Old 04-20-2013, 01:08 PM   #2206
rtwdoug OP
prominent underachiever
rtwdoug's Avatar
Oddometer: 3,722
late 80s - mid 90s softail, nothin '58 about it. I'd guess about 4k if it wasnt pink, cleaned up & looking/running good, 5-6k.
but that depends on where you are at, as it seems to be outside the US, probably worth alot more. jamaica?
But Im no expert.....
www.motosapiens.org
My bike hotel in Bulgaria. ADVriders get 1st beer free!
rtwdoug is offline   Reply With Quote
Old 04-20-2013, 01:13 PM   #2207
ML WYDELL
NED
Oddometer: 498
Ghana, all kinds of stuff over here. Bmws, tenere, xt etc.
ML WYDELL is offline   Reply With Quote
Old 04-20-2013, 01:40 PM   #2208
rtwdoug OP
rtwdoug's Avatar
Oddometer: 3,722
Ghana? cool.... I saw the little flag on the HD plate, thought maybe Jamaica.
Any old stuff there? altho I bet exporting it would be a pain!
I've been wanting to do the west coast of Africa, everyone does the east coast. The west is a bit sketchy in places......
www.motosapiens.org
Old 04-20-2013, 03:08 PM   #2209
ML WYDELL
NED
Oddometer: 498
Today I thought I saw Condor go cruising by but it was a quick shot. Haven't seen any real old stuff yet but was only out looking today. I'll be venturing out into the bush and searching as well. There is a guy here that imports bikes from the states. If I find anything I'm sure I could put it in a container going back. Takes about a month. Did some riding in Ethiopia and hope to do some here as well. Chop shops all over the place. I may go broke here!
Old 04-21-2013, 07:50 PM   #2210
rtwdoug OP
rtwdoug's Avatar
Oddometer: 3,722
got my new alternator & sprockets in, so been getting that installed.
the orig alternator worked ok, but the new cycle electrics puts out more amps, & at a lower rpm.
The only travel bike I have built that I didnt put a CE charging system on was the dirtster, & guess what broke, in turkmenistan.
I've talked to the owner of CE a couple times at trade shows, told him what I had done with his products, & mentioned him in magazine articles.
I hinted around at maybe a discout for the advertising, but I was sorta brushed off. Oh well, I'll still use thier stuff, only because its the best out there.
but a discount woulda been nice.......
lotsa crap has to come off
this is an issue with the stock setup, the plug at the case. as you can see, the one contact is black, from a bad connection, and it wouldnt have lasted alot longer. the easy fix for this is to cut the plug off, & hardwire them together, & fill the case hole with silicone.
CE comes with it hardwired, so this issue is fixed
I have drawers of HD special tools, but nothing for this late model stuff. Luckily, I was able to modify the older clutch hub puller to fit, & also this sprocket nut socket, which wasnt deep enough to fit over the shaft.
so I drilled it out a bit
then it fit ok.
pulled the seal to look at the bearing, all seems ok.
front end almost done, have to fab up some fender brackets
www.motosapiens.org
Old 04-21-2013, 08:11 PM   #2211
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,115
How hard is the chain conversion, are the sprocket offsets the same? Everything come as a kit?
Are you goung to use a skidplate?
Laconic is online now   Reply With Quote
Old 04-22-2013, 07:49 AM   #2212
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,082
Hey Doug, are you going to head over to the Motorcycle Vintage Meltdown this coming Saturday?
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 04-22-2013, 09:11 AM   #2213
docwells7
docwells7's Avatar
Oddometer: 6,927
'1984 was a warning, not an instruction manual.' - Unknown
IBA#25276
Airhead#9654
docwells7 is online now   Reply With Quote
Old 04-22-2013, 09:14 AM   #2214
rtwdoug OP
rtwdoug's Avatar
Oddometer: 3,722
nope, hadnt heard about it. Going to an antique bike meet up in yankeeland
www.motosapiens.org
Old 04-22-2013, 04:10 PM   #2215
hd_topor
hd_topor's Avatar
Oddometer: 30
That's the first year of EVO softail, due to kickstarter and chain drive. And it was 4 speed tranny as I remember. They made a really few of them in this setup. But Ghana.....
Originally Posted by ML WYDELL View Post
Hey Doug,
Stumbled on this today, literally. 58 from what I'm told with about 7000 miles on it. Odometer / speedo in kilometers. Kicked it and fired up. Whats a ballpark price for this?
m
HD_TOPOR
hd_topor is offline   Reply With Quote
Old 04-22-2013, 04:55 PM   #2216
Phrog
Terra Australis
Phrog's Avatar
Oddometer: 397
Hey Doug,
Stumbled on this today, literally. 58 from what I'm told with about 7000 miles on it. m
Maybe they ment to say it's an 85 model.
Sugar Cane to Cotton Fields
Poverty is the mother of invention.
Phrog is offline   Reply With Quote
Old 04-22-2013, 06:57 PM   #2217
Spark Plug
Low on compression
Spark Plug's Avatar
Oddometer: 1,343
It's later that that. The motor is a top end breather (post 90) and the kicker is a aftermarket add on, on a 5 speed. I wouldn't touch that thing unless you can get it REAL cheap.
Nothing to see here.
Spark Plug is offline   Reply With Quote
Old 04-23-2013, 12:56 AM   #2218
jposttx
jposttx's Avatar
Oddometer: 179
Hey that looks like "son of dirtster" in the top of the first picture
How is it running?
Is the wife gonna chase you on that on the TAT while you carry the groceries on the hack?
See you
Originally Posted by rtwdoug View Post
spent all day pullin crap off the bike. some big stuff, & alot of little stuff, (CB crap, cruise control, etc....)
theres a large pile of debris flying out of the garage.
got the rear wheel done, just waiting on the new sprocket for the chain conversion. Also have a new cycle electrics hi output alternator on order. it will probably be the most expensive part of the conversion. Once that stuff gets here, I'll pull apart the primary & swap it out, & maybe install a new clutch if needed.
also got the sidecar mounts installed, and the rear one wouldnt fit with the V&H pipes, so I put a set of factory headers back on it.
next, figuring out the seat. I always have problems deciding on what seat to use. I'm a seat whore. I probably have 20 solo seats, just waiting for the right bike. To me, the right seat can make or break the look of the bike. Plus, they dont always feel the same way on the same bike.
I sorta like this old K model seat, its really comfy, and would work good with a set of rear springs.
but, with this wide ass frame, theres alot of crap exposed, which doesnt look to good for me. I could always pound out an aluminum cover to go on the frame tho
I tried a little bigger one, of course I wouldnt keep it white, but it fits about the same
then, for the hell of it, I stuck this KZ1000 seat on it.
it covers the frame, its flat, so I can move around on it, & it flows with the lines pretty good. Its about 2" too long, so sits a bit high, but I'm sure I could cut it up & lower it.
I know... a kawasaki seat on a HD..... but I'm really leaning towards this one......
James
'02 VTX 1800s - Black Beast
I have been elsewhere but nowhere else is Texas - I cannot save - Jesus is the Savior I cannot solve or even understand most problems - God solves all problems I can serve so I will - paraphrased rom Mark Driscoll
jposttx is offline   Reply With Quote
Old 04-23-2013, 02:00 AM   #2219
hd_topor
hd_topor's Avatar
Oddometer: 30
Yep, I was wrong. And you are right about "real cheap" :)
HD_TOPOR
Old 04-23-2013, 03:20 AM   #2220
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,022
I like the last seat the best,looks comfortable and,in a picture at least looks good on the bike!
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Times are GMT -7.   It's 04:16 PM.
