05-31-2012, 05:10 AM
#991 | |
Oddometer: 80
05-31-2012, 07:06 AM
#992 | |
Oddometer: 2,402
Vince @ SWFL or WNC 2001 Kawasaki W650 2012 Ural Yamal |
05-31-2012, 07:13 AM
#993 |
Oddometer: 542
I put BT45s on, but I can't recall whether they were H or V. I'll take a look tonight when I get home. This one change made such an improvement in the bike, it was like I changed bikes. Ride improved, handling was better, stopping vastly improved.
2000 Kawasaki W650 2006 Harley 883R 2001 Ducati M750 (sold) |
05-31-2012, 07:29 AM
#994 |
Oddometer: 80
Removing throttle cables
When you guys removed your throttle cables from the carbs, did you find that you had to pull very hard to get the cables out of the retainer bracket? I felt like I had to pull way too hard to the point that I might damage something.
zwish screwed with this post 05-31-2012 at 09:09 AM |
05-31-2012, 08:51 AM
#995 |
Oddometer: 80
Also, for you guys who are using 7/8" handlebars. When you shimmed them, did 7/8" to 1" shims work for you? I picked up these off of amazon and they did not work:
http://www.amazon.com/gp/product/B00...ls_o01_s00_i00 There was way too much play in the bars still. I ended up putting 3 half circles on either side of the bar clamps and that worked, but now I don't have enough to finish the job. |
05-31-2012, 09:09 AM
#996 |
Oregon Expatriate
Oddometer: 2,329
I bought my shims from a local bicycle shop, who ordered them from Quality Bicycle Parts, a wholesaler. They are called "Problem Solvers" and come in several sizes. IIRC, mine were sized for BMX clamps. They're knurled, like the ones in your link, but the knurling was much more prominent--and they've never slipped. Again, IIRC, they came in about 1" lengths, so had to hacksaw them to length. Two packages did both clamps and both brake/clutch perches.
Here's the link to Quality Bicycle Parts website. http://www.qbp.com/ Unfortunately my network at work won't let me pull up the catalog browser, but maybe you'll have better luck. But since they're a wholesaler, you'll have to go to your local bike shop to order, if you wish. |
05-31-2012, 09:20 AM
#997 | |
Oddometer: 80
http://www.amazon.com/Problem-Solver.../dp/B001F2Y2RO Thanks so much for the tips! |
05-31-2012, 09:35 AM
#998 |
Oregon Expatriate
Oddometer: 2,329
Looks like Amazon did you proud! Those are the shims I used. (Now, how to keep the local shops in business . . . )?
05-31-2012, 10:39 AM
#999 |
Oddometer: 80
Hah! I always hit up the local bike shops first. I'm an avid cyclist as well as motorcyclist. Definitely better at working on bicycles! Thanks again for the info.
05-31-2012, 11:19 AM
#1000 | |
Bring us some fresh wine!
Oddometer: 2,329
It should not be any real chore to pull the cables out of the bracket unless there is some major corrosion between the bracket and the metal sleeve around the cable. I can't remember exactly because it was a long time ago, but I can't remember if you need to remove the cable ends from the throttle on the carbs before you can remove the cables/sleeves from the bracket. In other words I don't remember which step comes first. Try removing the cable ends from the throttle linkage on the carbs first, then removing the cables from the bracket. EDIT: I just re-read my post back on page 20 and you do indeed have to remove the cables from the throttle linkage before you can get them out of the bracket. The Jerk screwed with this post 05-31-2012 at 11:27 AM |
05-31-2012, 11:25 AM
#1001 | |
Oddometer: 2,329
As for the cables binding, check your cable routing (there is a cable routing chart in the back of the service manual). If you route them the wrong way around something, they can definitely bind. |
05-31-2012, 11:45 AM
#1002 | |
Oddometer: 80
As for the biding, hopefully my routing was just off. I'm going to give it another go tonight. |
05-31-2012, 12:05 PM
#1003 |
Oddometer: 2,329
I guess my only other suggestion is to make sure you have the opening cable and the closing cable connected to the right parts of the throttle linkage on the carbs. If you lose track of which is which, operating the twist grip while seeing what the cable ends do to the throttle linkage should point out which is which.
05-31-2012, 12:06 PM
#1004 |
Oddometer: 2,329
Hey all, I compiled a list of links to my how-to posts and put it at the top of the first post in this thread. For easy reference in the future.
05-31-2012, 03:41 PM
#1005 |
Oddometer: 10
