Old 09-29-2013, 06:52 AM   #2221
Zeon
Zeon's Avatar
Oddometer: 11
Hepco siderack 625.284 install questions
Just got a set of chrome Hepco sideracks for my W650.
Here are the instructions
http://neu.hepco-becker.de/Montagean...gen/625284.pdf
My one year of high school German is long gone, and I can't get Google translate to translate the entire doc.
My main questions are:
1. the kit comes with a black bracket that seems unnecessary, but looks like it might be an adapter for the top most mount point near the rear of the grab handle. Can anyone confirm what this part is and if I need it?
2. Does anyone have an English translation of this document? Cant' find one anywhere.
Thanks.
2001 W650, 2012 DR650,1982 Seca650, 1978 SR500
Zeon is offline   Reply With Quote
Old 09-29-2013, 07:31 AM   #2222
Zeon
Zeon's Avatar
Oddometer: 11
Photo of hepco parts 625.284 chrome
Here are the parts I referred to in previous post. Thanks.
Old 09-29-2013, 05:04 PM   #2223
Scrivens
Scrivens's Avatar
Oddometer: 566
It's the indicator mount and goes under the tail-light.
Scrivens is offline   Reply With Quote
Old 09-29-2013, 06:07 PM   #2224
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,842
boy, that sure solves the "cracking fender" problem . . . .
I like it.
Old . . . and . . . Slow
ORexpat is offline   Reply With Quote
Old 09-30-2013, 04:08 AM   #2225
Scrivens
Scrivens's Avatar
Oddometer: 566
Neither the indicator mount nor the bag rack mounts do anything to support the guard:
Old 09-30-2013, 05:47 AM   #2226
chupa88
Oddometer: 65
Originally Posted by BravoFox View Post
Hey Thanks. That was great.
chupa88 is offline   Reply With Quote
Old 09-30-2013, 05:52 AM   #2227
chupa88
Oddometer: 65
Originally Posted by Speedo66 View Post
A little thin skinned are we? No, I read where the filler cap was on my first bike in the manual. I didn't know anybody else that had a bike.
I did read the service manual regarding "Engine Lubrication." It was not very detailed and it did not even show a picture of the filler cap.
Old 09-30-2013, 08:18 AM   #2228
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,842
Looks to me that the black bracket attaches to or near the license plate bracket. Doesn't have to carry weight, just dampen vibration. If it does that it will substantially increase the life of the fender. Vibration is the issue.
Old 09-30-2013, 09:42 AM   #2229
orsurf76
engine braker
orsurf76's Avatar
Oddometer: 181
electrical question
so I'm planning on replacing my turn signals/indicators, and I'm looking into switching to LEDs to free up a little wattage.
It looks like the turn signal bulbs are 21w--how much power are the two front running lights drawing (while not indicating a turn)?
If I go with LEDs I'll need to add resistors--is there an option for replacing the OEM turn signal relay or do I just have to do in-line relays for each bulb?
Anyone done this for their bike?
orsurf76 is offline   Reply With Quote
Old 09-30-2013, 10:02 AM   #2230
The Jerk OP
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,651
Not sure of these bulbs specifically but generally speaking in the automotive universe, 21W is standard for a brake light or turn signal while running lights / tail lights are usually 5-8W.
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 09-30-2013, 11:31 AM   #2231
pjensen641
pjensen641's Avatar
Oddometer: 334
If you add resistors, you will not free up much power since it will be burned up in the resistor then right? There are some generic options for LED flashers that you should be able to wire in.
Pretty sure I used this one for one of my bikes. You just bypass the stock flasher socket or put some connectors on it that will interface with the socket. Linky
There are other options for flashers there as well as diodes to make sure your indicator light doesn't get stuck on. They have some nice replacement LED bulbs too. Make sure you get color matching ones for best light output.
In general, only the running lights and tail light would net a small power savings. The signals aren't ever on long enough to do much anyway. Another option would be to just replace the front indicators with a two wire signal only set up. Many bikes don't have those running lights.
Current Rides: '13 Street Triple R, '05 DR650, '05 DL1000, '03 SV650s, '01 W650, '02 KDX220
Past Rides: '82 GL500, '00 YZ426, '01 DRZ400S, '04 ST4S
pjensen641 is online now   Reply With Quote
Old 09-30-2013, 06:09 PM   #2232
Scrivens
Scrivens's Avatar
Oddometer: 566
It is simply a small joined plate which moves the indicators out of the way of the bag locks. It is bolted to the existing indicator mounts and nowhere else, so I can't see why it would have any damping effect - apart from adding perhaps 2oz to the 'unsprung' weight of the rubber-mounted taillight unit. (For the OP - I should add that the wiring has to be lengthened about 4" and redirected if the extension plate is used.)
The 2 smaller plates fit behind the under seat indicator mounting holes to attach the side mounting bar seen behind the pillion handgrip. Depending on the country, W650/800s came with the indicators either under the seat or on the taillight unit; there are mounting holes in both places.
Just checked the H&B site - the 2 small plates are used on the rack as well as the full system. They go behind the frame in the indicator mounting holes: you have to remove the top bolts of the mudguard and drop it a few inches to get them in, and the mounting bracket of the rack is bolted to it, as can be seen in my pics above. The plates are not interchangeable but the curved edge will show you which one fits on which side; they more or less click in place when properly mounted.
Scrivens screwed with this post 09-30-2013 at 06:34 PM
Old 09-30-2013, 08:20 PM   #2233
orsurf76
engine braker
orsurf76's Avatar
Oddometer: 181
Well Pjensen641, you make a couple good points. Maybe I'm chasing watts in all the wrong places.
So that electronic flasher unit you've used, where does it plug in? Where the relay goes or by one of the turn signals? Or by all of the turn signals?
Old 09-30-2013, 10:10 PM   #2234
pjensen641
pjensen641's Avatar
Oddometer: 334
You yank the old flasher out and install this in its place. Not plug and play, due to connectors, but totally eliminates the stock flasher.
Old 10-03-2013, 08:37 PM   #2235
snake89
snake89's Avatar
Oddometer: 138
Ok, im gonna chime in with my W. Ive got A 2000 model with 42000 miles, ive done all but 616 of them. Alot of those are hard fast sport riding miles with my sport bike club, its cafed out but has been semi scrambled it the past and has done a few offroad miles. I LOVE THIS BIKE ! Ive had it for 12 years & will never sell it. Im gonna build some sort of high pipe exhaust on it this winter. Its got a ducati monster headlight, low bars, a stock seat pan done up like a gunfighter also a stock 2001 seat for 2 up riding. Jet kit, airbox mod and debaffled pipes. Bobbed rear fender after it cracked and a lucas style tailight. Been wanting to go full scrambler with it since i bought it but its been too much fun as a cafe racer. A friend has one been sitting in his garage for 4 years, offered it to me stupid cheap. I think i see a second W in my shop in the near future. Ill get a pic when i figure out how to do it.
I can always beat the paramedics to my crashes by at least 10 minutes !!!
snake89 is offline   Reply With Quote
Times are GMT -7.   It's 07:14 PM.
