04-21-2010, 12:23 PM
#241 |
Oregon Expatriate
Oddometer: 2,329
Tires
I put Metzler Lasertec's on. Seem to work fine.
04-21-2010, 12:48 PM
#242 | |
Oddometer: 353
My headlight buzzed also so I took a little electrical tape and wrapped the lip that holds the light at the top of the housing. No more buzz.
99 Sprint ST, 00 W650, 82 XS 650 |
04-21-2010, 03:40 PM
#243 | |
Bring us some fresh wine!
Oddometer: 2,328
04-22-2010, 05:35 AM
#244 |
Oddometer: 353
I had taken mine apart to do some mods to it, but I miss riding it so much I put it back together before getting much done.
I was going to paint it but that can be done any time. I was bobing the rear fender and changing the tail light and signals as well as new pipes.
04-22-2010, 05:56 AM
#245 |
Oddometer: 2,328
BT-45 sizing
Hey guys,
Researching tires a bit and looking at the Bridgestone BT-45. The original rear tire size according to the owner's manual is 130/80-18. Apparently the BT-45 doesn't come in this size (or motorcycle superstore just doesn't carry it). So what are people going with? The 120/80-18 looks like the closest option even though by my calculations it would cut sidewall height by 8mm. EDIT: Im dumb. I didn't even look at the V-rated version of the tire. They do have the 130/80-18 size in the V-rated version. I certainly don't need V-rated rubber on a W650 but it's only a couple bucks more to get the right size so I'll probably just do that. The Jerk screwed with this post 04-22-2010 at 06:09 AM |
04-22-2010, 06:21 AM
#246 |
Oddometer: 353
That is what I have on mine. At one time I did use the 120 and it made a big difference in how the bike stood on the side stand. Too straight up.
Didn't notice too much of a difference while riding though.
04-22-2010, 06:37 AM
#247 | |
Oddometer: 2,328
04-22-2010, 06:40 AM
#248 | |
Oddometer: 4,588
The higher the speed rating, generally the stiffer the sidewall, so better handling. Probably the same for bike tires.
'01 Kawasaki W650 '05 Yamaha XT225 |
04-22-2010, 07:47 AM
#249 | |
Oddometer: 353
04-22-2010, 07:59 AM
#250 | |
Wannabe Adventurer
Oddometer: 82
04-22-2010, 10:05 AM
#251 | |
Oddometer: 542
Though mostly I use the center stand, so it is not much of an issue normally.
2000 Kawasaki W650 2006 Harley 883R 2001 Ducati M750 (sold) |
04-22-2010, 01:39 PM
#252 |
Oddometer: 657
picked up 2000 w650 last week
Love it so far. showed up with 2067 miles on the odo took it for shake down cruise and noticed after a mile or two the speedo quit working. now have ridden the bike for a few days and see the odo works and then not works and then works again. anybody got any suggestions?
04-22-2010, 02:49 PM
#253 | |
Oddometer: 2,328
Could also be a problem with the gauge itself but I would check out the speed sensor first because it's cheaper/easier and because the fact that both displays quit points to a speed sensor problem as the likely cause. EDIT: Now that I do have the service manual in front of me, I can confirm that the speed sensor is located on the output shaft near the front sprocket. Might want to pull the sprocket cover and check the sensor and wiring for physical damage. You can electrically test it but seeing as it's a solid state item it would be unlikely to be bad itself (I think). More likely damage to wiring or something. The other thing would be if the power supply to the speed sensor from the speedometer is faulty. You can test that as well by removing the clocks, connecting pin 5 on the back to +12V and pin 1 on the back to the - terminal of the battery, then use your VOM to test the voltage between pins 6 and 1. If it's less than 8V, you have to replace the clocks. They also make it a point to tell you not to short pins 1 and 6 or 4 and 6. They also have a more detailed test that can be done with an oscilloscope if you have one. The Jerk screwed with this post 04-22-2010 at 04:43 PM |
04-22-2010, 04:55 PM
#254 |
Oddometer: 4,588
There was a set a set of clocks on Ebay this afternoon, haven't checked to see if they're still there.
04-22-2010, 05:11 PM
#255 |
Oddometer: 657
thanks
Thanks for the circuitry insight Mr The Jerk
I relized after a quick look that this bike wasn't so old school that it would have a mechanical speedo/odo off the front hub, and I have yet to order a service manual. I'll check the speed sensor thing ASAP. |
