Old 10-11-2009, 10:20 AM   #1
The Jerk OP
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,614
New (to Me) 2000 Kawasaki W650
EDIT - Links to how-to tutorials buried in the thread:
Installing Kawasaki Euro low-bar kit
Installing Five Stars luggage rack
Removing the carburetors
Installing Race Tech springs & cartridge emulators
Replacing the rear fender
Installing the Hepco & Becker rear rack
Removing the Kawasaki Clean Air (KCA) air injection system
Removal and Replacement of the Battery
So the other weekend I picked up a '00 W650 in incredible condition. I first got a chance to ride one of these about a year ago when I helped a friend of mine buy one and ever since then I knew I would own one. In fact, I had already taken possession of my ex-'07 Scrambler at the time I first rode the W650 and even at that time I knew the W650 was the bike I should have bought instead of the Scrambler.
I sold the Scrambler earlier this year and hadn't planned on picking up another bike anytime in the immediate future but it turned out that this one became available, was the only W650 color scheme I was interested in, it was relatively local, and it was mint, so I had to jump on it as these bikes are not that easy to find and are even harder to find in stock unmolested condition which is what I was looking for.
My goal for this thread is for it to become as much of a resource for the W650 as my Tiger 1050 thread is for the Tiger. It seems online resources for W650 info are few and far between out there, no doubt due to the relatively small amount of these bikes that are in the U.S.
So here's the porn:
First, this is the condition of the bike when I went to go look at it (and actually got a test ride without even asking!):
And the following week, the happy buyer picking it up:
Then my friend Alicia and I went immediately to Van Sant airport for a glider ride and some guy parked his old Triumph right next to my W650 for a convenient photo op:
I took the following pics yesterday before taking it apart to get the carbs out (more on that later):
I love riding this bike. It has a really great feel to it. It's a 360 degree crank but it's counterbalanced. They dialed in just enough vibration to make it feel like a twin but not enough to rattle your fillings or put your hands to sleep. The exhaust sounds fantastic. The PO had punched the baffles out a bit on the stock exhaust so it's a bit louder than stock but it's a great tone. It's very quiet at idle. You only really hear it when you get on the throttle under load. However I think the bafflectomy has contributed to a lean condition (manifested mostly as a slight lean surge on steady throttle especially when the engine is cold) which I tried to address yesterday with some success but I think a re-jet is going to be in order. Will address that in a separate post to this thread.
I love the way the bike looks, I love the way it sounds, I love the way it rides, I love the bevel gear cam drive, I love the kickstarter. This bike just pushes my buttons.
I plan to keep it pretty much stock. I think I will have to re-jet as mentioned above. I've added on my E-ZPass holder and hard-wired in a Zumo mount. I've also added the Five Stars luggage rack available from Twisted Throttle which also mounts my Givi top case that I use on the Tiger.
I will also add a Powerlet outlet to power my Motopump kit's tire pump.
Soon I'll put up a pictorial "how to remove the carbs" post. That was my project yesterday.
2000 Kawasaki W650
The Jerk screwed with this post 06-23-2014 at 09:23 PM
The Jerk is offline   Reply With Quote
Old 10-11-2009, 10:26 AM   #2
Vbird
In Room 237
Vbird's Avatar
Oddometer: 784
Beautiful bike! It looks better than the new Bonnie.
Vbird is offline   Reply With Quote
Old 10-11-2009, 10:37 AM   #3
DaFoole
Lewddite at large...
DaFoole's Avatar
Oddometer: 4,135
Nice!!!
Always loved those bikes.
Couldn't believe Kawi pulled the plug on it so soon....
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
"Don't come in here with your thoughtfulness, empathy, and reason... this is shit, up with which, I shall not put." -Boondoggle
DaFoole is offline   Reply With Quote
Old 10-11-2009, 11:12 AM   #4
The Jerk OP
The Jerk's Avatar
Oddometer: 2,614
Carb Experts: Talk to me about jetting (I'm an FI guy).
Here's my situation: The W650 is pretty much bone stock except the PO punched out the baffles on the stock exhaust. I suspect that this is causing the bike to need a richer mixture than the stock jetting can provide.
I had the carbs apart yesterday (Keihin CVK) and found the stock jetting in place, that is a 118 main jet and 35 pilot jet. In fact, the carbs were so stock that I had to drill out the caps over the pilot screws before I could adjust anything.
I'm getting a bit of a lean miss/surge at steady throttle cruising, mostly @ lower rpms. It is worse when the engine is cold and improves a bit as the engine warms but still never goes away entirely.
My understanding is that the pilot circuit handles most of the fuel supply for that type of low-demand, low-throttle steady state cruising. I have opened the pilot screws up to 4.5 turns out and the lean miss has gotten better but has still not gone away entirely. I feel that at 4.5 turns out I'm probably pretty much near the max as to what the pilot circuit can supply.
Note that from the factory, one of the carbs had the pilot screw set at 2.5 turns out and the other one at 3.5 turns out.
An additional symptom of the lean running is I'm getting crackles and pops through the exhaust on decel. Part of that was due to the air injection system which I disabled yesterday by blocking the hose going to the air injection valve. This reduced the popping in the exhaust considerably but I'm still getting some, presumably from the mixture.
So my thinking is I might need to re-jet due to the now freer-flowing exhaust. My thought would be to just try and go up to the next size pilot & main and see what happens. I don't think I need to go crazy as I plan to retain the exhaust as is as well as retain the stock airbox. In doing a little research on the web, it appears that 120 main and 38 pilot would probably be the next step up.
