Old 09-08-2004, 04:46 AM   #1
Muzungu OP
Muzungu's Avatar
Oddometer: 52
Some help needed with an R80GS.....Please!
Will someone please send me in the right direction to find out how to make the homemade carb sync tool using ATF. I have spent the past couple of hours searching on this forum and only came up with the fancyer home made tool that uses guages. Some time back I recall seeing one made of clear tubing and ATF, with air bleed holes in the tubing. That's the one I'd like to make. The simpler the better. Knew I should have copied the directions at the time.
An old timer friend of mine has asked me to see if I can get his 1996 R80GS to run better than it is. It sounds terrible in my opinion, think it has seen too many African shade tree mechanics! Suposidly the carbs have had new rebuild kits installed, and I do not know who the person is that did the work. I suspect that besides the valve adjustment being way off, there will most likely be problems with the carbs. The owner of the bike suspects that the carbs were pulled off and apart together, so parts are mix matched. Are there a lot of parts that are differant between the left and right side carbs? The owner also tells me that he has a couple of manuals for the bike, so I'm hoping that at least one of them is the workshop manual.
I sure don't mean to insult any of you that have the newer BMW bikes with TBs instead of carbs, by posting this here . Actually, because of this site and his old R80GS, I'm considering selling my 640 and buying a new 1200GS in a couple of years after all the new model bugs are sorted out. Still don't like the idea of "good for life" final drive oil though . But it sure looks like a sweet bike.
Any other tips for the 80GS anyone is willing to give up, will be much appreicated.
Muzungu is offline   Reply With Quote
Old 09-08-2004, 05:02 AM   #2
FN in MT
FN in MT's Avatar
Oddometer: 641
Try;
WWW.Airheads.org For all things Airhead ....... try the Airheads Club.
Also try the Tech section on the Internet BMW Riders group
Welcome to the Forum. Been to RSA a few times but never as far north as Your neighborhood. Gotta have some amazing riding! Out here in the Wild West of Montana striking a deer.elk or bear is a concern. In your country getting gored,stomped or EATEN is THE concern. Wow.
If this doen't do it I can give you a few more links.
FN in MT
"I'm tryin' to think....... but nothin' happens"
Curly Howard
Definitive Stooge
FN in MT is offline   Reply With Quote
Old 09-08-2004, 06:04 AM   #3
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 6,008
Question
Here you go: http://www.advrider.com/forums/showthread.php?t=49987
For Sale 1998 Triumph Tiger
Eurobiker is offline   Reply With Quote
Old 09-08-2004, 06:23 AM   #4
Muzungu OP
Muzungu's Avatar
Oddometer: 52
FN in MT and Eurobiker, thanks for the links and the quick reply!
This site is great! Kinda makes me wonder how we ever got along with out the internett
Thanks again
Old 09-08-2004, 06:42 AM   #5
JamesJWeg
"Speedy"
JamesJWeg's Avatar
Oddometer: 1,736
CHeck the "choke" part of the carb, a small airleak there will make it run like crap.
James.
P.S. Not sure which carbs that has but if it's the bings these two links might help you out a little.
http://www.edgefield.k12.sc.us/jjw/Stuff/64list.pdf
http://www.edgefield.k12.sc.us/jjw/Stuff/94x.pdf
Hold my beer and watch this!
http://pics.jamesjweg.com
00100
JamesJWeg screwed with this post 09-08-2004 at 06:58 AM
JamesJWeg is offline   Reply With Quote
Times are GMT -7.   It's 07:17 PM.
