Old 08-08-2009, 08:31 AM   #121
PABiker OP
Anywhere but here
Oddometer: 3,877
Originally Posted by dad2bike
I wonder if it is really worthwhile to worry about the sidestand switch. Seems to me that those of us that are using the bikes in places that require the relocation, probably have (or should) disabled the switch due to the cutting out caused by off-roading. Mine is jumpered as well as my clutch switch.
Just thinking out loud.
Mine has been disabled for a while now too but I'm pretty sure that it is a requirement for some state/country inspections.
Plus, I didn't want to force people to disable it if they didn't want to. My only option was to make sure that it would still fit and that they will have to lengthen the wires if they want to keep it.
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 08-08-2009, 08:50 AM   #122
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
Gotcha. I wasn't aware of inspection issues. SUX to have to use a safety device that is unsafe in itself.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 08-08-2009, 06:04 PM   #123
Bermbuster
Bermbuster
Bermbuster's Avatar
Oddometer: 12
Eh? Who has broken a case?
Just found this thread, and I admire your hard work and engineering skills, however you're fixing a problem I wasn't aware existed. What were the conditions that caused a broken case due to the kickstand location? Did it get caught on a boulder while riding or ?? Has this happened to many others out there?
Tried to search this topic to find other instances, found nothing except this thread.
So, it looks like a great solution, I'm just not certain how large a problem it is. I'd expect blowing a hole in a side cover with a rock would be a larger concern, I've fixed a few of those for riding buddies . . .
Bermbuster
08 300 XCW, 08 450 EXC-R
06 950 Adv Black, 85 RZ350 Kenny Roberts resto mod
69 Z50A perfect condition, 36 HD VLD in restoration
on KTM since '87
Bermbuster is offline   Reply With Quote
Old 08-08-2009, 08:11 PM   #124
PABiker OP
Anywhere but here
Oddometer: 3,877
http://www.advrider.com/forums/showt...t=cracked+case
http://www.advrider.com/forums/showthread.php?t=340052&highlight=cracked+case
'12 Suzuki DR650SE
Old 08-09-2009, 12:52 PM   #125
Anthony
Hurry up, Stephie!
Anthony's Avatar
Oddometer: 301
My bike is in the shop now getting the cases replaced because of this issue.
If you hit a side cover with a rock, JB Weld or similar can be a permanent albeit ugly solution to this damage.
Since the side stand bolts to the case and contributes to the crack, JB Weld or similar will not fix this crack. If you lean the bike on the side stand again, the JB Weld will open up and continue to leak.
Some here have seemingly had luck with TIG welding the crack.. Fortunately for me, my extended warranty is covering the case failure on my bike.
The event that caused the failure on my bike should have been inconsequential. A small rock came up off the front tire and smacked my sidestand on a mellow dirt road. This is most definitely a real issue that needs a solution.
Hayduke drove a Jeep.
Anthony is offline   Reply With Quote
Old 08-12-2009, 02:07 PM   #126
PABiker OP
Anywhere but here
Oddometer: 3,877
Just got this message from the fab shop:
"I talked to the machine shop today. I will have the brackets here Friday around noon. Will need to weld nuts and your ready to try rev. 4 out !"
I plan to go there around 2:00 or 3:00 pm on Friday for the test fit. Pics to follow.
'12 Suzuki DR650SE
Old 08-12-2009, 02:21 PM   #127
azkiwi
message in a bottle
azkiwi's Avatar
Oddometer: 9,315
I'm interested to know how you got the warranty to extend coverage to that.
azkiwi is offline   Reply With Quote
Old 08-12-2009, 05:04 PM   #128
volrider
volrider's Avatar
Oddometer: 110
I think I speak for all those interested when I say thanks for sticking with this project.
Looking forward to seeing the finished product.
volrider is offline   Reply With Quote
Old 08-13-2009, 05:32 AM   #129
PABiker OP
Anywhere but here
Oddometer: 3,877
Thanks, hopefully this will be the last rev.
'12 Suzuki DR650SE
Old 08-13-2009, 06:49 AM   #130
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
"Keep running that play until you get it right."
Tom
My2Wheels
690 WIKI
Old 08-13-2009, 07:04 AM   #131
PABiker OP
Anywhere but here
Oddometer: 3,877
I'm not stopping now, this problem needs a solution once and for all.
'12 Suzuki DR650SE
Old 08-13-2009, 11:44 AM   #132
brewer90
brewer90's Avatar
Oddometer: 580
Well I'm definitely in line for one when you get it to the point of release. Very nice job!
brewer90 is offline   Reply With Quote
Old 08-13-2009, 02:45 PM   #133
SS in Vzla.
Totally Normal? I'm not!
Oddometer: 1,193
+1000
Great job!
One suggestion before you go into full production:
Try your latest rev onto several different bikes, not only your own.
SS. '98 BMW F650 / '06 WR250F / '07 KTM 990 Adv
Caracas, Venezuela
SS in Vzla. is offline   Reply With Quote
Old 08-13-2009, 03:20 PM   #134
FastEddieB
FastEddieB's Avatar
Oddometer: 638
I'm in - email sent!
FastEddieB is offline   Reply With Quote
Old 08-13-2009, 05:06 PM   #135
VTvfr
VTvfr's Avatar
Oddometer: 432
Originally Posted by SS in Vzla.
+1000
Great job!
Oh he will.
There's a couple of us in the 'Burgh that will be sneaking over to Schmoe's house to take it off his 950 to put on the 990's
Chad
'07 990 Adv
'07 250 XC-W
(plated)
'03 600RR
(track duty only now)
'94 VFR750 (sold)
VTvfr is online now   Reply With Quote
Times are GMT -7.   It's 12:12 PM.
