, usually anything from 300-800 ohms is a good pickup coil, anything thats open ( infinite ohms) or short ( 0 ohms) will be a bad coil.
Old 03-04-2010, 10:15 AM   #792
Dragon43 OP
If you insist.
Dragon43's Avatar
Oddometer: 6,016
Agree.
But thanks anyway.
Old 03-05-2010, 07:00 AM   #793
mouthfulloflake
Not afraid
Oddometer: 17,277
OK Gus,
I finally had a few minutes here at work ( big monitor) to blow up your schematic and check that out.
the breaker points sort of are in parrallell with the magneto coil generator.
It looks as if the points stay closed and ground that magneto output most of the time, then the eccentric opens the points, and allows the magneato to saturate the ignition coil, then close again and collapse the field to induce that spark magic
I guess you need to verify magneeto output with the points OPEN, or simply verify you have some AC voltage going TO the ignition coil when you kick the engine over. simple easy test, look for a few hundred volts AC, with some rythym as you roll the engine over. ( take the plug out, make it easy on you)
if you have those timed pulses of AC, then start looking at the ignition coil.
mouthfulloflake screwed with this post 03-05-2010 at 07:05 AM
Old 03-05-2010, 08:41 AM   #794
Dragon43 OP
If you insist.
Dragon43's Avatar
Oddometer: 6,016
Thanks for that.... it makes more sense than anything else I can think of. I hope my new coil show up soon.
Old 03-08-2010, 07:03 AM   #795
sc-razor
sc-razor's Avatar
Oddometer: 3,776
Sure was nice to meet you Sat morning Gus.
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Times are GMT -7.   It's 03:57 PM.
