Old 08-13-2009, 09:42 PM   #151
sloMark
Oddometer: 854
Hey PABiker,
Just got home from work (17hr. day), had a horrible two days....I wanted to get out there in the lot with you for the test fit but wasn't able. Looks good! . Can you autograph mine?
sloMark is offline   Reply With Quote
Old 08-13-2009, 09:42 PM   #152
The Fist
Knulp
The Fist's Avatar
Oddometer: 3,601
Well done...I'll take two when they're ready....
The Fist is offline   Reply With Quote
Old 08-13-2009, 10:22 PM   #153
Adventureme
Adventureme's Avatar
Oddometer: 56
It looks like a factory part, and it's not even done yet. I want one. And I don't even have an Adventure yet!!! Good work man, well done.
Bob
Think of how stupid the average person is, and realize half of them are stupider than that.
George Carlin
Adventureme is offline   Reply With Quote
Old 08-14-2009, 08:35 AM   #154
brewer90
brewer90's Avatar
Oddometer: 582
Are you losing any ground clearance with this? This picture makes it look like the kickstand is hanging down below the centerstand but it is at an angle so I really can't tell.
brewer90 is offline   Reply With Quote
Old 08-14-2009, 11:03 AM   #155
mookymoo
Mookish Mook
Oddometer: 4,393
Originally Posted by lightfighter
if it does touch there, it will be going in the proper direction to glide off anyway. leave 'er be, i say.
Agreed. Less is more. Dont solve a problem we arent sure exists.
mookymoo is offline   Reply With Quote
Old 08-14-2009, 12:23 PM   #156
PABiker OP
Anywhere but here
Oddometer: 3,892
I designed it so the mounting point was at the exact same height as the original location. That way the bike would sit at the exact lean angle when on the stand.
Here is a pic looking straight on so you can see both mounting points, old and new:
The mounting point is approx. 1.75" further out than the original location. This was as close to the bike as I could get in the new mounting location.
I'm pretty sure the kickstand always did sit lower than the centerstand. Here is a pic with both up:
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 08-14-2009, 02:31 PM   #157
Rich2wd
Oddometer: 115
G'day PABiker, is it possible to tap the lowest side stand mounting hole on your bracket without the tap cutting into the backside of the bracket?
Perhaps if that hole is tapped prior to the folding sequence.
Cheers Rich
Formerly Rich too_wheelz
2007 KTM 990 Adventure
2009 KTM 300 Christini AWD
Rich2wd is offline   Reply With Quote
Old 08-14-2009, 04:16 PM   #158
dezracer
dezracer's Avatar
Oddometer: 642
Excellent. My only question now is how do you delete/disable the saftey switch? Did I miss that?
2007 990 Adventure
Suspension by Super Plush
Rekluse Pro Auto Clutch
WINGS N.O.S Exhaust
Euro Headlight with PIAA bulbs
KTM Hard Parts Radiator Cover
CJ Racer Clear Spoke Clutch Cover
Hilslamer Long Pegs
GPR Stabilizer
DH Racing tripleclamps
'300' Throttle Cam
16t CS Sprocket
Mefo "Super Explorers"
Ram Mount Garmin 76c
PABIKER sidestand relocaton kit.
2007 KTM 300XC (long live lightweight 2-strokes)
Las Vegas, NV and the Great Mojave Desert
dezracer is offline   Reply With Quote
Old 08-14-2009, 05:42 PM   #159
RogerDe
Dust In The Wind
RogerDe's Avatar
Oddometer: 266
Thumb
Look's great, I'm looking forward to put 1 on my 07 SE, Great Job. I'm sure glad someone final took on a production run of this much needed part for the Adv & Se ...Really BAD design KTM made on these bike's......Ride on...Thank's again...
2007 KTM 950 SUPER ENDURO Take it to the limit one more time !!!
RogerDe is offline   Reply With Quote
Old 08-14-2009, 06:14 PM   #160
lightfighter
where does this go?
Oddometer: 2,276
someone could maybe overlay stock and this pic, but it looks like in the up position, the lowest portion of the side stand is further back... where it use to go under the peg, it now dips down for no real reason. so i would surmise that the visual appearance of ground clearance loss is an optical illusion. stand by while i try to overlay the two photos, ive seen it done but ive never tried it.
lightfighter is offline   Reply With Quote
Old 08-14-2009, 06:24 PM   #161
PABiker OP
Anywhere but here
Oddometer: 3,892
Cheers Rich
Rich,
Unfortunately it is not possible due to the metal stretching during the bending process. If the hole were drilled before the bend, it would end up oblong after. All the holes except the 3 for the kickstand are actually cut by the laser during the cut-out process. I then have to send the bracket to a michine shop to have the 3 for the kickstand done on a CNC vertical mill so they are exactly in the correct location for both the 950 and 990 kickstands.
Because the kickstand switch for the 950 hangs off the back of the kickstand, I had to machine the holes that close to the bottom. And since the spring bolt is the lowerst, we had to drill slighty into the bottom of the bracket and tap it so the bolt would seat all the way. It does not come all the way through the bottom.
Thanks.
'12 Suzuki DR650SE
Old 08-14-2009, 06:25 PM   #162
lightfighter
where does this go?
Oddometer: 2,276
[/quote]
cant overlay them becuase i cannot recreate the camera angle... but it appears that a bit of GC may actually have been given up to get the sidestand to clear the centerstand when both up? or to achieve the proper angle when down... either way, it doesnt look significant.
Old 08-14-2009, 06:27 PM   #163
PABiker OP
Anywhere but here
Oddometer: 3,892
On the 950 it's just a matter of cutting the 2 wires and soldering them together.
But the 990 uses a different style switch so you will either have to extend your wires to reach or use one of these to bypass the switch completely:
http://www.ktmtwins.com/990superduke/61011046044.html
'12 Suzuki DR650SE
Old 08-14-2009, 06:31 PM   #164
PABiker OP
Anywhere but here
Oddometer: 3,892
You may be right, but the problem I had was getting the bracket to bend just under the lower chain slider. It does look like it's lower but the mounting points are exactly at the same level.
'12 Suzuki DR650SE
Old 08-14-2009, 06:46 PM   #165
lightfighter
where does this go?
Oddometer: 2,276
PA, i sent you an email
Times are GMT -7.   It's 03:18 AM.
