Old 04-25-2011, 10:18 PM   #616
Speedo66
Transient
Oddometer: 6,695
Great write up, explained everything very clearly.
Thanks for the offer of the ride, much appreciated!
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 04-26-2011, 05:08 AM   #617
The Jerk OP
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,614
No problem. You going tonight?
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 04-26-2011, 06:52 AM   #618
Speedo66
Transient
Oddometer: 6,695
I just checked today's local forecast and it says rain, starting at 3PM, 50% chance, extending into the evening.
Old 04-26-2011, 02:55 PM   #619
The Jerk OP
The Jerk's Avatar
Oddometer: 2,614
Huh. Down here the slight chance of rain has now gone completely away. Looks like it's gonna be a nice evening!
2000 Kawasaki W650
Old 04-26-2011, 04:28 PM   #620
Speedo66
Transient
Oddometer: 6,695
You're right, forecast changed.
Yes, coming down.
Old 04-26-2011, 04:33 PM   #621
The Jerk OP
The Jerk's Avatar
Oddometer: 2,614
Yes, coming down.
Sweet, I'll bring the W in. Looks like there's gonna be a good crowd there tonight.
2000 Kawasaki W650
Old 04-27-2011, 06:35 AM   #622
Speedo66
Transient
Oddometer: 6,695
I got to ride the Jerk's W with the great suspension mods. Money well spent!
The test track was lower Manhattan with all it's bumps, cobblestone streets, potholes, etc.
The front no longer dives under braking, and there is actually rebound dampening. The rear didn't bounce over bumps to the extent mine normally does. Overall, it felt well balanced and well sorted out. I'm about 30 lbs heavy than he is, but it still worked very well for me. It's funny getting off one bike, getting on to the same bike, but it feels so different.
Thanks for the ride!
Just one question though. Isn't there supposed to be a rev limiter on this bike? At one point I looked down and saw 11K on the tach, is this normal?
Old 04-27-2011, 08:52 AM   #623
folmonty
folmonty's Avatar
Oddometer: 282
Suspension follow-up
Originally Posted by The Jerk View Post
OK the Race Tech suspension upgrade.
Just wanted to say thanks for taking all the time to write up such detailed follow-up. Well done! Haven't done my forks or rear shocks yet. FYI - length of Progressive fork springs are 18.5". Quite a big difference. Maybe they're intended to be used without spacers?
Glad to hear you're happy with the results.
Monty
Nor CA
TS, XLH, GT500
R5, RD (x's3),W, ZRX
R100GS, GSA, KLR
folmonty is offline   Reply With Quote
Old 05-03-2011, 08:34 AM   #624
Speedo66
Transient
Oddometer: 6,695
New inmate posted this here, looks like a great bike with a great price.
http://www.advrider.com/forums/showthread.php?t=681366
Old 05-12-2011, 10:56 AM   #625
Kentucky
Oddometer: 1,222
Originally Posted by ORexpat View Post
Last winter I installed Hagon shocks and new fork oil in the stock forks on my Dub. Definitely better than stock, but still felt hinged in the middle. Weight shifts, bumps in corners, made the bike feel unsettled.
Just put Race Tech fork springs and Gold Valve emulators in the front forks. OMG what a difference!!!
Absolutely huge improvement in handling. Not upset by bumps. Can shift weight side to side in corner transitions without causing the bike to wiggle.
IMHO, absolutely worth every penny for both upgrades. It handles like a whole new bike.
The service manual says remove the fork tubes from the triple clamps and turn them upside down to drain. Looking mine over I cannot find a drain bolt so I am assuming that is the way to do it? Whatup Kawasaki...build a fantastic motorcycle and not allow for draining the forks in the chassis? Doh! Am I right...there is no other way?
2013 Kymco Like 200i
2009 Piaggio BV500 Tourer
2009 Kawasaki KLR650
1973 Jawa 350 Californian two stroke twin
Kentucky is offline   Reply With Quote
Old 05-12-2011, 11:20 AM   #626
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,794
A pro shop may have a pump that will pump out the new fluid, but us shade tree types have to do it the hard way. OTOH, I found the process wasn't too hard. And if you want to put on new seals or bushings, you'll have to pull the forks anyway. When you loosen the triple clamp bolts, the forks will slide down--no need to remove the headlight.
The hardest part of pulling the forks was getting the front wheel off. The torque spec for the axle nut is high; it took a cheater bar on both ends of the axle when I pulled mine.
YMMV.
Old . . . and . . . Slow
ORexpat is offline   Reply With Quote
Old 05-13-2011, 04:10 PM   #627
The Jerk OP
The Jerk's Avatar
Oddometer: 2,614
Anyone definitively know what size the allen is for the front axle on the W? I have forgotten and I want to buy a socket for it to put in my road tool bag. It's bigger than 10mm, I'm guessing it's 12mm but I'd like to know for sure before I buy the socket.
2000 Kawasaki W650
Old 05-15-2011, 07:41 AM   #628
Kentucky
Oddometer: 1,222
[QUOTE=ORexpat;15894136]A pro shop may have a pump that will pump out the new fluid, but us shade tree types have to do it the hard way. OTOH, I found the process wasn't too hard. And if you want to put on new seals or bushings, you'll have to pull the forks anyway. When you loosen the triple clamp bolts, the forks will slide down--no need to remove the headlight.
YMMV.[/QUOTE
Great reply. Thanks. I was wondering about the headlamp ears. Glad they stay in place that will make that job fairly simple. Yesterday was fun. I did some needed maintanence.
New tires
New Chain
Drained and flushed the tank (no ethanol water!)
Replaced spark plugs.
Lubed all cables.
Changed front brake fluid and installed new EBC's
and misc other stuff.
It is amazing how easy these bikes are to service. It was time at 20k for some lovin'
Barry
Old 05-15-2011, 08:28 AM   #629
acap650
acap650
acap650's Avatar
Oddometer: 643
12MM. Rather than a socket I just bought a 12MM allen key and dremeled off a 1/2 in. piece to use as an insert so a 12MM wrench does the job.
acap650 is offline   Reply With Quote
Old 05-19-2011, 05:57 AM   #630
Kentucky
Oddometer: 1,222
The W had a great week. New plugs, new Bridgestone S11's, new D.I.D. chain, new EBC brake pads and some other stuff followed by a detail cleaning. I couldn't love that bike any more.
Heading up to St. Augustine to World Golf Village for the 12th annual Riding Into History vintage event. Check it out at www.ridingintohistory.com. Gonna be fun.
Barry
Times are GMT -7.   It's 09:29 PM.
