01-22-2013, 03:10 PM
#1591 | |
Oddometer: 80
zwish screwed with this post 01-22-2013 at 06:32 PM |
01-22-2013, 04:48 PM
#1592 |
Oregon Expatriate
Oddometer: 2,329
Shimming the needles affects the main jets, which come into play, so I've heard, around 3000 rpm or thereabouts.
I did the same thing, but all it did for me was use more gas without much other effect. So I took the shims out. (Pretty easy to do--much easier than the pilot jets. And easy to reverse if it doesn't work out). YMMV . . . . .
01-22-2013, 06:58 PM
#1593 | |
r-u-n-n-o-f-t
Oddometer: 12,178
The previous owner of the one I recently bought had put in Thruxton needles, which apparently have a richer taper. He'd also exposed the fuel/air screw and backed it out 1/2 turn.
On a cold morning it needs choke to start, but can be ridden away in a minute. It carburets crisply. Quote:
IBA #11735 . 1968-present |
01-23-2013, 05:54 AM
#1594 | |
British
Oddometer: 734
Here you go.........
Raising the needles make the mix richer - effecting 1/4 - 3/4 throttle range (approx) - it isn't necessarily related to rpm ! The pilot jets defo need to be upped 1 x size to help the poor part throttle running/spit back & slow warm-up. To ensure the air:fuel ratio is not overly lean at over 1/2 throttle opening, try upping the main jet a bit.... leave the needles until you've done this first. |
01-23-2013, 09:26 AM
#1595 |
Oddometer: 252
The general consensus on the Yahoo W650 group is that the main jet is already too RICH. I believe stock is about 118 and the ideal for stock air box and exhaust was found to be 112 by several who have dyno run and checked AFR with a sniffer. The overly rich main makes up for the non-ideal needles.
The needles are not tapered enough, this is an emissions thing. It allows really lean running in the operation range where the emissions are evaluated (low to mid throttle), then the overly RICH main jets help protect the engine at high load/rpm. Ideally, you should buy a jet kit with needles that have a more aggressive taper so that a 112 main can be ran, this will give a more consistent AFR throughout the operating range. The Factory Pro jet kits have the necessary needles. The idle jets seemed like there was no consensus. Either run the stock and back the idle screws out to 3.5-4 turns (or there abouts) or go one size bigger and turn the screws in. I read opinions that going to the 38 idle jets caused increased consumption, and it was better to keep the stock 35's with backed out screws. If you don't care about increased consumption, go with the 38's to get a quick warm up. This is all information I am regurgitating and paraphrasing from the Yahoo W650 group. I can't link the exact posts, but if you join and do a message search for "Jet Kit" or "Factory Pro" I think you will find the information. |
01-23-2013, 12:41 PM
#1596 |
British
Oddometer: 734
Pjensen641 - thats interesting - and I agree that either have "waisted" needles to increase fuel at a set needle/throttle opening to make a bit richer..... or a larger main jet.
As you rightly say, a DYNO run is the only 100% way to evaluate the A/F ratio to ensure you're not running lean at WOT (Wide Open Throttle), which could spell disaster if the main jets are too small !!!One point with the pilot jet and the pilot screw.... it's generally accepted that once the screw is open over about 3 or 4 turns, the screw has zero effect as the passageway is full open..... so if you start winding it further the next size pilot jet is needed. NOTE: The PILOT SCREW is in fact a method of controlling FUEL flow - not AIR (as in AIR SCREW)..... this is usually distinguished by the fact that the scew is the ENIGINE side of the carb - not the AIR BOX (intake) side So if the screw needs to be wound out, it's to make the part throttle circuit RICHER. Due to the sh*te weather here (UK) I haven't had chance to go for a decent run to do a plug-chop, so can't comment to specifically yet. |
01-23-2013, 03:09 PM
#1597 | |
Oddometer: 2,393
length 2.152 Diameters tip+ 0.0 = 0.066 tip+ 0.2 = 0.070 tip+ 0.4 = 0.074 tip+ 0.6 = 0.079 tip+ 0.8 = 0.084 tip+ 1.0 = 0.090 Taper begins Tip+ 1.330 Non taper Diameter 0.097 Anybody got the specs on the stock W needles?
Vince @ SWFL or WNC 2001 Kawasaki W650 2012 Ural Yamal |
01-25-2013, 05:46 AM
#1598 | |
acap650
Oddometer: 354
http://www.powersedge.com/pages/OemP...fC19C1946E1612 |
01-25-2013, 07:14 AM
#1599 |
Oddometer: 2,393
Funny that the Dynojet kit has both needles the same.
STAGE ONE INSTRUCTIONS 1. Remove the vacuum slide from the carbs. Remove the stock needles & spacers, noting the order of assembly. 2. Install the Dynojet needles on groove # 2, using all stock spacers (Fig. A). Install the adjusting washers above the e-clip (2 per needle). Install the Dynojet slide springs (DSP005) in place of the stock slide springs. 3. Remove the main jet and replace with the Dynojet main jets provided. Use the DJ108 main jets with stock exhaust. Use the DJ112 main jets with aftermarket headers or slip-ons with free flowing baffles. Be sure that the jets you are changing are the main jets. 4. Locate the fuel mixture screw (Fig. B). If you see a screw head, proceed to adjusting procedure. With the plug drill (DD #5/32) provided, carefully drill thru the plugs. NOTE: The mixture screw is directly underneath this plug, be ready to pull back on the drill the instant you break thru. Use screw provided to secure and remove the plug. Carefully turn mixture screw clockwise until seated, then back out 3 turns. http://www.dynojet.com/pdf/2176.pdf http://www.ebay.com/itm/00-02-Kawasa...-/310292839382
01-30-2013, 08:08 AM
#1600 |
Oddometer: 80
So has anyone installed that Dyno kit? Looks like it could be a good solution. Thanks!
01-31-2013, 06:56 AM
#1601 |
Oddometer: 23
I have the dynojet stage 1 needles on my bike and a 2-1 exhaust with original air box. When I installed the kit with the clip on groove #2 the bike was almost impossible to drive, it was running to lean. Like when the tank is almost empty, but all the time! I then moved the clip down to groove #3 to make it richer, now its running like a champ. I change them right before the winter arrived so I havent had the chance to test it "full out" but it feels more "smoother" and like it has more "power". I doesnt remember how many turns out my fuel mixture screw are thou... think it is about 3,5-3,75
01-31-2013, 07:00 AM
#1602 |
Oddometer: 80
What are you talking about when your saying "clip to groove 2, groove 3, etc." Is this a part of the dyno kit? Thanks.
zwish screwed with this post 01-31-2013 at 07:05 AM |
01-31-2013, 07:05 AM
#1603 |
Oddometer: 23
Oh, sorry! On the dynojet needles you can either lower the needles (by placing a clip on a higher groove) or raise the needles (by placing a clip on a lower groove). Unlike the original needles that only has one "stop" on one side of the needle. Here you can see the grooves (on the left side of the needle) and the clip on the #2 groove.
http://faq.ninja250.org/images/1/16/Jetneedle-horiz.jpg |
01-31-2013, 07:13 AM
#1604 |
Oddometer: 80
Ah perfect! Thanks for the clear description. Would you have installed the kit if you weren't running aftermarket pipes?
01-31-2013, 07:18 AM
#1605 |
Oddometer: 23
Hmm I dont really know, doesn't know if it will run better with dynojet needles and stock pipes. But I guess it will! Its a very simple procedure to install the needles, you don't even have to take the carbs of the bike so it will take like 30 min to do it!
