Old 07-08-2009, 06:22 PM   #1
PABiker OP
Anywhere but here
PABiker's Avatar
Oddometer: 3,671
My Version of the Kickstand Relocator
This is a completely bolt-on bracket to relocate the kickstand from the engine to the frame behind the left footpeg. The bracket is made from 0.250" cold rolled steel and powder coated black.
Fits all years of 9X0 Adventure and 950 SE models.
No longer will you have to worry about cracking the engine from a hit to the kickstand, or mounting the bike while fully loaded by stepping on the left peg.
The price of the bracket is $119.00 US each plus shipping including all mounting hardware.
PayPal perferred for payment, but if that is not an option for you then I will accept a certified check or money order via mail also.
Outside the US, I will accept only PayPal.
If you are interested in purchasing one or more of these, please PM me here or send an e-mail to:
ktmbikr66@comcast.net
Please provide the following information in the message:
Name:
Mailing Address:
E-mail address:
ADVrider Screen Name:
Within the US I use USPS Priority Mail Medium Flat Rate box for shipping. This way will cost the buyer $13.00 including tracking.
Outside the US I use USPS Priority International Flat Rate, this is the only option from the USPS that allows for tracking packages overseas. Once I know your mailing address, I can send you the price for shipping and verify with you that this is acceptable before sending an invoice.
UPDATE: You can purchase directly at www.ktmkickstand.com
Here are some pictures of the bracket:
Here are some pictures of the bracket installed on my personal '06 950 ADV:
Here are all the details of the entire build:
A few months back I started on my version of a kickstand relocation bracket for the 950. I started by copying a design I saw another inmate here made.
Rev 1.
Flat template made out of card stock:
Bent into shape:
Mounted on the bike:
Came out OK, but since the guy I copied the design from has a Super Enduro (no centerstand), this design is going to cause an interference between the kickstand and the centerstand.
Rev 2.
Template:
Bent into shape:
Mounted:
I drew it up in AutoCAD and got it off to my metal fabricator for a prototype. Hopefully in the next few weeks I'll have a finished product for all us 9x0 owners and we'll never have to worry about cracking the engine case anymore.
Well several weeks went by (8 actually, he has a busy shop) and this is what he came up with:
He had to make it in 2 pieces because of the compound bend on the back piece, and planned on welding it together.
I test fit it onto the bike and it was not exactly right, it interferes with the centerstand retracting completely to the full up position. I marked it up, made modifications to the drawings, and stopped by the shop to show them.
He is going to cut out another piece, we also came up with a way that it can be made out of 1 piece so it will not have to be welded.
OK, so here is Rev 2 ready for a test fit:
I got it on the bike and since I can't get things right the second time, it looks like there will be a Rev 3. All in all, it fits very good, only it needs a few minor tweaks to be perfect:
Rev 3 changes will be delivered this Friday morning to the fab shop. Most notibly will be a triangulation bracket on both sides to stiffen the bend where the kickstand attaches.
Hopefully I will have the next one before I leave (going to Colorado for 2 weeks) otherwise it will have to wait.
The part seen here is 0.125 cold rolled steel but I plan to have the final version made out of the same thickness stainless. And then powder coated black. EDIT: The final product is made from cold rolled, not stainless steel.
If all goes well I should have a viable product for the market by sometime in August. I have no idea just yet what the price will be so please bear with me, since the fab shop will be basing it on time and materials.
Worst case, I have a very expensive bracket I made for myself.
'06 KTM 950 Adventure
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker screwed with this post 10-20-2010 at 04:13 AM
PABiker is offline   Reply With Quote
Old 07-08-2009, 07:13 PM   #2
MJS
MJS's Avatar
Oddometer: 1,497
Nicely done!
How stiff is it. I would think that .125 might be not be stiff enough for the vertical. That's a long lever. I used .250 and it still has a little flex.
The bottom "arm" is being stressed upward in the vertical direction and the vertical arm will resist that force. I always try to think about where the stress are trying to bend the bracket and what resists that force.
As I looked at it, the forces on the kick stand are trying to bend the bracket where it mounts to the left side center stand bumper bracket. That is resisted by the vertical leg being in compression. The kickstand is also trying to bend the bracket inward at the bend where the bottom horizontal is bent to be the vertical leg. That force is resisted by the stiffness (directly related to the thickness) of the bracket itself. This could also be resisted by bending an "L" in the vertical leg. That effectively increases the stiffness of the bracket.
This is a very basic description and there are actually a lot of different forces at work. I'm sure an engineer could calculate it out, but that's not me.
