04-03-2010, 03:51 AM
#226 |
Oddometer: 542
Have race tech progressive springs and emulators up front and Progressive 440s on the rear. Works well, much better than stock, but not even close to my Ducati.
2000 Kawasaki W650 2006 Harley 883R 2001 Ducati M750 (sold) |
04-03-2010, 06:19 AM
#227 | |
Oddometer: 4,587
As far as the Hagons, is there any particular model? Another thing I noticed was, yes, you really are a sail at highway speeds with the high bars the bike comes with. Small changes in wind direction and speed had a great affect on the stability, so lower bars are next. Oh, and a 6th gear would have been nice, but maybe now I'm reaching. ;>)
'01 Kawasaki W650 '05 Yamaha XT225 |
04-03-2010, 06:07 PM
#228 |
Oddometer: 4,587
Another ride today. Leaned over in a left hander, hit a bump, and grounded some piece, probably the center stand.
Definitely needs some suspension work. ![]() But still, this bike puts a smile on my face every time I ride it (or look at it).
04-04-2010, 08:14 AM
#229 | |
Wannabe Adventurer
Oddometer: 82
I seem to recall if you just order "the ones for Kawasaki W650" you will get very stiff springs that won't work well for a rider under 200 lbs. W650 Shop lists some spring rate suggestions. Hagon has great customer service (they read their e-mails, too!) and will make suggestions if you tell them your size, if you ride with a pillion or not etc Hagon also has progressive front fork springs which are "drop in" unlike some other brands. If you get the springs sorted, you will soon notice there really isn't terribly much cornering clearance. The foot peg feelers are rather easily scraped even without bumps in the corners. |
04-06-2010, 10:28 PM
#230 |
Oddometer: 186
W650 gas mileage?
I picked up a used 2000 with a sidecar attached. I'm taking the chair off for some solo fun, and was wondering what to expect gas mileage wise. I was getting about 25-30 max with the sidecar attached and wifey riding monkey.
Cheers, Bill |
04-07-2010, 04:04 AM
#231 |
Oregon Expatriate
Oddometer: 2,329
I generally get 50-55 mpg. Better on longer rides doing backroads, lower on the freeway--but where's the fun in that?
I don't rev the W out too much. It's got enough mid-range torque to more than keep up with Dc traffic without wringing it's neck too often. |
04-07-2010, 04:41 AM
#232 |
Bavarian Murder Weapon
Oddometer: 672
Hey W650 owners - what's the handling like?
I understand its not a GSXR, but can you punt it around a corner (at sub or par speed limit) speed with a big grin on your face and not a face full of road? I'm very interested in getting one as my "Sunday fun bike" as I'm moving back to an area that I love riding in, but festooned with police.... Cheers Chris
_________________ 2008 BMW R1200RT SE Silver - "Tonto" 1981 BMW R65 - "Seven" My R65 Cafe Project |
04-07-2010, 09:24 AM
#233 |
Oregon Expatriate
Oddometer: 2,329
Actually, the W's handle OK--not great, but OK. If it's an original bike, new tires for sure. On mine, it reacted poorly to bumps in corners--felt like a hinge in the middle. I put Hagon's on the back and new 15w fork oil in the front--helps a lot. Have a Race Tech kit for the front but haven't had time to put it in yet.
Handling is better with the Hagon's, but the damping in the front leave something to be desired. Front bounces a bit. So, until I get the Race Tech springs and emulators in, I enter the corner kinda slow, then roll the throttle. That tends to transfer the energy and weight to the back where the good shocks are. It will never be a modern sport bike. Maybe that's one reason why I like it so much! But you can lean it a bit and have some fun.
04-07-2010, 11:47 AM
#234 |
Wannabe Adventurer
Oddometer: 82
Yes, it's fun in the twisties. You can grind the pegs even with the stock suspension but it's well worth upgrading with Hagons (I recommend them front and back, see my earlier post above).
I got rear sets and now it's my Dunstall replica exhausts that will scrape first. The stock Accolade tires are pretty bad. BT45s are better. Reportedly Dunlop GT501s and Avon Roadriders are great. Just got Roadriders for mine but haven't had a chance to test them yet. And get a 120/90 rear tire. It makes the bike a bit nimbler but not unstable. It's not as good as a modern sports bike but the best thing is it's a lot of fun at more reasonable speeds. You don't have to ride 30mph over the limit all the time to enjoy it. |
04-07-2010, 05:36 PM
#235 | |
Oddometer: 672
The speed nazi's are getting worse down here, and I can't afford to lose my license again. My strategy is to have a sportsbike (or two) for the track and an old school cafe racer for the road.
04-12-2010, 05:07 PM
#236 |
Oddometer: 4,587
Truly!
I'm finding I'm enjoying the bike at 70 MPH on roads I usually have to go 90-100 to enjoy on my SV1000. Lots safer physically and legally, but still a lot of fun.
04-16-2010, 10:19 AM
#237 | |
Oddometer: 4,587
I found the foot peg feelers unscrew out, so they're sitting on the shelf.
04-16-2010, 12:06 PM
#238 |
Oddometer: 3,978
Wow!- I have to look for that! I never had those feeler things until this bike. Rather disconcerting.
I feel like everything works together once assembled; tires, Hagons, and lower bars. Someone mentioned 6th gear- the PO of my bike put a countershaft sproket in there with one extra tooth. ??? It brings the revs down about 500 rpm, but I don't notce a lack of pick-up or anthing.
LOOK OUT IT'S COMING THIS WAY! |
04-21-2010, 09:41 AM
#239 |
Bring us some fresh wine!
Oddometer: 2,327
I love this bike! Now that the weather's been getting a bit warmer I've had it out more. I think a lower bar kit will definitely be on this summer's project list.
Does anybody else's headlight shell buzz/vibrate at a certain rpm? I gotta try and figure that out though nothing is obviously loose. |
04-21-2010, 11:59 AM
#240 |
Oddometer: 2,327
Also: the stock tires are not real confidence-inspiring during funtime. Plus I suspect mine are the original 10-year-old tires which unfortunately seem to have a lot of tread left. So I'm thinking about replacement.
Is the Bridgestone BT-45 *the* tire for this bike or what? Seems to be a popular choice. EDIT: just read a couple posts up about the Dunlops and Avons as well. Any other good options? Guess I'll be doing some tire research. |
