09-24-2008, 12:53 PM
#2236 | |
Coyote's Brother
Oddometer: 3,299
Did this engine ever have a BMW oil cooler installed? If so, you'll need to swap the filter housing. If it never has an oil cooler, move on. If you had the rubber ring on the oil filter shaft, you might have been running with no/low oil pressure and that fracked your bearings. now you have another tear down in your future. Me? I wouldnt bother with oil pressure guages or running the bike more because you already know that you have an oil pressure problem. The engine is simple by design, so you should be able to figuir this out. If you have no obvious oil leaks, the first place I'd look at would be the oil pump. Check the rotor and housing for proper clearance. If the clearences have opened up, (Somewhat common in these instances.) thats the problem. If you confirm a bad oil pump, you'll need to measure the rotor and the housing. The housing can be sleeved if necessary. The rotor can be replaced. If the pump checks out, move on. Once youve checked oil pressure and delivery to your satisfaction, mic both the main bearing journals and the rod journals, and install whatever new bearings you need with proper break-in lube and new bolts. Install the top end and then turn the engine over a bunch, confirming oil pressure before you run the engine. ALso check the pick-up for leakage. It's suprising how often eratic or low oil pressure is traced to a fracked PU. If you remove the PU, replace the bolts using red locktight. Accept no substitutes. Did you turn the engine over before you bolted in the rods? My wrench taught me to add oil to the sump and turn the engine over with the starter to confirm that oil was running through all oil passages. Did you do that? If not, remove the top end and perform that check before going further. Blown bearings might also be caused by junk in the oil passages. Eaten bearings get expensive. (You did mic the journals, right?) I gotta take my bike over to my pro wrench for a 500 mi check-up on the R-90 SPL this afternoon, so I'll give him a quiz. Airhead #85 Hawk Medicine screwed with this post 09-24-2008 at 06:59 PM |
09-24-2008, 01:41 PM
#2237 | |
Coyote's Brother
Oddometer: 3,299
If it was my descision to make and I was sold on the faired solo seat, I'd swap over to an R-100 tank, since thats what the seat was designed to go with and they look great together. OTOH... Probably the best and most usefull change that you could possibly make would be to add another front disk brake. When I built my Cafe bike, I remembered the words on my teacher/BMW expert/friend Del Ward of Virginia Beach, VA ,when he said: " Go ahead and modify the bike all you want but don't change it's character. It's a nice bike and it deserves to be what it is." Thats why, despite the fact that I have a complete set of R-100 tin on the shelf, I left my hot rod looking like this: Before: ![]() After: ![]() PS: This Winter, I'll have the /6 sport tank painted and striped to match and I'll be able to sport two different looks for the bike. Airhead #85 Hawk Medicine screwed with this post 09-24-2008 at 01:54 PM |
09-24-2008, 01:52 PM
#2238 | |
+/- V TDSPP
Oddometer: 19,954
This might be kinda off track, but check the oil passages in the front bearing carrier. Maybe the bearing spun because the key got knocked out or something, and blocked the oil passages.
What to do... What to do... |
09-24-2008, 02:49 PM
#2239 | |
Oddometer: 2,001
Cheers!
I suspect today's health & safety types would have a heart attack seeing that!
Doug 2006 KTM 525 EXC 2002 Yamaha FZ1 1973 Norton Commando & other old stuff |
09-25-2008, 08:09 AM
#2240 | |
Oddometer: 45
So, for anyone out there who knows, if I go with the R100 type tank, will that fit on my frame over top the master cylinder? Rode the bike to work today with the RS seat. Its harder than the stock r90/6 seat, but in my opinion, more comfortable. Otherwise, might sell the RS solo seat, and pick up something from: http://www.airtech-streamlining.com/bmw/bmwboxer.htm |
09-25-2008, 08:19 AM
#2241 | |
Beemerholics Anonymous
Oddometer: 7,365
There are many pictures of the custom bump style seats on the cafe airhead thread to get an idea of what they look like. It then would be up to you to decide how soft or hard you'd want it when it gets upholstered. If you decide to sell the solo seat I'd be interested.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
09-25-2008, 08:39 AM
#2242 | |
Oddometer: 45
I made some brackets that fit on the bottom of seat. Using the stock bolts coming out of the bottom of the seat pan, basically they set the "J" hooked hinges back a little less than 2 inches to make up for the gap that was there. Realizing if I go with the R100 tank, I can unbolt the brackets I added and put the seat where it is supposed to go. Extra gas the R100 tank can hold would be a benefit. |
09-25-2008, 08:47 AM
#2243 | |
Oddometer: 45
Doesn't have the sharp lines of the RS seat... |
09-25-2008, 08:48 AM
#2244 |
Oddometer: 7,365
The /7 tank will mount to your bike just fine. No problems with the master cylinder at all.
That's the standard S seat with custom upholstery making it a solo seat.
09-25-2008, 11:12 AM
#2245 |
Oddometer: 117
1970 Honda CB350
My first bike, got her about a month ago. She's pretty cool
09-26-2008, 07:54 AM
#2246 | |
Paulo Lança
Oddometer: 255
09-27-2008, 03:34 AM
#2247 |
Oddometer: 144
42wla-wld hybrid
42wla-wld
09-27-2008, 02:18 PM
#2248 |
Twisted toy maker
Oddometer: 1,498
My couch. 1982 Honda GL500I Silverwing.
44,000 miles,and still going strong. Next big trip, Portland To San Diego Via Oklahoma City next May........ Da Bear screwed with this post 09-27-2008 at 02:29 PM |
09-29-2008, 05:49 AM
#2249 | |
mc caregiver
Oddometer: 2,595
09-29-2008, 07:19 AM
#2250 |
supern00b
Oddometer: 6
here's my oldskool ride -- amal mkII mentor wanted
Hey there folks, been lurking around for a little bit. Enjoying the depth of info here -- almost overwhelming in fact. The eye candy is great as well.
I've had this Triumph for a while and have been slowly nicking off the bits it doesn't need. I bought the Meridan shop manual for it so I could sync the amal mkIIs, but I'm a visual learner and it's a little slim on diagrams. Is there anyone in or around Denver/Boulder who wants to mentor me?
-- John Clary Boulder, CO 78 T140e rat-bob (current, after log hiatus) '89 Softail Springer (what was I thinking?) '84 R65LS (never should have sold it) |