Cheers,
"You can follow me, but it's gonna hurt"
MJS is online now   Reply With Quote
Old 07-08-2009, 07:25 PM   #3
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 12,786
That bungee is a mess waiting to happen.
Learn to ride. Ride to learn.
a1fa is online now   Reply With Quote
Old 07-08-2009, 07:31 PM   #4
PABiker OP
Anywhere but here
PABiker's Avatar
Oddometer: 3,671
Originally Posted by MJS
Nicely done!
Cheers,
There was some flex in it, which is why I am planning on adding the triangulation pieces to the sides.
I also plan to increase the thickness to 0.250 if the flex is too much.
'12 Suzuki DR650SE
Old 07-08-2009, 07:33 PM   #5
PABiker OP
Anywhere but here
PABiker's Avatar
Oddometer: 3,671
The bungee is just to hold the kickstand up because I don't have the springs installed. The hole for the spring post was tapped at the wrong angle.
'12 Suzuki DR650SE
Old 07-08-2009, 09:57 PM   #6
thugdog
Druid Revisionist
thugdog's Avatar
Oddometer: 396
I want to have yer baby...Uh, the first available Rev.4, that is.
Sound design method. Good itterative approach. Steady progress of improvement. Please keep us informed.
....there's nothing more permanent than a temporary solution
thugdog is offline   Reply With Quote
Old 07-09-2009, 12:53 AM   #7
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Greetings PABiker,
Great work!
One area that may need attention is where the chain runs over/near the bracket. Extra clearance here will ensure chain-bounce won't cut into it.
I'm in for one too!
ktm950se
ktm950se is offline   Reply With Quote
Old 07-09-2009, 03:21 AM   #8
PABiker OP
Anywhere but here
PABiker's Avatar
Oddometer: 3,671
Thanks, will do.
Originally Posted by ktm950se
Greetings PABiker,
Great work!
I'm in for one too!
ktm950se
I noticed that too. It is close when up on the centerstand but when off the centrerstand there is a good amount of clearance. But I do plan to trim away some of the material at the rear just to be safe. Here is a pic when it was off the centerstand:
I did more testing last night and I think I'm going to look into thicker material for the next rev instead of waiting. There was some vertical flex as MJS stated above, so it would be best to address it this time.
'12 Suzuki DR650SE
PABiker screwed with this post 07-09-2009 at 04:24 AM
Old 07-09-2009, 12:10 PM   #9
pigstain
Out of Control
Oddometer: 322
Excellent!!! After the sidestand relocation thread from hell and numerous folks attempting to design, fab and sell something, here PABiker comes along with a damn near finished product. Like stated before, it's great that the product is evolving quickly and we may be seeing something "real" real soon.
BTW, thicker is better for this bracket. It needs to carry the full load of the bike for a sidestand pivot turn without flex. It's appears very close. Finally.
You can't take it with you so spend it all on toys!!
2005 Honda CRF450X plated
pigstain is offline   Reply With Quote
Old 07-09-2009, 12:53 PM   #10
aurel
Cheese&Wine!
aurel's Avatar
Oddometer: 3,684
Great job
Put me on the list
aurel is offline   Reply With Quote
Old 07-09-2009, 01:08 PM   #11
Frgich
Frgich's Avatar
Oddometer: 729
I'm going to break my fingers from keeping them crossed for this one to happen
If You wish to be out front,
Then act as if you were behind
Lao Tzu
Frgich is offline   Reply With Quote
Old 07-09-2009, 01:12 PM   #12
KTRMN8R
Inmate
KTRMN8R's Avatar
Oddometer: 1,133
Eh? Question?
Hmmm,... Why did you want to relocate it,... what advantages are there??? I haven't seen the other histories so pardon my curiosities.
Thanx!,
KTRMN8R is offline   Reply With Quote
Old 07-09-2009, 03:51 PM   #13
aurel
Cheese&Wine!
aurel's Avatar
Oddometer: 3,684
Thanx!,
From stock the sidestand is attached to the engine case, it put some stress on it and it can damage it (cracks, oil leak).
Old 07-09-2009, 07:07 PM   #14
PABiker OP
Anywhere but here
PABiker's Avatar
Oddometer: 3,671
Thanks guys, I do plan on seeing this through. Just not sure what the cost will be until I perfect the design.
Heading to the fab shop in the morning to discuss the next rev, and it will definitely include making it thicker.
Details to follow.
'12 Suzuki DR650SE
Old 07-10-2009, 12:22 AM   #15
aurel
Cheese&Wine!
aurel's Avatar
Oddometer: 3,684
Is the wire long enough from stock ?
Times are GMT -7.   It's 09:01 PM.
