Old 08-01-2013, 01:08 AM   #2056
Fuzzball
Oddometer: 130
Or I hand all the parts to the same bloke who's turning my SR500 in a 45~50HP monster ...and a shit load of money
Just found that the builder of the nicer set of pipes i linked earlier, has a sound check video hidden on his sight.
http://symzcraft.jp/public_html /video/video.html
3rd link, right click and save to desktop, run in player of your choice.
rool:
Bash plate wise, I'm going to use U-bolks and or "half saddles", with rubber hose or tape over the frame at the mounting points.
Oh, and I just ordered a set of K60's
Fuzzball screwed with this post 08-01-2013 at 01:13 AM
Fuzzball is offline   Reply With Quote
Old 08-08-2013, 09:22 AM   #2057
GoonerYoda
Hot Dickens Cider
GoonerYoda's Avatar
Oddometer: 802
So um...I searched, but maybe I suck at it.
What's the range average range of the W650 on a full tank? 4 gallons is the capacity right?
GoonerYoda is online now   Reply With Quote
Old 08-08-2013, 09:25 AM   #2058
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 304
Depends on your environment and riding style... I can manage 280 kms on my local twisties and village streets.
With the high bars on yours I doubt you'll achieve as much. I would guess you hit reserve by 180 kms ?
______________________
99 Clubman W650
78 R100/7
BravoFox is offline   Reply With Quote
Old 08-08-2013, 09:56 AM   #2059
GoonerYoda
Hot Dickens Cider
GoonerYoda's Avatar
Oddometer: 802
Not sure if I did this right....
I filled up on 7/29. Don't remember the exact amount but I filled the tank. Road around a mixture of back roads and city streets. Racked up 133 miles. Got gas, put in 2.6 gals to fill it back up again. So I guess I got 51.15mpg?! So I was guessing I'd get around 200 miles per tank? Something doesn't seem right...no coffee in the office this morning. :(
Old 08-08-2013, 10:08 AM   #2060
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 304
You were asking about range, now you are talking fuel consumption. They are related alright, but two different things nevertheless.
Fuel up, zero in your trip odometer, ride, fuel up again, read the quantity of gas you just pumped in your tank, read the mileage, do the math.
99 Clubman W650
78 R100/7
Old 08-08-2013, 10:22 AM   #2061
GoonerYoda
Hot Dickens Cider
GoonerYoda's Avatar
Oddometer: 802
That's what I did!
So if I'm getting around 50mpg, I should get around 200miles per tank, right?
Otherwise, I should just fill the bitch up and ride around until I run out of gas and check the trip odometer while waiting for assistance.
Old 08-08-2013, 10:28 AM   #2062
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 304
That's what I did!
50mpg would make sense indeed.
May I remind you the notion of RESERVE on your tank ? Run your bike until you hit reserve, note the mileage it covered, and try to avoid using the reserve at all by filling up slightly before.
For instance on mine I know that with my riding style, type of roads etc... I hit reserve at approx 240 kms. Well most times I would fill up between 220 kms and 240, slightly before having to switch.
99 Clubman W650
78 R100/7
Old 08-08-2013, 12:28 PM   #2063
chupa88
Oddometer: 65
I get about 45mpg in the city and up to 60mpg on the highway. Check out Fuelly.com. It'll let you record your mpg online and keep a history.
chupa88 is offline   Reply With Quote
Old 08-08-2013, 07:28 PM   #2064
acap650
acap650
acap650's Avatar
Oddometer: 711
125 miles to reserve. Takes less than 3 US gallons so maybe another 50 miles on reserve. Never tried to run it out. I get 45 - 50 mpg.
acap650 is offline   Reply With Quote
Old 08-08-2013, 07:38 PM   #2065
marco83
marco83's Avatar
Oddometer: 4
I get 27.25km per L
17L get me 463.25k
I am using a 18L aftermarket alloy tank.
Mostly travel speed is 90-120km.
marco83 is offline   Reply With Quote
Old 08-09-2013, 06:45 AM   #2066
lkr57
scooter trash
lkr57's Avatar
Oddometer: 241
gas capacity?
I don't think it really holds 4 gallons. I was on a weekend trip recently and ran onto reserve at 110 miles (headwinds, hills, cruising at 70+ mph). The owner's manual states the tank holds 15 liters (3.9 gal) with a 3 liter reserve. The closest gas station was 30 miles up the road. I did some mental arithmetic and figured that I probably wasn't going to make it (according to my on-the-bike mental calculations anyway). I slowed way down and did make it. When I filled up the bike only took 2.65 gallons. That worked out to about 52 mpg. It seems that either the tank holds a lot less than stated, or reserve is a lot more than stated, or both. One of these days I'm going to drain it and see how much gas it actually takes.
96 M900, 00 W650, couple of Nortons, and more...
lkr57 is offline   Reply With Quote
Old 08-09-2013, 07:02 AM   #2067
GoonerYoda
Hot Dickens Cider
GoonerYoda's Avatar
Oddometer: 802
I've thought about the actual amount of fuel the tank holds. I haven't had to switch it to reserve.
Old 08-10-2013, 09:06 AM   #2068
Pigford
British
Pigford's Avatar
Oddometer: 963
The tank has a recessed lip at the filler and you can't fill it up fully anyhow
I manage 65mpg (UK) easy and on a 50mph run got a genuine 80mpg
Pigford is offline   Reply With Quote
Old 08-10-2013, 09:33 AM   #2069
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 304
Why are we even talking about fuel consumption of a 650 cc twin cylinder engine ?
99 Clubman W650
78 R100/7
Old 08-10-2013, 07:51 PM   #2070
GoonerYoda
Hot Dickens Cider
GoonerYoda's Avatar
Oddometer: 802
Because I wanted to know. I plan on going from the Wine Country to Reno, NV for Street Vibrations next year and I'd like to know how many stops I need to make.
It's about 220 miles and in a car would take about 3.5hrs.
Or I can take a bit more scenic route via Lake Tahoe and it would be about 250miles and about 4.5hrs.
So it looks like at least 2 stops which would be perfect for taking a break as well. The scenic route would probably require 3-4 because why the hell not!
BTW...I'd love to ride to Sturgis, SD which is about 1,400 miles. Another one would be Daytona Beach, FL which is just a bit over 2,900 miles.
Times are GMT -7.   It's 06:52 PM.
