Old 09-05-2004, 08:38 AM   #1
JamesJWeg OP
"Speedy"
JamesJWeg's Avatar
Oddometer: 1,736
Question Wierd carb problem. (Bing CV)
Now that we airhead junkies got a place to play. My R100RT sports it's stock Bing carbs, and around the 100,000 mile mark it started snapping ether the main jet needle itself or the clip which holds it in the slide. Both carbs are doing this and I am only getting 2 - 3 K miles on each needle. Right now I am loosing one about every 1K because first it's one side, then it's the other. It's getting really old and I can't seem to find any answers, anyone know what's up? It's bad when you are preping for a weekend ride and you make sure you got two sets of needles and clips cause it's likly that you'll break more than one in two days.
James.
Hold my beer and watch this!
http://pics.jamesjweg.com
00100
JamesJWeg is offline   Reply With Quote
Old 09-05-2004, 02:57 PM   #2
a_k_nicholls
a_k_nicholls's Avatar
Oddometer: 291
Sounds to me like as the piston is lifting the needle up its kicking ever so slightly sideways & loading up the needle & eventually causing it to snap.
Check how much movement is in the piston as either the bore or piston itself is probably worn.
Said by a very brave soul " Lets Roll & Remember To Burn Rubber Not Your Soul "
Words of wisdom
Give big space to the festive dog that makes sport in roadway. Avoid entanglement of dog with wheel spokes.
Go soothingly on the grease mud, As there lurks the skid demon. Press the brake foot as you roll around the corners, And save the collapse and tie up.
F650GS Dakar in Australia
a_k_nicholls is offline   Reply With Quote
Old 09-05-2004, 07:20 PM   #3
arroyoshark
Needing some space
arroyoshark's Avatar
Oddometer: 2,130
No bling-bling Bing...!
arroyoshark is offline   Reply With Quote
Old 09-05-2004, 07:23 PM   #4
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
When was the last time you cleaned out the carbys ... could be some crud at the bottom of the needles' hole. Got some oil blow by? Then you will have crud. Unless you reroute the breather.
Oh, you better find the problem and fix it before something finds it way to the inlet valve!
Regards Frank Warner
motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S
http://www.geocities.com/fwarner_au/
Frank Warner is offline   Reply With Quote
Old 09-05-2004, 07:46 PM   #5
JamesJWeg OP
"Speedy"
JamesJWeg's Avatar
Oddometer: 1,736
Cleaned the jet stack, pulled it and dissasembled it, nothing, looks fine, no trash at all, I got twin inline paper element autotype fuel filters post tank, and got no trash from blow by, that plumbing's a little differant now . um, the motor has eaten several c clips no harm done, I've pulled the jugs and checked. When I take it apart early it seems like there must be a lot of extra movement somewhere as the c clip ring is worn loose, it will wear till the whole shoulder is gone and it drops. So where do I look for wear and who can get me specs of what size those parts should be?
James.
00100
Old 09-05-2004, 08:24 PM   #6
Frank Warner
Traveller
Oddometer: 6,593
Ummm... some advise replacing the seat along with the needle as they both ware together.
Is it the clip or its seat that is worn? ... If your have put in new clips and they are dropping out then I'd be looking at
1) the seat ... means you need a new piston $$ ...
2) the clip ... you certain you are gettting the correct clip?
... good puzzle ... may be the best place is the airhead list for this. Good Luck.
Old 09-06-2004, 10:29 AM   #7
JamesJWeg OP
"Speedy"
JamesJWeg's Avatar
Oddometer: 1,736
Ok, which part are you refering to as the seat? Here are the doc I've got on the carbs.
http://www.edgefield.k12.sc.us/jjw/Stuff/94x.pdf
http://www.edgefield.k12.sc.us/jjw/Stuff/64list.pdf
The parts which are failing are parts #14b and #4, I am replacing these with OEM parts, and any time I am in there I replace both of those parts at the same time with new OEM. Mine has clip style #14b and retainer style #15b. These are 64-3 carbs. Could the problem be that parts #2, #3, and #10 are worn? Or would it be #13 that is to blame? I have spoken to Bing and they say mail them in and we'll figure it out. sounds like a lot of money to me. FYI, the bike has about 140,000 miles on it now.
James.
00100
Old 10-01-2004, 10:40 AM   #8
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,403
James.
mm .. I've rebuilt upwards of 20 such carbs in the last 5 years and can't see how that could happen. Are you sure you have the correct parts? Is there dirt in part 15b that pushes the clip down and out of 14b? Don't tighten 15b too mcuh. Seated plus a very minor bit of pressure is enough. Are the dimples in the carb rubbers lined up with the carb correctly?
Back in YVR after riding around the world for 2 years. www.nohorizons.net
Malindi is offline   Reply With Quote
Old 10-01-2004, 10:42 AM   #9
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,403
James.
Old 10-01-2004, 10:43 AM   #10
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,403
James.
Old 10-01-2004, 07:59 PM   #11
JamesJWeg OP
"Speedy"
JamesJWeg's Avatar
Oddometer: 1,736
It's all very clean, I've rebuilt and cleaned them several times. Yes it is the correct parts, the dealer has even repaired it twice, they are at a lose as well. Part 15b does not tighten down on 14b, should it? The carb rubbers are lined up correctly. When holding part 13 with 14b, 15b and 4 assembled part 4 seems to have a lot of play. A few times the sholders on part 4 have worn completly off allowing it to drop. At other times 14b fails dropping 4 into the jet. Every time I replace 14b, I also replace 4 as well. This has happened so many times I have gotten it down to about a 10 min operation to replace 14b and 4 with new parts.
James.
00100
Old 10-02-2004, 12:14 AM   #12
Malindi
Zen Adventurer
Malindi's Avatar
Oddometer: 5,403
James.
15b needs to tighten to hold 14b in place. The edge on 15b holds 14b in place, leaving 4 some wiggle room to move side to side, but not up and down, at all. If 4 can move up and down, even a millimeter, then 4 cannot ever be guaranteed to rise at the correct height. As well, if 14b is loose (up and down) in 13, it will vibrate and wear out the shoulders as you found and drop 4 into 2 and 3. 4 wears out together with 3 in normal circumstances only very slightly. 4 and 3 need to be replaced every 20K or so as a set, as 4 will wear due to rotational vibration and become out of round, letting too much fuel through 3. 14b is made of much harder material, hence wearing out 4. Normally, the fuel surface tension shields 4 and 3 from excessive wear. I think the fact 15b does not hold 14b down is your problem. Also remember that most mechanics never get to tinker with carbs and don’t get it taught in the BMW courses anymore.
Old 10-02-2004, 03:14 PM   #13
JamesJWeg OP
"Speedy"
JamesJWeg's Avatar
Oddometer: 1,736
Since the battery in that bike just went belly up I'll pull the carbs off and have another look soon. I'll take some pics of it so you can see if you see anything that I am missing. It's kinda funny, I've nearly been worshiped for fixing carb problems on other people's 64's, but mine keep failing.
James.
00100
Times are GMT -7.   It's 05:47 AM.
