Old 12-06-2012, 05:26 AM   #1426
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,683
Originally Posted by Speedo66 View Post
Unfortunately, the info a lot of new owners are seeking, his excellent pictorial on shimming the carb needles, is not there. I can't get his "modifications" thread to open, so perhaps that's where it is.
Speedo66.
I sent him an email about the problem. jake@captainjakes.com
Vince @ SWFL or WNC 2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Sky Team ST125-8A 2013 Sky Team ST125-6B
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Old 12-07-2012, 08:09 AM   #1427
acap650
acap650
acap650's Avatar
Oddometer: 681
Not sure much is to be gained by doing the needles or messing with jet kits, etc., unless one increases flow in exhaust and intake. On the other hand the idle screws are worth doing IMHO.
acap650 is offline   Reply With Quote
Old 12-07-2012, 12:38 PM   #1428
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,683
I agree but some like to tinker. I'm happy with my Ws performance.
2015 Ural cT
Old 12-07-2012, 01:20 PM   #1429
Speedo66
Transient
Oddometer: 6,783
I shimmed the needles and drilled out the caps and screwed out the idle mixture screws not for performance, but just for "rideability".
The changes seemed to make it a little less lean, which resulted in initially staying lit better when extremely cold, and quicker warm up.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 12-08-2012, 03:57 AM   #1430
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,150
Flying to Vegas on Friday to pick up a W and ride it back.
Nice and clean, 14.8k miles. Very reminiscent of one of my favorite old bikes in the 70's, an XS650D.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 12-08-2012, 04:37 AM   #1431
gkgeiger
Every ride is an ADV
gkgeiger's Avatar
Oddometer: 628
Ebay?
Getting old is not for Sissy's!
Gene
'14 R1200GSW
'12 NC700X/D
gkgeiger is offline   Reply With Quote
Old 12-08-2012, 05:26 AM   #1432
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,683
Congrats and of course photos are required to verify actual ownership.
2015 Ural cT
Old 12-08-2012, 07:16 AM   #1433
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,150
Originally Posted by gkgeiger View Post
Ebay?
nope....flea market.
He mentioned putting the bike on ebay in his ad and it got nuked.
Lives about a mile from my old place in Vegas (Henderson)
Has Norman Hyde "M" bars mounted upside down in the pics - he's putting the oem bars on, I may put the "M" bars back on right side up when I get back - I'll have to see what I like best.
Has oem mirrors and taillight too, but not turn signals.
Old 12-08-2012, 08:28 AM   #1434
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,683
Blakebird,
That is a nice and clean 2000 W. Those bars look nice with the high bar cables(?).
2015 Ural cT
Old 12-08-2012, 09:30 AM   #1435
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,150
He'd just done a valve adjustment and put in a new clutch with HD springs.
The original clutch turned out to be fine, just felt a little funky - and that went away with the new clutch & springs.
I was happy to hear it uses the same 7.48 shims as my TE 310...but it won't need any for a while.
Old 12-08-2012, 10:41 AM   #1436
Speedo66
Transient
Oddometer: 6,783
Do some reading here and you'll find that year rear fender was weak, tended to crack.
If you put the rear turn signals back on, suggest you mount them in the rear reflector holes rather than back on the rear fender to keep the weight off.
Nice bike, enjoy the ride!
Old 12-11-2012, 12:30 PM   #1437
Burninator
Zed's dead
Burninator's Avatar
Oddometer: 320
Alternator output
Howdy all -
I've done a google search and come up empty handed. Does anyone know the alternator output of the W650? I'd like to run a Gerbing jacket and gloves. Thanks!
Burninator is offline   Reply With Quote
Old 12-11-2012, 01:43 PM   #1438
Speedo66
Transient
Oddometer: 6,783
I run both on my '01 with no problem. Don't know the actual output though.
Old 12-11-2012, 02:02 PM   #1439
pumps
pumps's Avatar
Oddometer: 39
In my factory Kawasaki W650 service manual on page General information page 1-10 it states :
Alternator: Type Three-phase AC
Rated Output
18 A-14 V @7 500 r/min (rpm)
Hope that helps.
Dangerous! That's why you love it! - The Doobie Brothers
http://youtu.be/Dk4k1ZKxU94
A 2000 W650 is my daily rider.
pumps is offline   Reply With Quote
Old 12-11-2012, 05:16 PM   #1440
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,825
A Gerbing's jacket/liner uses 6.4 amps/77 watts at max--I've hardly ever been able to crank mine up to max even on a naked bike.
I'd have to ask my son, a real avionics electrician, but I believe the watts output of the alternator will be about 12 x 18 = or about 216 watts.
Headlight on bright about 60 watts, then add up the tail light, some guesstimates for the turnsignal/brakes (on only intermittently) and whatever you think the ignition might take.
So I thought about that for a while, what's left of my pea brain went up in smoke, and I just put on the liner and electric gloves and went for a ride . . .
Seriously, I've used both the Gerbing's liner and gloves on the Dub, but NOT at full power . . . I also crank them back down at stoplights.
No problems so far.
Old . . . and . . . Slow
ORexpat is offline   Reply With Quote
Times are GMT -7.   It's 02:30 AM.
