Old 01-04-2012, 05:26 PM   #826
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,855
Fender re-hab
We all know how poor the chrome work is on the Dubya fenders; mine showed some significant rusting. Here's a pic of the rear fender after it was off. The front fender had a lot more rust.
Not so bad back by the tail light.
Taking the fender off is really easy with the rear wheel removed--and the front is even easier--4 bolts and the front's ready to work on.
On page 48 of this thread The Jerk has a really nice pictorial of removing the rear fender without removing the wheel. Nice photos, nice work.
Starting to take the rust down.
You can see the difference here.
JB Weld "Kwik" epoxy and some metal rod. This should keep the rear fender from cracking . . .
What I hope is the "holy trinity." Several coats of Hammerite first, then primer, then silver Rustoleum.
Partially painted.
Painted. I didn't bother to sand the JB Weld--its underneath and I wanted as much material there as possible.
Started to put the rear fender back on the bike. You can see the two bolts at the front/bottom of the rear fender.
There are four bolts that hold the fender to the frame underneath the seat.
Wiring loom going back through the fender.
Wiring clipped underneath the fender. You can see the extra epoxy in this photo. Also where the masking tape covered a bit of the metal . . .
Tool tray (and stretched to uselessness) bungee back in place.
Easy project, and I think well worth doing. Between the rust and the potential fender cracks, the time spent was worth it. Only cost was the paint and the JB Weld.
Old . . . and . . . Slow
ORexpat is offline   Reply With Quote
Old 01-04-2012, 07:50 PM   #827
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,976
ORexpat,
Another nice job with the photos and write up. Luckily my W is still rust free under the fenders.
Vince @ SWFL or WNC
2015 Ural cT 2001 Kawasaki W650 for sale
Bar None is online now   Reply With Quote
Old 01-05-2012, 07:22 AM   #828
igozumn
igozumn's Avatar
Oddometer: 129
Originally Posted by ORexpat
Looks nice--saw the photo in the Yahoo Group.
As did I. Looks good.
'90 Voyager
'01 W650
igozumn is offline   Reply With Quote
Old 01-05-2012, 11:29 AM   #829
acap650
acap650
acap650's Avatar
Oddometer: 727
Fender work
Well done ORexpat . Been there done that with the JB and rod bracing - 21K miles and no sign of a crack. No rust either but I do keep it clean and use nothing but Turtle Wash&Wax. Mixed up good and strong - waxes everything it touches.
Ride it and keep it shiney 'cause these W's are keepers.
acap650 is offline   Reply With Quote
Old 01-11-2012, 10:30 AM   #830
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,976
Went for a 120 mile ride yesterday on back roads at speeds up to 70 MPH and got 63 MPG. My odometer should be accurate since I now have the 16 tooth front sprocket on the W.
Did remove the small windshield and the ride is quieter without it. I wear a HJC full face helmet.
Vince @ SWFL or WNC
Old 01-11-2012, 10:33 AM   #831
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,976
acap650,
What cap do you have on the Air Injection System manifold on your W?
Vince @ SWFL or WNC
Old 01-11-2012, 03:17 PM   #832
acap650
acap650
acap650's Avatar
Oddometer: 727
Originally Posted by Barnone View Post
acap650,
I'm always amazed at the details that get noticed. I believe it is one of those rubber caps that are used for furniture legs - looks to be about 5/8 in. I.D.. I shortened it to around 1/2 in.. Been on there for 7 years and 18K miles - the heat doesn't seem to bother it.
Old 01-11-2012, 03:22 PM   #833
acap650
acap650
acap650's Avatar
Oddometer: 727
Forgot to mention that I also have the steel blocking plates behind the air manifolds - I believe they were called coasters and were made by someone from the Yahoo group.
Old 01-11-2012, 03:51 PM   #834
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,976
So the cap doesn't do anything?
Vince @ SWFL or WNC
Old 01-12-2012, 06:58 AM   #835
acap650
acap650
acap650's Avatar
Oddometer: 727
I suppose not, so why didn't I just remove the tubes and plug the holes with something?
Some folks bought OEM manifold covers that had no air openings but there is a limit to what I'll spend on cosmetics.
Old 01-12-2012, 07:39 AM   #836
rider929
rider929's Avatar
Oddometer: 365
I had a guy at work make me a set of block-offs. They sure clean up the front of the motor.
00 W650, 82 XS 650, 74 Commando, 03 RM250, 15 fj-09
rider929 is online now   Reply With Quote
Old 01-12-2012, 12:41 PM   #837
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,976
That's what I did on my DF250RTB to block off the port. Just an1/8" aluminum plate.
Vince @ SWFL or WNC
Old 01-12-2012, 06:56 PM   #838
rheritage
Oddometer: 300
Orexpat,
Nice work on the fender, should hold up no problem. When I bought my "W" last year it was too late for the fender, bike had 25K on it and 3/8 cracks on bothe sides. Prior to laying out $225 for a new fender I'm going to "Bob" it and install a small "Lucas" style tail light and small signals moved up near the frame, I'll post some pics when done.
It's a shame Kawi had to hang such a heavy tail light/signal assembly on that fender but at least they fixed it with a new reinforced design.
Thanks,
Rich
R75/5, R75/5 AHRMA Racer, R100GS PD, 1150GSA, WR450, Zuma 125
R100CS Sold, R100RS Sold, R80RT Sold, 1150RT Traded, RC51 Sold, KLR685 Sold, W650 Sold, CB1100F Traded, 1100S BCR Traded
rheritage is offline   Reply With Quote
Old 01-13-2012, 05:47 AM   #839
Speedo66
Transient
Oddometer: 6,873
Originally Posted by rheritage View Post
Orexpat,
Thanks,
Rich
I did just that when I got mine, having heard of the weak fender. Remove the rear reflectors, and the holes work perfectly with smaller turn signals. I think Kaw did just that in other markets.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 01-13-2012, 08:33 AM   #840
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,855
Because I ride in heavy DC/beltway traffic, I confess that I rather like having those big ugly turn signals way aft on the bike . . . they may be a touch more visible . . . .
At any rate, thanks for the comments about "should last a while . . . . " Sure hope so.
Times are GMT -7.   It's 06:51 PM.