Also I noticed that DynoJet has a kit for the W650 that has new mains and new needles (but they don't mention anything about pilots). Strangely, according to the PDF on their site, the mains are listed in various sizes from 108 thru 114. Unless DynoJet numbers their mains differently, that would seem to be a step in the wrong direction. Unless their needle changes the calculations versus the stock needle so that smaller main jets are used. Anyone know anything about that?
2000 Kawasaki W650
Old 10-11-2009, 12:47 PM   #5
tslewisz
tslewisz's Avatar
Oddometer: 2,374
I don't believe DJ jet sizes correspond to stock numbers. It does sound like you need to go up on pilots, but you could try shimming the stock needles (presuming they're not adjustable). If you go for a DJ kit, their needles will be adjustable, at least they've been for all the kits I've seen.
Love your bike.
tslewisz is offline   Reply With Quote
Old 10-11-2009, 01:40 PM   #6
The Jerk OP
The Jerk's Avatar
Oddometer: 2,614
The stock needles are definitely not adjustable. What would you shim it with? Washers?
2000 Kawasaki W650
Old 10-11-2009, 01:50 PM   #7
BarkALot
inhabitant
BarkALot's Avatar
Oddometer: 212
Congrats on the W.. I had one about 6-7 yrs ago.
I got aftermarket pipes for it, a corbin, and a lower handlebar kit. If I recall, I shimmed the needles and got the instructions from a website..
will see if I can find it.
Enjoy the bike !
I come from downtown
Born ready for you
Armed with will and determination
and grace, too
BarkALot is offline   Reply With Quote
Old 10-11-2009, 01:52 PM   #8
BarkALot
inhabitant
BarkALot's Avatar
Oddometer: 212
here's a link:
http://www.captainjakes.com/w650/shi...shimming.shtml
Born ready for you
and grace, too
Old 10-11-2009, 06:20 PM   #9
sjc56
Oddometer: 1,306
Very nice. Have fun.
Steve
sjc56 is offline   Reply With Quote
Old 10-11-2009, 08:03 PM   #10
The Jerk OP
The Jerk's Avatar
Oddometer: 2,614
Originally Posted by BarkALot
Thanks, that's great info. I think I'll try shimming the needle first as it's cheap & can be done with the carbs in the bike. If that doesn't work to my satisfaction then I'll look at re-jetting.
2000 Kawasaki W650
Old 10-11-2009, 11:41 PM   #11
RocketJohn
Hook em' Horns!
RocketJohn's Avatar
Oddometer: 11,330
Very nice bike!
RocketJohn is offline   Reply With Quote
Old 10-12-2009, 05:42 AM   #12
NCGS
De Oppresso Liber
NCGS's Avatar
Oddometer: 1,178
That's a helluva find.. the bike looks like it just came out of the box. Tell us the story behind how you found it.
There are things I still like about the W better than the new Bonnies (and I'm a multi-Bonnie owner), but (to me) the Bonnies simply have more power (not that 60 hp is a lot of power). Kaw did a great job building the bike, but they did a lousy job marketing it. I understand it's still produced and sold overseas.
Many years ago I saw a W where the cam cover at the top of the bevel drive tube had been replaced by a clear piece molded in the same shape as the stock cover. The owner started the bike for me, and it was really cool watching the bevel drive work the camshaft.
Back in the day when I was seriously contemplating buying a W I bought a genuine Japanese W650 sales brochure off fleabay. It's actually a very classy piece of multi fold-out page sales literature, written in Japanese that includes a photo of a '01 silver/blue W. If you're interested in collecting W memorabilia to go along with the bike, I'll be glad to pass it your way for a few bucks, since it doesn't appear that I'm going to be latching onto a W any time soon.
Congrats on a great bike, and a great find. Please don't bob/chop/mod it too much.. they're fine just like they are, and I have no doubt they'll become more collectible as the years go by.
'13 Explorer XC
'13 Speed Triple SE
Do not regret growing older, it's a privilege denied to many.
NCGS is offline   Reply With Quote
Old 10-12-2009, 09:00 AM   #13
Dranrab Luap
E-Tarded
Dranrab Luap's Avatar
Oddometer: 31,010
Pictures please. Thanks.
Sweet bike
Dranrab Luap is offline   Reply With Quote
Old 10-12-2009, 10:40 AM   #14
Phang
Phang's Avatar
Oddometer: 48
The shiny polished camshaft hypoid gears cover is just an ornamental cover. The hypoid gears are inside the rockers cover. Unlike ducatis where you can put a sight glass on the cover to view the gears in action.
Very clean bike considering it is 9 years old, I bet the mileage is less than 6,000miles.
Greetings from a stroked-down W650 owner
Cheers,
Phang
Singapore
Phang is offline   Reply With Quote
Old 10-12-2009, 11:20 AM   #15
jmlmjmjm
Oddometer: 904
One of the most enjoyable motorcycles I ever owned!
I loved every moment with it.
I left mine mostly stock with the following exceptions:
Low Bar Kit (brake lines, mirrors, handlebar) from Z-Power in Europe
SuperBrace Fork brace and progressive springs
National Cycle Superfly windscreen
Corbin Gunfighter saddle
slimmer '01 tank knee pads
There is a very active Yahoo Group associated with the bike.
Have great fun with yours, I know you will.
Wish I had taken better pictures of it when I owned it but here is one:
John M.
'08 Kawasaki Versys
'11 Victory Cross Roads
jmlmjmjm is offline   Reply With Quote
Times are GMT -7.   It's 12:06 PM.
