10-13-2009, 08:02 AM
#31 | |
Oddometer: 102
10-13-2009, 08:25 AM
#32 | |
Oddometer: 2,229
10-13-2009, 09:08 AM
#33 | |
STILL Jim Williams
Oddometer: 5,985
10-13-2009, 09:56 AM
#34 | |
Oddometer: 343
Thanks for the time and effort to post the photos and such But heck $22.00 is a very good deal for a controller. I used to use a portable one since I have multiple bikes, at that price I could mount one to each bike and still come out ahead.
PAPA duc |
10-13-2009, 02:00 PM
#35 | |
Group W Bench
Oddometer: 1,252
I'd been noodling a sealed controller for permanent mounting in the bikes fairing. Just have a knob, led, power switch, and connector. Lazy wins though, I've only been planning to do this through 3 bikes at this point. |
10-13-2009, 06:21 PM
#36 |
Pepperfool
Oddometer: 2,587
Interesting thread
Just a comment, I built my own controller using a power mosfet and found I had to drop the switching frequency to the 1-10 hz range or the controller would inject a ton of noise in the intercom/audio system. In the application of heating control that low frequency is of no concern.
Old enough to know better.... Young enough to try it again |
10-13-2009, 06:49 PM
#37 | |
Oddometer: 102
Keep in mind though, that this is my first attempt at heated clothing, and mine is untested in actual cold weather riding. So everything I have done so far is still “in theory” |
10-19-2009, 02:57 AM
#38 |
Oddometer: 61
Fantastic information here, think I'll be searching for some wire to run into the liners of my jacket and trousers this winter.
Cheers, Justin. |
10-19-2009, 05:53 AM
#39 |
where 2 ride today?
Oddometer: 228
Some other thoughts on construction
Hi,
I decided to try one myself. I bought the same starter jacket. Did not want to order wire and wait so I used 30 ga. transformer wire. The insulation is not as thick but supposed to be good to 200 c. It fits into a large needle nicely. I used 2 forty ft lengths. One in the body and one in the sleeves. I am planning to connect those in parallel. Two things I found that made the installation of the wire easier. One was to plan where the wires go and mark with a silver sharpie. You can use the marks to estimate wire length. Second was to have wife wear jacket turned inside out while I wired up the jacket. Better than working with jacket spread out on table. I didn't stick her to many times. I tested the jacket connected to a battery and seemed to work fine. I will borrow a meter to check amps later. Now I need to decide on connectors, controller, etc. Mike
Everything in life is not Digital (0's & 1's) |
10-19-2009, 07:35 AM
#40 | |
where 2 ride today?
Oddometer: 228
Connectors
There seems to be only one 5.5 X 2.5 jack size. http://www.action-electronics.com/dcpowerplugs.htm Thanks Mike
10-19-2009, 06:44 PM
#41 | |
Oddometer: 102
10-20-2009, 09:10 AM
#42 |
Oddometer: 10
Thanks for the great thread and the easy to understand and follow data/instructions... I wanted a liner/shell similar to what Gerbin and others use and was able to find one at Kmart, it is made by Basic Edition and you can get it on sale for around $10-17.00 ... It has a mesh lining and a few pockets with elastic cuffs, neck and hip/base. It is a shade heavier than the Walmart wind breaker... the only thing it can't do is fold itself into one of the pockets...
they run on the large size, so buy one size smaller than your regular size, I bought a medium which fits me very well with a 44 chest size. Kmart jacket
Happy riding LeDude...
Ledude screwed with this post 10-20-2009 at 10:02 AM |
10-22-2009, 07:13 AM
#43 |
Adventure forthcoming
Oddometer: 207
Gloves
Where are they? WHERE ARE THEY??? Man I watch way to many CG movies.
Any pics on the gloves yet? Very interested? We don't have such cold whether as you guys in the north, but, if it means being less bulky on the bike (think Michelin man), then I am a go for it.....just sad no matter what, my jacket will cost me a lot since my G/S don't generate that much power to play with. Happy trails and I like it.
If an idle mind is the devil's workshop, then a busy mind is God's canvas Democracy and politics is a conflict of interest |
10-22-2009, 10:15 AM
#44 | |
Oddometer: 102
I haven't had any time to work on them due to work, but my goal is to finish the whole setup this weekend. Pics and build report will be posted then. Sorry for the wait, yes, my hands re REALLY sorry for the wait! |
10-22-2009, 10:34 AM
#45 |
Oddometer: 10
Found another source for the teflon wire, Bulkwire.com, at $20.67 for a 100 feet spool and $4.95 for s&h.
it has the following specs: Conductor Silver-plated stranded copper wire Insulation Extruded PTFE Temperature Range -65°C to +200°C (-85°F to +392°F) Compliances
600 VAC
